05-07-2010, 09:54 AM | #1 |
Rep 144
Checking Oil Using Centre Gauge
Apologies for such a stupid question.. but I think i'm losing my mind (or going blind) and just want to get a sanity check before I make an appointment with the psychiatrist..... I've gone through the manual to figure out how to check oil using idrive and using the centre console (ie. display between the gauges). Seems simple enough. The weirdest thing though is when I scroll through the different pages on the centre console, there is no display showing the oil symbol!!!?!! WTF? I get the interior light display, check control, set time, set date and service info... but that's it? no oil check!!!! Is there some secret password i have to utter as I scroll through the pages or is my car just broke azz? Tks.
05-07-2010, 11:34 AM | #2 |
Rep 4,144
It sounds like your using the little wheel thingy on the stalk. Scroll through the menu using the push button at the end of the blinker stalk.
Cheers.
2017 F80 YMB.
05-07-2010, 01:29 PM | #3 |
Rep 144
Oh damn, are you serious? Yeah i was using the wheel thingy to scroll. Thought that's what the manual said. will definitely try scrolling using the button. Tks!!!!
05-07-2010, 10:08 PM | #4 |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
Shits is, once you find it, it only gives you a rough idea and takes forever to update when you add oil.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
05-07-2010, 10:23 PM | #5 |
Rep 144
Tks for the tip ersin! In the manual it seems to suggest that you scroll with the the up/down tabs to a screen with the oil symbol.. tried the button scrolling as you suggested and it worked (weird thing is there is no oil symbol.. just the meter). Anyway, finally got to that screen, held the button down and it reset!.... greg, you aren't kidding.. it takes for ever to reset!! all done though. tks again guys!..... btw, already down a notch and i'm only at 1,300kms!!!
05-15-2010, 05:33 PM | #6 |
Rep 144
Hi guys, sort of a related question.
got my first service today, but my oil level hasn't changed. It was down by half before i took it in and after the oil change, and repeated cycles it hasn't moved... i recall reading on another post that it takes a while for the computer to register after an oil change.. but i can't find that post. Any thoughts? I'm going to wait a couple of days to see if it registers the full oil. p.s. i read the service invoice and it showed 9 quarts of engine oil added, so it has to be full..... |
05-15-2010, 10:36 PM | #7 | |
Commander-In-Chief
2122
Rep 8,924
05-16-2010, 12:16 AM | #8 |
Moderator
673
Rep 4,737
The oil gauge is just a PIA.
So I was told to add 1 qt. Added 1/2 qt. and gauge recognized during first cycle. Next cycle, the added oil disappears! I was told to add another 1 qt. So I added another 1/4 qt., and the gauge didn't even move up a tick. After resetting the gauge about 5-10 times the gauge finally registered the 3/4 qt. that I've added... I thought I was leaking oil for a moment |
05-16-2010, 01:44 AM | #9 |
Rep 5,012
If it hasn't changed, it's at the same level it was before. Once you drive the car enough to show a reading (10 miles or so, depending on ambient temperature), doing a proper 'reset' will yield repeatable results (within the system's accuracy, of course). We're talking oil not molasses . Remember the time to do a 'reset' is with oil at full operating temperature; it takes less than a minute on my car. Take care.
05-16-2010, 07:03 PM | #10 |
Rep 144
Tks guys.
Finally registered the full oil just now. It's weird as it took a full day and multiple resets (on flat surface at operating temp) before the gauge actually registered that I had changed the oil and had a full 9 quarts. It is now showing max, which is a relief as I was getting rather OCD with that oil gauge hahahah. I can now relax and enjoy the ///m post break-in!!!! |
