  TireRack
      08-23-2018, 10:31 AM   #1
wildwestm3
wildwestm3's Avatar
215
Drives: 2008 M3 Convertible
Tires and 359m's
So, there are so many opinions on here and I've read so much that my brain now hurts. I'm about to buy a ZCP car that is on the stock suspension (i.e. not lowered). It is going to need tires and my plan is to stick with Michelin's. From what I've read, I can go 265/30/19 and 295/30/19 without any rubbing. Here are my questions:
- Will these sizes fit without rubbing?
- Will they come flush to the fenders or will I still need spacers?
I have an 08 e93 now that I'm running 255/275 combo on with 12 15mm spacers. However, those are 220m wheels, not 359m's. Plus, it is not the ZCP suspension. Please don't bother telling me to read and give me a tutorial on searches, I've done plenty and all it has done is confuse me to be honest. Your thoughts and/or any pictures you have with this set-up would be greatly appreciated!
Thanks,
Dave
[SIGPIC][/SIGPIC]
      08-23-2018, 11:18 AM   #2
spazzyfry123
spazzyfry123's Avatar
4359
Drives: Here and There
You'll be fine with the tire size - especially with non-ZCP suspension (fronts should be fine regardless, 295 may rub a smidge on ZCP suspension if you're going Dukes of Hazard).
If you want flush, the same spacer combo you are using will get the job done. If I'm not mistaken, 15mm front, and 12mm rear (I might have that backwards).
I was running 265F/285R on 359 wheels with no problems at all.
      08-23-2018, 12:31 PM   #3
wildwestm3
wildwestm3's Avatar
215
The car is a ZCP. Problem is doesn't look like the MPSS' come in a 285/30, so doing 295/30.
Thanks,
Dave
[SIGPIC][/SIGPIC]
      08-23-2018, 12:59 PM   #4
spazzyfry123
4359
Ah I read too quick. Combined the second part saying "Plus, it is not the ZCP suspension." from your E93 with the new car you're buying.
I think you'll be set! Going to be a good look.
      08-23-2018, 01:02 PM   #5
roastbeef
roastbeef's Avatar
I run 275/30/19 and 295/30/19's on my 359's on the street without rubbing. Oem zcp suspension. Michelin ps4's.
      08-23-2018, 05:44 PM   #6
wildwestm3
wildwestm3's Avatar
215
Roastbeef - that’s perfect! Thanks for the pics. Looks like I’ll be good. Given the pics, I’ll run spacers as well. I have 12 & 15mm already. Looks like they’ll work...thanks!
Thanks,
Dave
[SIGPIC][/SIGPIC]
      08-23-2018, 06:03 PM   #7
roastbeef
roastbeef's Avatar
Might rub with spacers.... you'll be able to test fit I guess.
      08-23-2018, 07:00 PM   #8
wyatth
Drives: E90 ZCP
Roast beef - why do your fronts look so sunken in? Like, worse than stock yet you’re on 275s.
      08-23-2018, 07:15 PM   #9
spazzyfry123
4359
Dat camber doe.
roastbeef11586.00
      08-23-2018, 08:45 PM   #10
roastbeef
roastbeef's Avatar
its added camber, and i don't run spacers.
      08-23-2018, 08:57 PM   #11
wyatth
Drives: E90 ZCP
Roger that. What’s your front camber set to?
      08-23-2018, 09:34 PM   #12
roastbeef
roastbeef's Avatar
i think its around -3.
      08-25-2018, 01:31 PM   #13
scrammer
scrammer's Avatar
Drives: 2017 M3 Ultimate
Roger that. What's your front camber set to?
I was trying to get a handle on that look as well. Have you ever tried a 12mm spacer on the front?
Rears are perfect!
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
      08-25-2018, 05:11 PM   #14
roastbeef
roastbeef's Avatar
Rears are perfect!
I got some used 15mm spacers when I first got the car and I got a little vibration from them and didn't like the way they made the car feel in general. No more spacers for me u less I absolutely have to.
      08-25-2018, 10:45 PM   #15
scrammer
scrammer's Avatar
[/QUOTE]
I got some used 15mm spacers when I first got the car and I got a little vibration from them and didn't like the way they made the car feel in general. No more spacers for me u less I absolutely have to.[/QUOTE]
just thought I would ask
      08-28-2018, 01:28 PM   #16
slicer
slicer's Avatar
2738
I don't see the point of putting 275's on a 9" and 295's on a 10" wheel. 255 or maybe 265 is the widest I would want to run on a 9" and 275 or maybe 285 is the widest I would run on a 10". The wider tires will work but you aren't getting as much performance out of them with such a narrow wheel plus they don't look good IMO. I would do the classic 255/35 and 275/35/19 if it were me.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
BayE301341.00
      08-29-2018, 01:07 PM   #17
Dave07997S
Drives: 2020 Ford Mustang GT
MPSS does come in 285/30/19 now..
Dave
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk
2007 Porsche 997C2S Speed Yellow/Blk sport seats
2004 BMW M3 Imola/Blk
