      08-01-2018, 02:45 AM   #1
DerEisbaer
Germany
100
Drives: E92 M3 & VW Golf Mk2
Engine rumbles and stumbles in lower RPM
Hi Folks,
a few days ago I recognized, that my M3 would hesitate in 3rd gear and sputter slightly.
After an extensive Autobahn & backroad chase on Saturday, the rumbling and stumbling became very apparent between 2000-3000 revs.
A kind of misfire at cold & warm start joined the chorus. No warning lights or else. Filled up with 102 ROZ fuel during the night and returned back home.
I checked the codes yesterday and it gave me P0308 - misfire on cyl. 8.
Will now proceed to have the spark-plugs changed and coil pack checked.
Any other recommendations? Any good tutorials / DIYs for changing the spark plugs and coils (including torque specs etc.?)?
M3 is a 2008 with now roughly 93k kilometers on the clock (57k mls).
Give me some confidence - should be the spark/coil only, right?
Cheers,
Seb
      08-01-2018, 04:42 AM   #2
Helmsman
Helmsman's Avatar
Sweden
4465
Drives: 2011 AW E90 M3 ZCP
The searcher will find - try the DYI section and you'll find what you need to change plugs for sure.
      08-01-2018, 08:50 AM   #3
DerEisbaer
Germany
100
Thanks Helmsman - too nervous.
The Tutorial for the spark-plugs here in the DIY section was indeed very helpful already.
I will have a specialist look at it on Saturday as well, will let you all know the outcome. An inspection would be due soon, so we gonna prepone the same, fix the leaking diff, change the DCT transmission oil. Might even be the spark-plug(s) only, not really sure, when they were last changed.
      08-01-2018, 09:38 AM   #4
Mvy
Drives: 2008 E93 M3
Consider Idle control valve if the plug change doesnt solve this. Check for codes.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive...
      08-01-2018, 10:49 AM   #5
DerEisbaer
Germany
100
Thanks Mvy - will have to deep dive into diagnostics, but regular code reader just came back with P0308.
First car with such a sophisticated engine, I'm for sure overreacting with all my nervousness
      08-03-2018, 04:15 AM   #6
Helmsman
Helmsman's Avatar
Sweden
4465
Try this code list out mate. P0308 is suggested to be misfire on cyl 8.
http://wiki.rcollins.org/core/index....),_ECU_(MSS-60)
DrFerry6728.50
      08-07-2018, 06:30 AM   #7
DerEisbaer
Germany
100
Thanks.
Had found the full list of codes already, and torque gave me the same feedback - misfire on cylinder 8.
Dropped the car at the shop on Saturday. First tests will be coil pack and spark plugs. Could have done the work at home as well, however the DCT is slighlty leaking and so is the diff, the service is due shortly and hence I decided to just get it all done. Will keep you posted.
      08-07-2018, 07:57 AM   #8
Helmsman
Helmsman's Avatar
Sweden
4465
Thanks.
Okidoki, sounds good. Better stay in contact with the dealer before they start do the DCT. Depending on where it leaks (can be at least 3 different locations) it can end up being quite costly and you may want to reconsider depending on the amount (most boxes seems to leak some and if small may not be worth while to correct).
      08-08-2018, 03:21 AM   #9
DerEisbaer
Germany
100
Thanks.
At this stage, we are doing the most obvious leak at the pan only - including fluid flush & change.
Basically decided to just do all at once and get back to driving asap
      08-13-2018, 03:29 AM   #10
DerEisbaer
Germany
100
Picked up the car on Friday, all well.
Issue was the coil-pack on cylinder 8, switched them onto cyl 5 - and the issue shifted as well. Had it changed for a new OEM BMW one. Car feels a lot stronger now, seems the system was pulling timing out, after the error was detected first.
Flushing the DCT and replacing the filters had a crazy impact, even at the low mileage I am at.
      08-13-2018, 02:51 PM   #11
Helmsman
Helmsman's Avatar
Sweden
4465
Good stuff!
      08-13-2018, 03:20 PM   #12
wyatth
Drives: E90 ZCP
The other 7 probably aren’t far behind. I typically swap coils all together, just like bulbs or plugs or tires.
      08-14-2018, 02:45 AM   #13
DerEisbaer
Germany
100
Generally, I would agree, I change tires per axle and spark plugs altogether as well - but with coils, I'm a little bit hesitant as these are not a regular wear&tear item.
Will keep an eye on it - now that I have the code reader stored in the car itself it's easy to check and monitor regularly.
      08-17-2018, 11:26 AM   #14
Lambro
Lambro's Avatar
29
Drives: 2008 M3 Sedan
anytime you get a misfire on one cylinder always switch the coil pack to another cylinder. Easiest way to find a bad coil.
