06-24-2018, 06:24 PM | #1 |
Rep 86
Balancing Problem - Any input?
I recently had my rims refinished (slight rash repair and powdercoating) and while I was there I installed four new PS4S - same size (255/275) as the worn out PSS.
After getting it on the highway I noticed a very mild vibration in the steering wheel and seat at speed (~120kmh). I attributed this to either needing an alignment or poor balancing job. I was swapping to coilovers soon so held off. I recently did the alignment and a roadforce balance. Alignment had no issues, but they could not roadforce balance any of the wheels. Each wheel was showing at least 40lbs of roadforce (should be well below 20lbs). The alignment shop I went to said the tires could be defective and try to warranty them through Michelin. I'm completely stumped. -The rims before refinishing were fine. No vibrations w/ Mich PSS. Is it possible that during the refinishing process the rims may have warped in the oven? That is the best idea I could come up with as only 2 of them had mild rash that needed to be repaired. The rims and tires balanced fine, just not w/ roadforce. -Is it possible four tires could all be defective? Being that they are PS4S which are a brand new tire? -Is it possible the shop's Roadforce balancer need to be re-calibrated? 40lbs+ of roadforce seems excessive, however I only have a very mild vibration from ~110-120kmh. |
06-24-2018, 09:10 PM | #2 |
Rep 3,001
How is it even possible that 4 tires would be defective? Take it elsewhere and try to get it road force balanced again.
INSTAGRAM: GORDON.M3
06-24-2018, 09:44 PM | #4 |
Rep 307
This doesn't make sense...not a single rim and tire could be balanced? If so, there is really only one option in my mind, or I can say at least what I would do. I would take the car back to the alignment shop or wherever you bought the tires, have them remove all four tires from the rim, put the rim on the balancer minus the tire and have them spin it. Watch carefully for any wobble in the wheel to rule out the rims did not get some sort of damage. If you cannot notice a wobble they should be round.
If they cannot confirm its your suspension or they cannot road force balance the tire within spec. Then demand new tires, how many km's did you put on them? I have found Michelin to be pretty good with stuff like this. I had a similar issue on my previous M3 on a set of HRE, I could not get the right front passenger rim and tire to balance out right. It did turn out to be the tire and it was a PSS. The tire shop replaced the tire after I put about 700 km's on it. One tire is not 4 though...wish I could be more helpful but I think you have to rule it out one variation at a time.
2008 E93 M3 | SSII | HRE P40's (Sold 2018)
2011 E90 M3 | Jerez Black (Sold 2019) 2019 Lexus IS300 (lasted 3 months) 2020 Toyota 4Runner TRD (fun truck) 2014 Tesla Model S P85 (wicked car) 2011.5 E92 M3 | Space Grey | ADV.1?s |
06-25-2018, 12:28 PM | #5 |
Rep 6,734
Powder coating at too high of a temperature will weaken the wheel. Often they powder coat at a safe temperature but overheat the wheel to remove the existing paint. It's possible that's what happened. I doubt all 4 tires are defective but powder coating itself wouldn't cause an imbalance. It would be something that would happen after use.
'23 X7
06-25-2018, 05:24 PM | #6 |
Rep 86
Update - Will bring it back to wheel shop to re-balance. Turns out they have a roadforce machine as well and offered to force match, etc for free. Highly doubt all 4 michelins could be defective... If they balance there, I'm going back to the alignment shop for a refund...
06-25-2018, 08:41 PM | #7 |
Derbo Tuning
3609
Rep 3,022
I had the EXACT same issue with brand new rims + brand new PS4S. Turns out the installer did not put enough tire mounting lube and the bead did not fully seat properly resulting in poor road balance weight.
I took it to another shop that knew what they were doing and they got it down from 40-50lbs to managable 18, 11, 13, 8 here is my post in my journal: http://www.m3post.com/forums/showpos...3&postcount=87
IG:ruhrohz_m3
06-25-2018, 11:28 PM | #8 | |
Rep 86
06-26-2018, 01:27 AM | #9 | |
Rep 6,734
'23 X7
06-29-2018, 07:03 PM | #10 |
Rep 86
For anyone interested, I went back to try to force balance them again and was able to get two tires below 30lbs and one ended up showing a ridiculous 90lbs+. We spun the rims as well and they were perfectly straight. I was told two of the tires had random flat/dead spots almost as if the car had been sitting unmoved for months. I'm going back to the tire distributor to do an inspection and begin the warranty process w/ Michelin for all 4 tires. Really surprised to see this happening to higher end Michelin tires... but I guess it's just bad luck for me.
06-30-2018, 01:29 PM | #11 | |
Derbo Tuning
3609
Rep 3,022
IG:ruhrohz_m3
06-30-2018, 01:49 PM | #12 | |
Rep 3,001
Having 4 tires to be so out of balance sounds strange.
