      08-19-2019, 06:53 PM   #1
sibhusz06
Drives: 2011 M3, 2012 X35I, 2007 911
Shift lights not coming on
So Ive read several posts on this but i purchased my 2011 e90 ZCP last year and for the first time had it in M mode with the shift lights enabled in the menu and revved up to 7k but saw no light activity.
The other thing is that I also have Alex's alpine engine and dct tune, with this tune, ive noticed the auto start feature is disabled, and that the shift logic setting always defaults to position 2 unlike the oem software which leaves it at the last user setting. I cant tell if the Alpine tune is causing this or something underlying.
Thanks for the help.
      08-19-2019, 06:58 PM   #2
ItsGary
ItsGary's Avatar
Drives: 2009 E90 M3
Go to Settings > M Drive > Shift Lights On
Alternatively if you're not in M Drive and want the lights still
Go to Settings > M Drive > Press Options > Select whatever
The second one I don't remember if you need to click on M Drive or just press options over top of it.
Anyways, GTS DCT starts with D2 always but remembers your manual shift settings so as soon as you hit the paddles whatever shift setting you had it to will be applied.
Auto Start/Stop is a feature a lot of people get coded out anyways but idk about that.
'09 335i Coupe - Alpine White/Black - SOLD
Dpc2u11486.00
      08-19-2019, 07:04 PM   #3
Dpc2u
Dpc2u's Avatar
Drives: E93 M3, E60 M5, F15 X5, E46
^ What he said.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus
ItsGary1457.00
      08-19-2019, 07:33 PM   #4
Drv4fun
Drives: '13 M3 (original owner)
So the lights do not correspond to the tackometer. Its just the yellow and red area of the tack. So yellow lights come on once the needle actually goes into yellow. Hope that makes sense.
Like 7800-8300 — does anyone know the actual rpm her light, probably 100 rpm starting at 7500 then three red?
