  TireRack
      04-30-2020, 10:00 AM   #1
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Spacers and Style 220's
Seems like most members running spacers are on ZCP Style 359's and not Style 220's. For those with spacers and 220's, what size spacers are you running? Seems like 15F/12R is a popular combo, but is that ideal for 359's or 220's? Anyone have pics of 220's with spacers on E92's preferably.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      04-30-2020, 10:03 AM   #2
Dpc2u
Dpc2u's Avatar
Drives: E93 M3, E60 M5, F15 X5, E46
15f and 12r on mine. E93 with Eibach pro kit.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus
      04-30-2020, 10:40 AM   #3
brettcp
Drives: 2012 E93 M3
I did 12.5mm front, 10mm rear with 220's but that's on an E93 M3. See my post here: https://www.m3post.com/forums/showpo...&postcount=699
      04-30-2020, 11:04 AM   #4
bake
bake's Avatar
Thanks to you both. Ironically I have an E93 as well, but figured very few members have verts, so asked for pics on coupes. I think I am going to go with 15/12's as I am on stock suspension for now (just picked up a '13 E93 late February). I do plan on getting Eibach pro kit down the road as well, and if I get rubbing once lowered I will make adjustments if needed. I really appreciate you guys chiming in.
Originally Posted by brettcp View Post
I did 12.5mm front, 10mm rear with 220's but that's on an E93 M3. See my post here: https://www.m3post.com/forums/showpo...;postcount=699
Bake
Dpc2u11503.00
      04-30-2020, 11:16 AM   #5
jiggz
Drives: E90 M3|F15 X5 50i
I'm running 15F/12R w/220's on my E90 (Eibach pro kit as well).
bake601.50
      04-30-2020, 12:23 PM   #6
Dpc2u
Dpc2u's Avatar
I have no rubbing issues with the Eibachs and those spacers. Eibach had e93 pro kits on closeout for $78 which I was fortunate to grab a set for. Unfortunately they are all gone since several people bought a crapload to resell for close to full retail.
IG - @thebimmerhaus
bake601.50
      04-30-2020, 01:08 PM   #7
bake
bake's Avatar
Wow, I wish I would have caught that deal. Great find!
Bake
Dpc2u11503.00
      06-06-2020, 12:30 PM   #8
slowdown_dan
slowdown_dan's Avatar
281
Drives: e93
On my 220 street set I'm running 15 front, 12.5 rear with 255 & 275x35 azenis fk510. It looks fantastic.
      06-07-2020, 02:10 PM   #9
DL335D
DL335D's Avatar
578
Drives: 2013 e92 M3 Q4
Your car is not lowered correct?
Do you have a pick of your car from this angle...
2013 e92 M3
2011 X5 35d
2018 F80 M3 ZCP
      06-07-2020, 03:15 PM   #10
slowdown_dan
281
Drives: e93
This is the closest angle I have on my phone atm. If you go 255/275 lowered or not, don't go for more than a 12.5mm rear spacer (without increasing camber a bit) or it will rub 100% with this tire. 15 in the front could really be 18mm with this tire, especially if you pull the pins and max out the factory camber. Coilovers and camber plates are coming for track duty but a side effect of those will be that I can adjust the fender gap and increase the camber to tuck in wider rubber.
DL335D577.50
      06-07-2020, 03:18 PM   #11
slowdown_dan
281
Drives: e93
I have the slightest of side wall rubs on my rears when from when I launch. This is how l can firmly suggest anything more than a 12ish mm spacer will rub with this particular tire.
      07-05-2020, 03:42 PM   #12
ExpatPetrolhead
Drives: 2017 Mustang GT V8 5.0
Hi, sorry I'm new here, still finding my feet on this forum, bit of a maze. Anyway, have 2008 E92 M3 stock 19 inch wheels, stock springs/shocks, want to add spacers not sure what to go for, or why I have to (?) go different front and back when the distance moved outward will be the same if i go same size F & R, the 'stagger' will remain the same? What difference would it make if I went 15mm f & R, or 15f 12r? I do not intend to lower. Please help.....thx
      07-05-2020, 05:34 PM   #13
DL335D
DL335D's Avatar
578
15F 12R is the combo that most seem to run and IMO look perfect. I get slight rub when turning because I'm running 255/35/19s upfront. I recommend going with a quality spacer due to risk of steering wheel shake with cheap options. MS or TMS seem to be most popular here.
2013 e92 M3
2011 X5 35d
2018 F80 M3 ZCP
      07-05-2020, 06:11 PM   #14
bake
bake's Avatar
15F/12r lowered on Eibach Pro Kit springs
Bake
Scrippy1802.00
      10-02-2020, 03:08 PM   #15
6spdvert
Drives: NA
that looks real good.. what spacer brand did you go with?
With ECS, TMS, MS and FC, I am on the fence... lol
Having options is nice but its can be a pain when trying to decide...
      10-03-2020, 06:33 PM   #16
bake
bake's Avatar
ECS
Bake
Search this Thread:
Advanced Search
