11-27-2019, 11:11 PM | #1 |
Rep 431
PPI results: 2011 E92, 77k miles DCT
I'd just like to share my PPI results for some input and whether the items are heavy concerns or somewhat typical characteristics for the E92. Overall the car is in great shape, no surprises. However the below was highlighted:
Regarding "seeping", i believe they categorize the level of extremity from moist, seep, to leak and did mention at the car's age/mileage it is not surprising but of course recommended to address the above. I did not note down estimated cost but I recall it was substantial..somewhere in the 3-3.5k for the 'seeping' work. Battery ~$400 for OEM. Any feedback is welcome. |
11-27-2019, 11:45 PM | #2 |
Rep 2,824
Battery, brake fluid, and cabin filters are ordinary, cheap maintenance items so nothing to worry or address there.
The other items are not unusual at all for the mileage, but are not the cheapest services to address. That’s several thousand dollars, not including the RB job. If it’s just the lower DCT pan, that can be $500, if it’s the side pan, then add $1K. If that’s all they caught in the PPI and the car is otherwise clean and exactly what you want, I would just use the PPI to negotiate a price reduction of $2-3K. |
11-27-2019, 11:52 PM | #3 |
Rep 7,109
"Minor shavings in the oil", is that from oil analysis or visual mate? If the latter I personally would stay away.
Like Wyatth and your shop says for the other; normal maintenance but certainly not free and most probably you will find more things to add to the list, plugs etc. |
11-27-2019, 11:53 PM | #4 | |
Rep 431
11-28-2019, 12:07 AM | #5 | |
Rep 431
11-28-2019, 12:59 AM | #6 | |
Rep 7,109
I should point out that this is far from a professional opinion though. Lets see if some of tge experts chime in here. Good luck! |
11-28-2019, 01:24 AM | #7 |
Rep 2,824
Reading this on my phone and don’t think I saw or processed the metal shavings. That’s definitely worth clarifying and a potential red flag.
Did you test drive it? Did the engine feel and sound good? |
11-28-2019, 01:29 AM | #8 |
Rep 431
I'll email and have them clarify their methods. Yes - sounded fine and performed great. The PPI was done and SVBimmer.
11-28-2019, 02:05 AM | #10 |
Rep 7,109
OP, btw seems you do have a proper shop. Having a dealer doing a PPI over here I bet they wouldn't even find the trans leak, cause too much work to take the cover off (DCT)... So that should be a good start, lets see what they feel about the shavings!
11-28-2019, 08:46 AM | #11 |
Rep 431
Yes very reputable here in CA. I’ll sync up after the holiday weekend and ask to clarify. I’n the meantime, the RB work is already on the calendar but for my wallets sake will tend to the other “seeping” the next round
11-28-2019, 09:30 PM | #12 |
Rep 1,389
Ummm.. all of the above "seeping" are somewhat normal (by themselves), but could be a disaster since you have the trifecta... but #1, if you have any sort of metal shavings in the oil RUN AWAY as fast as you can. literally. So many choices out there. run run run... doesn't matter if metal shavings were in oil, doing rob bearings after the fact is just flushing more money down the toilet.
Not that it matters, since you should run away, but the other seeping are somewhat normal, but the Diff, tranny, and valve covers all being culprits, conservatively assume that's $4K+ to get those alone fixed assuming you aren't DIYing, and if any of those are beyond just gaskets and have further damage like replacing actual valve covers, or replacing the entire Diff (never know) then add $2-4K more.. this has all the signs of a $10K-$25K repair job car (assuming the worst, which happens, TRUST me)... run run run |
11-29-2019, 01:05 AM | #15 |
Rep 431
Hello all, thanks for the info so far, it's definitely informative and warrants concern. To be clear, I have already purchased the vehicle for a price that took into consideration the work mentioned above. Whether or not the decision will result in long term consequence is now a responsibility I own. Asides from the items of concern, the car does sound and drive well. It is a Mineral White DCT w/ two-tone black/fox red interior with a clean body (clean title, no accidents or past body/paint work) which is why I chose to accept. As mentioned earlier, my Indy shop did point these items out but did not give the impression of a deal breaker hence I moved forward. Currently the car will be 'on ice' while waiting for my RB appt etc but as of this moment the car looks and feels great.
Definitely more than happy to keep this dialogue open and report back their detailed explanation for that comment...To be continued. |
11-29-2019, 01:35 AM | #16 | |
Rep 7,109
11-29-2019, 01:40 AM | #17 | |
Rep 780
11-29-2019, 01:45 AM | #18 |
Rep 431
Curious what year E9x? And if above 2011, would it have a similar signature?
11-29-2019, 02:10 AM | #19 | |
Rep 780
11-29-2019, 02:45 AM | #20 |
Rep 586
battery is easy. I got 90AGM(same size) from AutoZone and I have INPA in my computer to register the new battery. Seems you are in Bay Area too, let me know if you need help with it.
The battery is very heavy and in the corner well where you cannot pull it straight up |
01-07-2020, 04:00 PM | #21 |
Rep 431
Hello all, would like to circle back on this thread as I've finally gotten a chance to speak w/ the Indy shop which performed the PPI. So their method of oil inspection was simply visual, a pull-out the oil filter and observing tiny particles. Whether or not this is RB material they are not certain until performed but mentioned it is not an unusual finding but something that needs to be addressed. Since the PPI, I have only driven ~30 miles or so to get acquainted w/ the car (no redline) while I wait for my BE bearing back order. From normal driving, the car feels and sounds great but nonetheless will have all preventative maintenance done any day now.
01-08-2020, 02:10 PM | #22 | |
Rep 420
Drives: E92 335XI (sold)/E92 M3 (sold)
The DCT is most likely the bottom pan. Those are notorious for leaking. I had mine replaced while doing the RBs. You might want to get clarification whether its the bottom pan, the mechatronics, or both and how much of it has leaked out. I had a shop tell me it was both the bottom and mecha. The guys who did my RBs told me that is was only the bottom ... that the liquid near the mecha was from the A/C drain off and people confuse it sometimes for seepage and the first shop was trying to scam me into getting it fixed. Cost me like $500 to fix the bottom pan. When I bought my M3, I probably only drove it like 30 miles before grounding it until I got the RBs done as well. I think that is a good move. It is overkill? Maybe...but I didn't want to take the chance. |
