01-05-2018, 09:37 PM | #1 |
Rep 6,914
HydroSilex Recharge a Game Changer? Will your Last Step Ever Be the Same?
HydroSilex Recharge
Click here for your chance to Win a Bottle of HydroSilex Recharge We received the HydroSilex Recharge a little while ago and all I can say is it's incredible! If you are looking for a super easy and quick way to get your car protected this is what I feel is the best way to do it. It's hard to compare this to anything out there because it's so versatile. It's a hybrid of sorts, it's as easy to use as a detail spray but has the traits and strengths of products like Reload, Brilliant Shine, Polymer Net Shield, Cure, Wet Coat, Wash Coat, SiFinish, and many others. What's funny is where most other manufacturers have two products or even three, HydroSilex Recharge has condensed the two or three into 1 product! The HydroSilex Recharge will save you time and provide results. Now if you love waxing your car or pulling out your orbital polisher to lay down your favorite sealant or wax, this is not the product for you. Where we see this product:
What the manufacturer says: HydroSilex is the first “professional” coating that doesn’t need a professional to do the install. The simplicity of the installation makes HydroSilex into the perfect coating for the DIY. Once applied HydroSilex cures into a durable transparent ceramic layer on top of the substrate. The new top layer adds shine and protects the substrate from getting in contact with contaminants, UV, minor scratches and other harmful chemicals. HYDROSILEX Recharge - As a maintanence Spray Ceramic coatings will not perform as promised unless they are cared for. HydroSilex is the perfect product for your already installed proffesional coating. Let's get all the questions out of the way, these were some of the questions th came to mind when we were testing the product out....... IS THIS THE SAME AS AN ACTUAL COATING? Recharge is engineered to be used as both a maintenance coating for traditional coated surfaces or as a stand-alone protection. It works with any coating brand to help maintain gloss, self-cleaning, UV protection and slick surface feel. As a stand-alone, it also provides those features. WHAT DOES HYDROSILEX RECHARGE PROTECT AGAINST? HydroSilex Recharge creates an extremely slick surface which serves as a repellent from environmental contaminants, while providing UV protection against fading. IS HYDROSILEX RECHARGE RESISTANT TO SCRATCHES? HydroSilex Recharge is a ceramic-based coating, it is not designed to resist scratches like a conventional glass coating. WHAT CAN IT BE USED ON? HydroSilex Recharge can be used on virtually any surface. It can be applied to bare metal, stainless steel, aluminum, glass, plastic, wood, fiberglass, stone, marble tiles, automotive paint, gel coats and more. HOW IS IT APPLIED? HydroSilex Recharge is extremely easy to use! It's as easy as spray on and wipe/rinse off. Unlike other maintenance coatings that only have one method of application. HydroSilex Recharge can be applied numerous ways. It can be applied using both wet and dry methods. Refer to our "How to Install" section for instructions on each method of application. CAN HYDROSILEX RECHARGE BE APPLIED USING A FOAM CANNON? Yes, it can be applied using the recommended mixing ratio for application with a foam cannon. Mix 1 ounce of Recharge in a typical 32oz foam cannon bottle, with water. For a heavier application, simply pour Recharge into the foam cannon bottle, then apply. Pour any unused product back into Recharge bottle when finished. DOES HYDROSILEX RECHARGE GIVE HYDROPHOBIC PROPERTIES AND SELF-CLEANING EFFECT? By design, HydroSilex Recharge gives instant hydrophobic effect upon contact. Because it is engineered to be applied wet, the surface can be exposed to water immediately. Yes, HydroSilex Recharge creates a slick surface that is extremely hydrophobic and thus creating a self-cleaning surface that requires less maintenance. HOW LONG DOES IT LAST? HydroSilex Recharge can last from 6 to 8 months, but will last indefinitely longer if used routinely as it was designed. The product is designed to be layered, so the more often it is used, the longer the durability and effect. DOES IT PROTECT SURFACES FROM OXIDATION AND FADING? Yes, HydroSilex provides protection against oxidation and fading from UV exposure. CAN I USE RECHARGE ON A CLEAR BRA? Yes, HydroSilex Recharge is great for use on Paint Protection Film as those products do not have built in protection against UV exposure. It will help keep those surfaces easy to clean by creating a slick barrier, without the common build up by waxes and sealants on the edges of the film. This BMW M2 was Recharged - the full front has a clear bar on it. Installation is as easy as it can possibly get, here is what HydroSilex wants us to use the product. My favorite way to apply the product is probably going to be dry, for some reason my head is telling me that it will be the best way to get the most out of the product (in the sense of durability), without diluting it like on a wet application via drying the vehicle or installing it via a foam cannon or foam gun. So that being said my thinking is for the 1st application go dry and for maintenance with HydroSilex use it in a foam cannon, foam gun, or as a drying agent, either way imagine that while you are drying the car you are adding that slick feel to it as well as giving your car protection 1-8 months worth! Dry Application
*****Always use clean towels. Microfiber towels are recommended.***** Wet Application
Foam Cannon Application
Water Beading is on point, HydroSilex Recharge was used over this coated BMW M3, in this case Recharge was used to boost the current coating. Some of the microfibers we have used with the HydroSilex Recharge with great results: The Rag Company Drago The Rag Company Pluffe The Rag Company Eagle Edgeless Uber Classic Uber Quick Detail Uber All Purpose Adam's Great White Uber Super Drying |
01-06-2018, 06:03 PM | #2 |
Retired Curmudgeon
2981
Rep 4,046
Coatings keep evolving for the better! This has my name all over it once I use all the other products up that I have ready for spring!
I remember the days of putting Zymöl carbon on the car. Shine lasted about the same amount of time as the installation process... This is a much, much better option, though Zymöl smelled so good.
03-29-2018, 12:45 PM | #4 |
Rep 1,198
Drives: 2021 F87 M2c. LBB, 6mt
I was thinking about getting this, but have you seen the online reviews? They are anything but stellar.
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
03-29-2018, 01:21 PM | #5 |
Rep 6,914
I believe there is one review out there that isn't all that great, I believe in the product if that counts LOL
We have used a lot of it in the shop prior to launch. I believe it's a great product, I also believe there are a lot of folks not drying the car down completely. it will streak, haze, if it's not wiped down properly. Phil |
03-29-2018, 02:46 PM | #6 |
Rep 1,198
Thanks Phil,
Since this initial post, do you feel the dry application has been best? One of the reviews I saw the guy applied it to his SUV wet and he claims it left streaks and cloudy areas that were a pain to cure. I will probably give this product a shot. I appreciate your replies and post.
03-29-2018, 04:46 PM | #8 |
Rep 1,198
How do you like it? I think 1.5 months is a pretty reasonable amount of time for a spray on. Is it as easy to apply as they make it sound? Dis you apply is using the dry or wet method?
03-30-2018, 08:23 AM | #9 | |
Rep 1,930
With that being said, I used the dry method. It's easy to apply but you must make sure you do a good wipe down. I did a wash, clay, Gtechniq panel wipe down to clean any residue, then used like half a 16oz bottle for 1 application. |
03-30-2018, 10:29 AM | #10 | |
Member
11
Rep 267
From my use, we have determined that using the product as a dry wipe on wipe off application worked much better and used very minimal product in comparison to spraying on while the car is wet. We tried the product in many different scenarios (wet, dry, indoors and outdoors) and have come across the streaking/staining spots that many have seen when applying wet. From our experience working with Hydro2 and other similar spray on silica sealant products, the streaking is caused by over saturating the surface and not properly rinsing the product off. If you are flooding the car with water after it is ideal to work on top surfaces first to make sure the product is spread downwards instead of onto an area that is already hit with the product. Do not use in direct sunlight and do not let the product sit on the surface for an extended period of time. Flush extremely well and work in small areas of the car. Don't try to do the entire side of the car in one shot. Overall, the product has worked extremely well and has been quite durable when used properly. A lot of the durability also has to do with amount of maintenance of the vehicle, prep as well as climate. Here in Miami, the weather is extremely brutal so I don't expect it to last 6 months, but for the ease of application and time it takes we can apply it in the same amount of time as a quick detailer would. We have gotten well over 10 cars on a single 16oz bottle using it dry and have plenty of product left making a very effective item for the price. Its a great product and would highly recommend to have in your arsenal whether a professional like myself or a DIY
04 M3 Jet Balck/ Imola
AA Gen 8 Level 2 | AA Headers | Bimmerworld Race Exhaust and Diffuser | Bilstein PSS | Volk Te37 SL | Sparta Evolution BBK | Vorsteiner | Modesta 08 E90 M3 Alpine White/ Fox Red AA Level 2 | Full AA Exhaust | BBS FI-R | KW V3CS |
03-30-2018, 03:42 PM | #11 |
Rep 1,198
Awesome, thanks so much for the replies! I am going to order a bottle and give it a shot.
03-30-2018, 03:58 PM | #12 | |
Stop the hate, get a V8
3848
Rep 8,625
I never trust any sort of "lasts for X" claims for detailing products. Those are always in some impossible ideal scenario, e.g. brand new car that sits in a bubble and never gets exposed to direct sunlight, humidity, etc. Even the shop that did my C.quartz alluded to that, saying YMMV based on how, when, and where you use the car. Year-round use in a climate that sees snow/ice/salt as well as hot summers will drastically shorten the life versus a car that's only driven in moderate temperatures and garaged 99% of the time. So when you say 1.5 months, what is your specific use case? -where/when do you park it -temperature range -exposure to salt, dirt, other pollutants -status of your paint prior to application -how often/how thoroughly do you wash it -etc
Past: 2011.5 M3 sedan ZCP |
03-31-2018, 05:30 AM | #13 |
Rep 6,914
03-31-2018, 05:31 AM | #14 | |
Rep 6,914
04-02-2018, 05:58 AM | #15 |
Rep 2,442
Drives: 2022 M3 6MT
Can this be used with the AMMO paint regiment? Thinking of using this as a final step after Skin is applied.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
04-02-2018, 08:31 AM | #16 | |
Rep 1,930
Yea I usually take those claims with a grain of salt -indoor heated garage -well its in the 40's now -no salt but dust build up is norm -no swirls, paint is excellent. Did a clay application before applying. -wash every 2 week |
