06-27-2019, 09:48 PM | #1 |
i'm just saying
5738
Rep 2,634
What Formula 1 Needs
ideas will be sent to FIA, hoping they consider..
thought it can be interesting to gather ideas.. even if im super happy with Merc's dominance in recent years, there can be things to boost racing without slowing the cars down.. some may sound extreme or easy to do.. 1. longer straights that forces teams to use lower downforce setup.. cause each meter after reaching top speed makes the leading car vulnerable.. and heavy braking zone is a big overtake advantage.. 2. adding 1-2 less than 60-70kmh corners can avoid aero grip and using mechanical grip only.. not even mentioning the braking zone before the corner to widen the chance of an overtake.. closing the gap in the corner will allow the follower car to exit the corner closer.. 3. DRS duration can vary on each team.. there should be more advantage on slower cars.. equal on each car is not fair.. it can be based on the recent constructor points.. 4. wider tracks.. wider tracks and turn combinations will alter different racing lines on the corners to avoid aero grip lose for following the car in front.. and the next idea is necessary to complete this one.. 5. cleaning the track before the GP weekend.. nothing high tech about this.. 3-5 or more vehicle that each municipality uses for cleaning the streets can be useful to clean the track also.. overtaking almost always requires going off the racing line and if there is dust things are getting even harder.. drivers shouldnt hesitate to use different lines because sticking dirt to their tires.. 6. mild banking on mid speed corners.. 1-2 on each track.. banking will allow to keep the mechanical grip in the game a bit more and take off some the disadvantage of following a car.. 7. not changing the regulations of cars and engines regularly.. cause each big regulation change is leading one team shine more than others.. keep the regs longer or changing them smaller will give time to other teams and gaps will be much smaller.. 8. im not sure it can work but like we re using in prokart or other series that adding weight to faster car to create a handicap based on the previous race.. even if probably big teams will produce cars according the max handicap weight, it still can be useful.. 9. longer braking distances.. like 25-30% longer braking.. cause most of the overtakes finish in the following corner and recently F1 cars almost brake at the entry of the corner.. braking distance is too short.. this can be achieved by thinner discs or smaller disc diameter easily.. i guess all the teams are customers of Brembo.. 10. like DRS based on the constructor points more electric juice on slower cars to compensate the power difference.. these are the initial ideas i have for some time.. what do you guys suggest or think to boost the competition among drivers?
"Race car driving is like sex. All guys think they're good at it." Jay Leno
06-28-2019, 06:44 AM | #2 |
Rep 137
better tracks (more like Spa, Silverstone)
V12s and no traction control cars are too big for tracks. hard to make tracks bigger, easier to make cars smaller. |
06-28-2019, 12:06 PM | #3 |
Rep 286
I like number 5. The Toronto Indy cleans the track during races, every time there is a caution lap. Jet blower mounted to the back of a truck comes out and blows the marbles off the track. Leading to more passing during a race. I always wondered why F1 doesn’t do this. It would work on the CF bits that they spend time picking up by hand and shorten the amount of caution laps I think.
2019 YMB ZCP convertible with Dinan Exhaust
2011 Ducati Diavel Carbon Edition 2015 BSM M4 Convertible - 2018-2019 2016 228Xi - 2017-2018 2003 Acura RSX Type S 2003-2017 |
clee1982797.50 |
06-28-2019, 12:44 PM | #4 |
Rep 2,232
I would like to add two pit stop related ones:
1. Refueling - Technology can be advanced to make it safer I would say. Less fuel/smaller fuel tanks might also result in faster lap times. Also adds a bit of strategy, although I assume everyone will find the optimum theoretical strategy pretty quickly. Still. 2. Minimum pit stop times, the minimum limit would be a second or two more than adding a splash of fuel, but less than a full refuel. This way during a Safety car (or even not during a SC) there's an additional strategy component. |
Pauldunlop13425.00 Timujin352.50 |
06-28-2019, 02:14 PM | #5 |
Rep 210
Just reduce aero by 50%, leave the rest the same.
2012 Space Grey 128i
RMachuca3d723.50 |
06-28-2019, 02:49 PM | #6 |
Run Deep
15127
Rep 4,123
Drives: Back and Forth To Work
Garage List 2018 Alfa Romeo Giu ... [0.00]
2022 Ford Bronco 2d ... [0.00] 2016 Alfa Romeo 4C [8.50] 2019 BMW i8 Roadster [0.00] |
I think the comment about the longer straights needed and the fact the tracks are too narrow are probably the most viable when it comes to where the biggest issues are related to watch-ability of current F1.
Passing is extremely difficult due to the size of the cars vs. the width of the tracks. As mentioned by a poster above, widening tracks may be too difficult, so making the cars smaller is another alternative option. In addition, the longer straights will automatically dictate longer braking zones at the end, there by negating your point about extending braking zones via car manipulations. Longer straights and higher speeds will allow longer braking at the end, to wit more opportunity for passing. These are some good points you mention - unlikely to come to fruition though in reality. Which is sad.
Don't sweat petty things....or pet sweaty things.
06-29-2019, 10:47 AM | #8 |
dances with roads
4725
Rep 4,096
I know it will never happen but, immensely simplify the rules. Set a few minimums and maximums, then let chassis builders and engine builders have at it. It won't do much to trim costs but it might make for some pretty innovative solutions. Look at the Delta Wing car for example; half the horsepower, no wild airplane parts hanging off front or rear, still fast and competitive. I'm still enamored of that car and what it could represent if the rules were just simplified to allow minds to truly be creative.
Run Silent15127.00 MKSixer34184.50 |
06-30-2019, 02:39 PM | #9 |
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
All too complicated. Here is how you fix F1:
15% of the aero from a mandated 2 element wing. 75% of the aero from the floor. Diffusers of any type allowed. 10% of the aero from the rear wing. Cars can follow. Cars can pass. Cars won't experience aero wash out when their path is cut across by another car. Shall I send my bill to the FIA and Jean Todt? Who has their address?
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
///M Power-Belgium63331.00 |
06-30-2019, 04:11 PM | #11 | |
Rep 11,637
If the floor is responsible for most of the aero then the mechanical grip will move back to the fore. This single change will fix the following problem as well as reduce the cost of development.
06-30-2019, 05:40 PM | #12 | ||
Rep 6,862
MKSixer34184.50 |
06-30-2019, 09:53 PM | #13 | |
i'm just saying
5738
Rep 2,634
07-01-2019, 10:28 AM | #14 |
Rep 2,232
I've got a new suggestion for this thread.
All future races in Austria, clone Max, Charles, Albon, Lando, Sainz, Lewis, Kimi, and Valterri; put them all in identical cars and let the race. |
07-01-2019, 11:34 AM | #15 |
Rep 145
Take the cars back to the 80's 90's spec when the drivers had to drive the fucking car, not pushing buttons like a play station game.
07-01-2019, 02:31 PM | #16 |
Rep 1,005
Drives: GMC Sierra
DRS should be unlimited during race.
We grow food to feed the animals so we can eat the animals
07-01-2019, 03:08 PM | #18 | |
Rep 11,637
On the subject of Gordon Murray's Fan Car...it's funny, we were actually discussing this over the weekend with a friend of mine who is getting a T50 (name?) and has a follow-up meeting with Mr. Murray this month. I also thought the car was banned but it was actually voluntarily withdrawn by Mr. Ecclestone. The teams all got together and told him that if he ran the car in the next race, they would all withdraw and they'd be left alone to drive in in circles on an empty track. Good ole' F1 history from the horses mouth, once removed. Great post!! Cheers-mk
07-01-2019, 03:27 PM | #19 | |
i'm just saying
5738
Rep 2,634
MKSixer34184.50 |
07-01-2019, 04:35 PM | #20 | |
Supreme Allied Commander
1963
Rep 61,781
Drives: A BBS WHORE
"strat, mode 4"
07-01-2019, 05:50 PM | #22 |
Rep 10,662
Drives: M4 CS. Former G82, x2 F82, F80
V12s, kill the aero at least 50%, bring back manual gearboxes, full pit stops again with fueling, on and on. Drop the dumbass tire regs too, you can run whatever kind of tire you freaking want at anytime.
What I'd really like to see are stock V12s given to every team from a sole supplier, and then the chasis/gearboxes are left up to the teams. If they insist on having different engines by manufacturer, put a cap on HP levels so all engines for all teams must be within 1-2% max hp of each other. So for instance we'd be detuning the Mercs which should have happened years and countless boring races ago. None of this will ever happen in F1 of course. Last edited by NickyC; 07-01-2019 at 07:33 PM.. |
Bartledoo2691.50 |
