11-20-2014, 09:27 PM | #2 |
Rep 701
Best gauge I have ever used. Remains accurate even if dropped.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 |
11-20-2014, 10:34 PM | #3 | |
Rep 70
You can get it at Sears/Kmart for $9.00. Check dealnews.com. Although I wish I had similar with a bleeder valve... |
11-20-2014, 10:56 PM | #4 |
Rep 6,735
'23 X7
11-20-2014, 10:58 PM | #5 | |
Rep 701
11-20-2014, 11:00 PM | #6 |
Rep 701
11-20-2014, 11:06 PM | #7 |
Rep 6,735
The intercomp allows you to hold the large, easy to read, gauge pointed towards you while you use your thumb to press the bleed valve to release air / adjust the tire pressure. The accutire is definitely in a different league but not a better one. It's a $10 product that is sized to throw in your glove box.
'23 X7
11-20-2014, 11:17 PM | #8 |
Rep 837
Am I reading that correct, the Accutire max out the readings at 28.5 psi??! I'm running oem tires so I need a guage that goes at least 36 psi
11-20-2014, 11:22 PM | #9 |
Rep 701
11-20-2014, 11:23 PM | #10 | |
Rep 701
11-20-2014, 11:26 PM | #11 |
Rep 6,735
When the OP asked for a "good quality tire pressure gauge" I assumed that he was taking the time to post in this forum because he wanted "quality". If the OP would have asked for a "decent, plastic pressure gauge, that I can throw in my glove box with a max budget of $10" then I would have suggested something different...
'23 X7
11-20-2014, 11:32 PM | #12 | |
Rep 701
Your gauge is cool because it allows you to quickly tweak pressure. Its definitely a more substantial gauge. |
11-20-2014, 11:41 PM | #13 | |
Rep 6,735
'23 X7
11-21-2014, 02:21 AM | #14 |
Rep 837
Ok gents, I've reviewed both recommendations and they have their plus and minuses. I don't mind the extra dollar for something that last longer, reliable and accurate. Think I'll get the Intercomp.
Thanks guys, much appreciated! 😊 |
11-21-2014, 05:55 AM | #15 |
Rep 11,065
Accuracy is usually best in the middle range of the gauge, so if you run 30-40 psi, buy a 60 psi gauge not a 100 psi gauge. There are a bunch of good ones, Accutire, Intercomp, Longacre and others. Probably the liquid filled are best, but cost more. My old Accutire disappeared this year at the dragstrip. I replaced it with a $20 Joe's Garage gauge.
11-21-2014, 06:48 AM | #16 | |
Rep 969
Sold 2011.5 E92 M3 ZCP.
11-21-2014, 01:23 PM | #18 | |
M3Post Supporting Vendor
89
Rep 964
We sell a pretty good mix of different gauges, but this one is the one I use myself.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
11-22-2014, 02:52 PM | #19 |
Rep 3,633
11-22-2014, 04:02 PM | #20 |
Rep 701
http://www.caranddriver.com/features...-gauges-tested
Can't go wrong with any of the gauges listed in this thread. They are all listed in C&D's list. |
11-23-2014, 08:32 PM | #21 |
Rep 486
accu-gage makes good reasonably priced gauges.i have had a basic one for over 20 years,and more recently got this one that works with your compressor-
http://www.ghmeiser.com/ez-air-series.htm |
11-23-2014, 10:01 PM | #22 |
Rep 1,122
