02-16-2018, 07:32 AM | #1 |
Rep 1,230
Advice on adjustable sway bar end links
I'm looking to fix a problem Im currently having with the front end links on my car. Not long ago I 'upgraded' to the dinan adjustable sway bar. My mechanic used the supplied Dinan front end links. I'm not sure why but I was informed that they're too long. Having reached out to Dinan every single day for the passed 3 weeks with pictures and other information they have become unresponsive. Which marks the last time I'll buy one of their products but that's another story. My question is what end links will work with the Dinan sway bar and Ohlins R&T coils which are set at the recommended height? I'm considering the Turner ones or the Fall line. Thanks
02-16-2018, 10:28 AM | #2 |
Rep 6,734
Do you know what length you need? What spacing you need from the sway bar, shock mount, and threaded shaft length for each? If so I can tell you if the fall-line links fit. I have fall line links now but I need something custom to fit all of my Eibach sway bar adjustment points. I ended up having SPL make something for me. I'll have my fall line end link available for sale once the replacement arrives.
'23 X7
02-16-2018, 11:29 AM | #3 |
Rep 1,230
I don't know the exact length which is the problem. I'm trying to get this information without having to bring my car in and put it on a lift to measure everything. I'm also asking because I want to find somebody who has a proven set up. Stock EL are 12.99" - 13.58" 330mm-345mm. To my knowledge the Ohlins drops the car anywhere from 30-50mm. Which would make it tricky to pick the correct one on Turner
Website because its only a 15mm threshold (about 9/16") |
02-16-2018, 11:35 AM | #4 |
Rep 11,667
It has nothing to do with ride height/drop/elevation.
The length depends on the type of coilover. Each mfg. locates the mounting tab in a slightly different way. Measuring is really the way to be sure. Assuming the coilovers are installed.... Its easy to do, just remove a front wheel measure between the two points. (with the bar in aprox. correct position.)
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 02-16-2018 at 11:42 AM.. |
02-16-2018, 01:12 PM | #5 | |
Rep 1,230
02-16-2018, 02:37 PM | #6 | |
Rep 6,734
'23 X7
02-16-2018, 02:40 PM | #7 |
Rep 6,734
Technically you want the sway bar length to be measured with the tires resting on the ground (or a stand or ramp). The sway bar is not supposed to be under load when the car is static. The end link should slide into place with the car on the ground. Jacking up the car and removing one tire will result in some twisting force and make measuring difficult, if not impossible. The best way to do it at home is putting the car on ramps that are tall enough to allow you to crawl under the car to measure.
'23 X7
02-16-2018, 03:07 PM | #8 |
Rep 11,667
^ this....
I should have added, with wheel off you need to jack it into correct height position.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
02-21-2018, 08:27 AM | #9 |
Rep 8,075
Drives: 11 E90 M3 Individual
Just use the OE links. I have them on my older version Dinan bar. Unless the new bar locates the ends of the sway bar in a different location.
On a different note, a sway bar is a mostly useless mod on this car. I'd go back to stock if I had one.
2018 F30 320iX Melbourne Red
08-06-2019, 01:53 AM | #10 |
Rep 1,401
Drives: 06' E46 M3 ZCP
Reviving this thread for a relevant issue.
My issue is slightly different as I'm running the stock ARB, but since installing the Ohlins I've noticed that although the Ohlins are great and handling is drastically improved, something isn’t right and I believe It’s with the endlinks. The suspension doesn't feel as tight and firm as it should. At slow speeds and often over speed bumps, it almost feels a little sloppy. I'm lower than the Ohlins recommended ride height, which I believe is causing the issue with the end links. I suspect the endlinks may be too long for it now, making them less effective. I wouldn't be surprised if the joints were compromised. This is all just speculation seeing as that I'm not a suspension expert. I'm looking to get adjustable endlinks to see how/if they help. Any recommendations on a manufacturer? Hotchkis appears to have stopped making theres for the E9x M3 chassis.
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell 03' E39 M5 | 100% Stock Last edited by simpleM3; 08-08-2019 at 04:08 PM.. |
08-06-2019, 11:09 PM | #11 |
Future Classic
263
Rep 995
FWIW, I am running the Fall-Line Motorsport sway bar end links front and rear. Similar to the issue that most are running into in this thread, I needed a shorter link to account for my KW Clubsport ride height. As a result, the E46 M3 length versions of the Fall-Line links were appropriate.
Largely, aftermarket manufacturers are selling them as "E46 M3" or "E9X M3", etc. because their lengths correspond to adjustment dictated by the OE range. Once you move outside that OE range, it becomes a matter of measurement and seeking out a solution accordingly. PM incoming!
FUTURE CLASSIC | | Follow Us on Instagram
Melbourne E90 M3 | Jet Black E46 M3 | Techno E36 M3 | 997.2 C2S | 958 Cayenne GTS |
E90325M475.00 |
12-15-2021, 04:39 PM | #12 | |
Rep 40
It's confusing because some people are saying that the 9"-10.5" front adjustable endlinks from bimmerworld will work but then these fall line E46 front adjustable endlinks have an adjustability range of 10"-11". I've inquired at Turner Motorsport and SPL and both have said they can't make custom length endlinks with an adjustability range of 9" to 10.5"... so what is the length that works with the KW clubsport really? SPL can make me a link that is 9.9" - 11" on bimmerworld they have the following ranges for their endlinks: E9X M3 w/ Stock Strut - 12 - 13.5 E9X M3 w/ MCS - 11 - 12.5 E82, E9X Non-M - 11 - 12.5 E46/Z4 (All) - 10 - 11.5 E30/E36 M3, MZ3 - 9 - 10.5 E36/Z3 - MCS Specific - 7 - 9.5 F2X/F3X - MCS-specific - 10 -11.5 Last edited by e9x_m3; 12-15-2021 at 04:45 PM.. Reason: Included more info |
12-17-2021, 07:44 PM | #13 | |
Rep 82
e9x_m384.50 |
