12-20-2019, 10:43 AM | #1 |
Rep 6
Voltage issue on E92 M3
So about a month ago, i started my car to be greeted by the lovely "increased battery discharge" warning, proceeded to let the car sit for a while and warm up. When i turned it off and the started it again, warning went away. Didn't really think anything of it. About a week later, it did it again, and then multiple other warnings came up (ABS, DSC, and many others) and then it killed itself at a stoplight. I hadn't replaced the battery since i purchased the car a little over a year ago, so i went ahead and did that and coded it through Carly. Everything has been running fairly good, except for the fact that when i monitor the voltage on the in dash tool, it will start off reading 11.8v and then once ive driven it a considerable amount, it will jump back up to around 13.5-14.5 V. I know that 13.5-14.5 is a very reasonable number, but should it take almost 30 minutes of driving to get to that point? Im also due for the positive battery cable recall, and am doing so next week. Just seeing if anyone else has had the same issue. If i let the car sit for even just a day, ill have weird issues like the headlights not coming on when i unlock the car and some instrument panels will clear themselves when i start the car. I feel like its alternator related, but then how could it eventually go back to normal voltage? Faulty Battery? I did pull codes and the 00278D "generator communication" code came up. Voltage regulator issue? IBS issue? Let me know your thoughts.
01-09-2020, 12:32 PM | #2 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
Did the battery cable recall fix the issue?
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
01-10-2020, 03:44 PM | #3 | |
Science stuff and stuff
395
Rep 414
Mdriv3r148.50 |
01-10-2020, 04:34 PM | #4 |
Rep 3,982
It helps if you search, a quick search of that error code turns up this very in depth thread another member created and what he did to solve the issue.
https://www.m3post.com/forums/showthread.php?t=1470613
01-23-2020, 02:01 AM | #5 | |
Rep 392
Drives: F13 M6
"I have an an alternator off of a 2008 e92 m3. Everything works on it when I took it off. Has about 100k miles on it. I would part with it for super cheap bc its just sitting in my garage now. I swapped mine out along with pulleys, valve cover seals etc... pm me if interested." |
01-23-2020, 05:02 AM | #7 | |
Rep 392
Drives: F13 M6
01-23-2020, 06:34 AM | #8 | |
Rep 6
01-24-2020, 07:17 PM | #9 | ||
Rep 392
Drives: F13 M6
Alternatively, I suggest just buying a new valeo 180amp alternator or you can check the autoparts stores for remanufactured ones. Those will be cheaper. Maybe a bit less than $200. The valeo will be $280ish from fcpeuro or ecstuning. Im not sure if its your alternator, but its a possibility. You'll just have to run scan codes. Consulting an indy shop might not be a bad idea. |
01-24-2020, 07:21 PM | #10 |
Rep 392
Drives: F13 M6
Also if you do it yourself, I suggest getting a belt wrench instead if using a box end wrench. You'll get more torque that way and it'll be much easier haha. After going super charged, I have found that to be a great tool.
01-24-2020, 10:38 PM | #11 | |
Rep 4,160
The good news is, after my last posting in that thread, my car has not given me any more issues. No errors, no increased batt discharge messages, voltage all normal. As far as my case is concerned, it appears that it is normal for the alt to undercharge the batt after registration. |
01-25-2020, 11:17 AM | #12 |
I got lei'd
844
Rep 7,593
Regarding the 1st post 00278D it’s the alternator
I had the same code ever since I bought my 2010 went away after replacing a refurbished unit from fcpeuro Drove like that for 2 years, car died twice, changed battery twice Also had the IBS and glove compartment recall for the wire done Haven’t had the code since |
ItsGary1457.50 |
