      10-03-2013, 03:28 PM   #1
crash32
Going to put car on lift.... here to place lift???
I am going to install my Meisterschaft GT2 exhaust on the car this weekend and have access to a lift. Is there a preferred place on the chassis or bottom of car to place the lift pads on?
I am concerned that I will place the pads on the wrong area and do undercarriage or even worse... body damage to the vehicle.
On many cars, you can see the frame, but I looked under the car and it does not seem as if I can see exactly where the frame is which concerns me that I will place the lift pads on the wrong part of the car.
Someone please help!!!!
      10-03-2013, 04:17 PM   #2
edwinm3
edwinm3's Avatar
Drives: F82
Car has 4 plastic jacking points/pads underneath, only place it should be jacked from. Located front and rear along the sides
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
      10-03-2013, 04:20 PM   #3
edwinm3
edwinm3's Avatar
Drives: F82
This is what they look like
Coyote 5.0 F-150
991 GT3
      10-03-2013, 05:33 PM   #4
Villanofun
Drives: 2008 E92 ///M3
Dumb question: what about the rear differential?
      10-03-2013, 06:12 PM   #5
BMW Fanatic
Drives: slow
What about it?
      10-03-2013, 06:26 PM   #6
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
I'd be very careful about lifting from the rear diff. The fins on the diff cooler are thin and delicate. If you do lift from the diff, find a hard point and be sure not to touch the cooler with your jack.
Auto Detailing Enthusiast!
      10-03-2013, 06:31 PM   #7
crash32
Edwin... those pics help a ton. Thanks!
      10-03-2013, 06:53 PM   #8
edwinm3
edwinm3's Avatar
Drives: F82
Anytime
Coyote 5.0 F-150
991 GT3
      10-03-2013, 06:55 PM   #9
edwinm3
edwinm3's Avatar
Drives: F82
I would not use the diff as a jacking point, you're risking hurting the diff or hurting the diff mounts
Coyote 5.0 F-150
991 GT3
      10-26-2013, 09:07 PM   #10
stylelab
Drives: M3 ZCP '11
If I want to lift the rear or front of the car in order to put it on axle stands, where do I place the jack?
For winter storage, I want to lift all 4 corners of the car slightly and to do so I need to jack the car up to put 4 axle stands at each corner. I was thinking of using the 4 jackpad adapters as shown on the pics in the post above to set the axle stands. But in order to do so I need to lift the front of the car positioning the jack in the middle of the car (and then do the same thing at the rear)....Not sure where to set the jack. Any ideas?
      08-13-2018, 03:38 PM   #11
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
2 or 3 of my jack point jackpad things are DESTROYED
they chunked off
but i just placed the jack under where the destroyed jack pads are and lifted my car
should i replace the jackpads?
i think at this point i'm better off just leaving the destroyed jackpads alone since i had a flat surface for the jack to lift
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22
      08-13-2018, 08:30 PM   #12
roastbeef
roastbeef's Avatar
you can safely lift from the rear diff, just don't do it when swapping rear exhausts, it will be in the way.
if your jack pads look like the above pic, they are still fine to use.
      08-13-2018, 08:47 PM   #13
drrust
drrust's Avatar
336
Drives: E90 M3 DCT Sedan
they chunked off
It's a straight forward process to replace the pads. They aren't too pricey. Then either get some pad "pucks" or make your own from hockey pucks. There are several videos out there that go over the process. For jack stands I used some small blocks of wood to set minimize any further damage to them. When I replaced the pads I found some cheap pucks on eBay.
      08-14-2018, 02:03 AM   #14
MaximusB
Drives: 13 Frozen White E92
There is no need to lift the car up for winter storage. Modern car's suspensions are designed to take the weight of the car. I read somewhere before that you will actually do more harm than good by storing the car on jack stands and let the suspension dangle.
I store both my weekend cars for winter and I never put them on jack stands. Just inflate the tires before storage and place carpet under each tire. One of my car is 2001 and have been stored every winter that way, no issues till this day.
