12-20-2021, 07:42 PM | #2 |
Rep 234
I've never used bimmercode, but here are the parameters I changed using NCS Expert.
These were in the NFRM ECU: PWM_SL_V = wert_04 PWM_SL_V_BEI_AKTIVEN_AL = wert_04 PWM_SL_V_BEI_AKTIVEN_FL = wert_04 TAGFAHRLICHT_ECE_0 = nicht_aktiv PO_RL_FKT_MIT_SL_V = nicht_aktiv |
12-20-2021, 09:18 PM | #3 | |
Rep 436
Arsenal F.C. - Gooner 4 Life
12-21-2021, 06:57 PM | #4 |
Rep 80
New to my E92 so forgive the newb question. I assume this bulb is separate from the turn signal bulb, as one would want that bulb to operate.
On my car, I don't believe I have this what looks to be smaller right up inside the corner. Maybe mine is already coded out or the bulb is removed. |
12-21-2021, 07:06 PM | #5 | |
Rep 21
