      09-29-2018, 03:21 PM   #1
99leeric
Drives: n/a
TPMS issue on E92 M3 2013
Hello all!
I've watch countless videos, read tons of posts and also read my manual 10 times and for some odd reason i can't figure out the simplest thing that should technically be brainless.
I have a 2013 E92 M3 without iDrive.
I have the red tire pressure light. I've pumped back the pressure in the tire and I can't seem to reset it.
I use my stalk on the right side and cycle through the options. I don't see the red tire pressure light unless i go into check control.
When it does show up as i cycle through the stalk, I for the love of God do not see the RESET option.
I simply don't get an option to reset.
I'd greatly appreciate any help! this is so frustrating.
Thank you
      09-29-2018, 05:43 PM   #2
M3SCUZZI
M3SCUZZI's Avatar
Drives: e92 m3
Hopefully this works for you or try holding button on side of stalk down when you reach TPMS for 5 seconds
      09-29-2018, 06:53 PM   #3
99leeric
Drives: n/a
Thanks for sending the video over.
When I hover to the red tire warning light I dont see the reset option - it's just empty on the bottom.
Also, I'm using the same OEM tires.
I can't understand why I don't see a reset option.
I keep reading videos of people saying make sure the vehicle is turned on but idle and that it is in park. I drive a 6 speed so i have my foot on the brake. Not sure if this affects it. I also took off the hand brake
      10-01-2018, 02:17 PM   #4
99leeric
Drives: n/a
figured it out.
      12-30-2019, 01:26 AM   #5
Mralan007
Drives: 2008 e92 M3, 2007 e92 320d
Originally Posted by 99leeric View Post
figured it out.
Im having the same problem with my car, below the red symbol it’s totally greyed out. All tyres are at the correct pressure, what did you do to solve it? Thanks in advance
      12-30-2019, 06:00 AM   #6
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
LCI cars should have a button below the hazard lights for this.
G-Power Supercharged
      12-30-2019, 12:49 PM   #7
Mralan007
Mine is pre lci, the process is usually flick through the stalk till you find check then hold the bc button for 5 secs over the reset option. This time though the reset option is greyed out, all tyres correct pressure and Ive tried driving it off with no luck 🤔 its been almost 2 weeks of consistent red symbol😩
