      02-18-2015, 01:00 PM   #1
BrewRifle
BrewRifle's Avatar
Drives: 2011 MCB E92 M3
2011 BMW M3  [7.56]
2013 BMW X3 35i  [0.00]
2009 BMW 135i  [8.00]
ESS Supercharger O2 Readiness for State Inspection
So I'm trying to get my car inspected with an ESS VT2-625 kit and the the O2 sensors are listing as not ready. I'm on stock cats so there isn't any CEL. They are not failing, just not set to ready. The O2 sensors are not throwing any codes as well so it has to be software related.
Has anyone ever run into this with the supercharger software or is there a particular file that I need to load?
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
      02-18-2015, 01:32 PM   #2
Patrón
PAZUZU
Patrón's Avatar
Drives: '15 M4
2015 BMW M4  [0.00]
2009 BMW M3  [10.00]
Drive down to San Antonio
2009 M3 DCT ESS625+ SOLD
2015 M4 BSM/Silverstone F4LCON
@texasMclub IG @jagemoets
      02-18-2015, 02:06 PM   #3
BrewRifle
BrewRifle's Avatar
2011 BMW M3  [7.56]
Can't, it has to be done in the county the car is registered in.
      02-18-2015, 02:19 PM   #4
kawasaki00
kawasaki00's Avatar
Drives: SG-E92 ESS-650 BPM Tune
PM Sent
Electronics Junkie, Engine Builder.
      02-18-2015, 02:51 PM   #5
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
This happens because ESS uses the same file for catted and catless cars. Contact them to see if they can give you the proper file for your setup.
      02-18-2015, 02:56 PM   #6
IMG's Avatar
Drives: E36 M3 Track car,Ess E90 M3 DD
Easy fix. Shoot Roman@Ess an email !
      02-18-2015, 03:00 PM   #7
sales@ESSTuning
sales@ESSTuning's Avatar
391
Drives: ESS M3 / M4
You need our supercharger emissions file as the standard file will not set 02 readiness. Email software@esstuning.com and AJ can supply you with the emissions file and instructions on how to use it. You can also email me anytime if you have questions Roman@esstuning.com .
      02-18-2015, 03:15 PM   #8
BrewRifle
BrewRifle's Avatar
2011 BMW M3  [7.56]
Thanks, Roman. I sent AJ an email. I had called you earlier today to discuss this very issue, but it went to voicemail. Anyways, it sounds like a quick fix.
      02-18-2015, 05:55 PM   #9
801M3
801M3's Avatar
16
Drives: 2012 M3
Good info!
Thanks!
-2012 E92 M3 ZCP 6MT AP-
ESS VT2-625, ESS full exhaust, ESS Tune, HRE FF01, Vorsteiner carbon
      02-18-2015, 06:31 PM   #10
imstimpy
Drives: 2010 M3
I'm experiencing a similar issue, but I'm using Evolve software. I've asked to have all cat/O2 systems re-enabled, since they also use a canned tune for catted or catless cars. I'm approximately 200 miles after the flash and still haven't had the cat or O2 sensor flip to READY.
Once your calibration has all systems enabled, you also need to fit your driving into a couple drive cycles:
http://www.europeantransmissions.com...0Procedure.pdf
      02-19-2015, 05:07 PM   #11
BobS
BobS's Avatar
97
Drives: M3
They should be able to do the same thing ESS does. Make sure you follow the drive cycle a couple times and have the stock xpipe back on the car.
ESS 650 ACM-R Upgrades
      02-20-2015, 07:48 AM   #12
imstimpy
Drives: 2010 M3
You'd think, right? I'm 230 miles and two full drive cycles in. I'm still sitting on NOT READY for the Catalyst and O2 Sensor with factory cats in place (and have always in place).
      02-20-2015, 06:13 PM   #13
BobS
BobS's Avatar
97
Drives: M3
You're factory cats have always been installed all along?
      02-21-2015, 07:19 AM   #14
imstimpy
Drives: 2010 M3
Absolutely! I disagree with removing cats on a street car.
      02-21-2015, 07:25 AM   #15
BobS
BobS's Avatar
97
Drives: M3
Ok well then i'm confused. If you have the stock xpipe on with stock cats, why are you doing drive cycles? The evolve tune should already allow readiness. Sounds like you need to contact evolve.
The key is to have the STOCK cats/xpipe installed while running a tune that allows the O2's to go ready. Aftermarket catted xpipe's generally don't work.
      02-22-2015, 07:34 AM   #16
imstimpy
Drives: 2010 M3
Why am I doing drive cycles? Frankly, because Evolve is unable to provide the calibration I've asked for. I've been in constant contact with Evolve for over three months now for various reasons. They have been attempting to provide an emissions compliant calibration now for nearly one and a half months (with no success, I might add).
Theoretically, yes, if you have an emissions compliant tune and factory cats you should be capable of passing I/M Readiness after 1-2 drive cycles. In my experience on my S2000, that happens easily in 80-110 miles.
I was contributing to this thread initially to provide the drive cycle details, which I've been going through multiple times per calibration. But since you asked, I'll tell you that I'm also dealing with this because the two calibrators at Evolve I've dealt with so far are complete imbeciles.
      02-22-2015, 08:15 AM   #17
BobS
BobS's Avatar
97
Drives: M3
Well i know of two supercharged evolve cars that passed emissions so i'm sure it can be done with just a NA tune. I'm actually trying to get it done now so I feel your pain. My car is at ACM at the moment getting some things done then i'm going to try and pass. From what i heard from those two guys, you need to do the drive cycle perfectly and have the stock xpipe/cats on the car.
      02-25-2015, 10:23 AM   #18
imstimpy
Drives: 2010 M3
My "tuner" is now blaming my O2 sensors. There are no thrown or pending DTCs yet both Catalyst and O2 Sensor are both NOT READY.
      02-25-2015, 11:42 AM   #19
regular guy
Drives: Sprint car
When you start your car, does the check engine light come on shortly before going off? If not (if it never comes on), then your entire engine warning systems have been disabled and that would explain why you don't see any codes. Please check this.
      02-26-2015, 09:57 AM   #20
imstimpy
Drives: 2010 M3
You hit the nail on the head. No Check Engine light any longer. Regardless of the readiness states, a car cannot pass emissions if the Check Engine light does not illuminate upon startup.
      02-26-2015, 10:28 AM   #21
BrewRifle
BrewRifle's Avatar
2011 BMW M3  [7.56]
I just checked mine after getting another tune and my CEL shows up for a brief second while cranking the car over.
      02-26-2015, 11:10 AM   #22
whats77inaname
Drives: when at all possible
In Texas, you're allow to have 1 of the 3 sensors show as "Not ready" and still pass. I've done it the past 2 years as I was battling some Procede issues that repeatedly triggered the "Increased Emissions!" warning. I reset the OBDII readiness (disconnected the battery for a bit) completed the drive cycle up to the point where the 02 sensors were shown as "Not ready", took the car in, and passed. I can scan a copy of the pass cert. if you'd like.
Is there any reason outside of principle that you can't remove the tune, go through the drive cycle and pass, and then re-install the tune?
