      05-06-2020, 12:16 AM   #1
Nuttyy
Drives: E93 m3
Car keeps on heating up
Usually my car stays around 180-100f driving normally, but these past few weeks, my car seems to overheat allt. Like it went over 210f mark and stays around 220f-230f while on a normal drive. What could this be? Checked my fluid level and it was max. I need help before i have tp make a decision to buy a csf radiator and oil cooler
      05-06-2020, 12:24 AM   #2
roastbeef
roastbeef's Avatar
is your undertray missing?
      05-06-2020, 02:55 AM   #3
Nuttyy
Drives: E93 m3
Yes lol
      05-06-2020, 03:00 AM   #4
roastbeef
roastbeef's Avatar
Originally Posted by Nuttyy View Post
Yes lol
thats your problem. fix that, this isn't a cooler problem.
      05-06-2020, 03:41 AM   #5
Nuttyy
Drives: E93 m3
Undertray means the cover under the oil pan?
      05-06-2020, 04:10 AM   #6
roastbeef
roastbeef's Avatar
Yes.
      05-06-2020, 11:27 AM   #7
Nuttyy
Drives: E93 m3
Yes.
Which thpe of coolant should i use? Im only running bmw coolant, no distilled water
      05-06-2020, 05:07 PM   #8
roastbeef
roastbeef's Avatar
Yes.
Oem is sufficient.
      05-06-2020, 05:14 PM   #9
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
Depending on which coolant you have the BMW fluid is normally full strength and needs to be diluted with distilled water. 50/50 is standard the mix to run.
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
      05-06-2020, 08:15 PM   #10
Nuttyy
Drives: E93 m3
Its just regular bmw coolant which runs me 25-30 bucks at bmw
      05-06-2020, 08:22 PM   #11
DRLane
DRLane's Avatar
2008 m3  [6.63]
Does it look like this?
      05-06-2020, 08:59 PM   #12
Drv4fun
Drives: '13 M3 (original owner)
Yes lol
I have one private message me.
      05-07-2020, 06:07 AM   #13
Nuttyy
Drives: E93 m3
Yes thats the one
      05-07-2020, 06:08 AM   #14
Nuttyy
Drives: E93 m3
I have one. Thank you!!
      05-07-2020, 08:55 AM   #15
DRLane
DRLane's Avatar
2008 m3  [6.63]
Yes thats the one
You need to dilute it with distilled water - It's not supposed to be straight coolant, and likely your overheating issue. Read the back of the bottle but roughly 50/50 coolant to water.
      05-07-2020, 09:59 AM   #16
Nuttyy
Drives: E93 m3
Thank you, so im gessing 1 and half gallon of bmw coolant and 1 and half gallon of distilled water? Do i still need to put back my undertray or nah
      05-07-2020, 10:23 AM   #17
DRLane
DRLane's Avatar
2008 m3  [6.63]
Yes - They're two different coolers. Coolant runs through the radiator. The under tray improves cooling to the oil cooler. The gauge on the dash is combination of the two. Might be worth taking this to an Indy mechanic and having him review everything with you. Assuming you're new to these cars. Take care of that engine and it'll take care of you. Enjoy mate!
      05-07-2020, 11:02 AM   #18
Nuttyy
Drives: E93 m3
I had just made an order for fender liner and undertray. Hope its gonna improve the cooling a bit
