      05-29-2019, 11:24 AM   #1
cvstar9M3
cvstar9M3's Avatar
Drives: 2011 MR e90ZCP 6-MT
295 Ps4s in the rear ok for track?
I have a new set of F14s wheels 10 inch fronts and 11 in the rear. My car is mostly street but I think I will do 3-4 track days a year. I have 275/30/19s PS4 in the back now and was thinking of moving them to the front and getting 295/30s for the back but my concern is that 295 might be a bit wide/heavy for track use. Am I right? the other option is to get 285 for the rear but that would mess would handling of the car (I think) since I'd have 275 in the fronts. Any help would be appreciated. I could get a new set of tires but I want to hold on to the 275s since they are virtually new. Thanks.
2011 MR e90ZCP, 6-mt
2011.75 e90 M3 ZCP, DCT, ZP2, ZCV, JB w/ 2Toned FoxRed/Black Interior - SOLD
      05-29-2019, 12:16 PM   #2
dparm
Stop the hate, get a V8
dparm's Avatar
275/295 keeps the same front-to-rear offset as stock, but a non-stock offset isn't necessarily bad. It will depend on how the car is setup and your driving competence. A bigger tire will be able to handle heat better, but it adds unsprung weight. You are also potentially changing the effective gearing even further.
3 or 4 track days per year isn't really that many, in my opinion, so don't solution for a situation you're in for 1% of your driving miles. If you decide to get more serious, I suspect you'll end up with dedicated track wheels anyway.
Past: 2011.5 M3 sedan ZCP
cvstar9M3284.00
      05-29-2019, 12:31 PM   #3
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11480
I think you'll be just fine. The best advice for tracking is 'run what you brung' and worry more about learning and improving your skills than getting to the perfect mod level
      05-29-2019, 12:36 PM   #4
cvstar9M3
cvstar9M3's Avatar
Thanks. That makes sense. I just tracked my car for the first time. And wanna do more. Tops 5 days this year would be plenty.
I appreciate it. Considering 275 will be upfront., which would you choose for rear Between 285 or 295? Thanks again fellas
      05-29-2019, 12:52 PM   #5
SYT_Shadow
SYT_Shadow's Avatar
11480
With an 11" in the rear you can properly support a 295, so why the hell not get the most tire you can get?
cvstar9M3284.00
      05-29-2019, 03:56 PM   #6
slicer
slicer's Avatar
2738
Agreed!
OP - what is your rear offset? That's the bigger concern. You need to make sure the 295 will actually fit.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
SYT_Shadow11479.50
      05-29-2019, 07:12 PM   #7
dparm
dparm's Avatar
Yeah, I think this is a really basic point that everyone overlooked. You already have a big wheel that can fit a large tire so why not just go that route? An 11" wheel will even support a 305 though I don't think those fit on a coupe without serious modification (sedans supposedly have a little more room).
As a casual HPDE person, are you even driving the car at 10/10ths where you'll notice a small difference in tire size? Probably not.
SYT_Shadow11479.50
      05-31-2019, 12:19 PM   #8
rhyary
rhyary's Avatar
Drives: 2013 M3
I have a new set of F14s wheels 10 inch fronts and 11 in the rear. My car is mostly street but I think 3-4 track days a year. I have 275/30/19s PS4 in the back now and was thinking of moving them to the front and getting 295/30s for the back but my concern is that 295 might be a bit wide/heavy for track use. Am I right? the other option is to get 285 for the rear but that would mess would handling of the car (I think) since I'd have 275 in the fronts. Any help would be appreciated. I could get a new set of tires but I want to hold on to the 275s since they are virtually new. Thanks.
295/30/19 would polish your inner fender.
But as Slicer said, offset can make a difference.
I run 275/30/19 front and 295/30/19 rear
cvstar9M3284.00
      05-31-2019, 12:32 PM   #9
Richbot
Drives: Jerez Black E90
I've recently become a fan of just running 275's square and tuning throttle-on balance with spacers rather than carry the extra tire around, which I'm not convinced you need unless you're supercharged. I'm all about whatever I've done most recently though, so you can safely ignore me
      05-31-2019, 02:14 PM   #10
slicer
slicer's Avatar
2738
That looks like you ran a 295 on an et35 wheel. Am I right?
'23 X7
      05-31-2019, 07:26 PM   #11
Chris_PDX
Drives: E92 M3, E46 M3, NA Miata
2002 BMW M3  [0.00]
2012 BMW M3 Coupe  [0.00]
I ran 275 and 295/30/19 as my street setup for years with the occasional track day thrown in. It's fine. You'll rub inside, but that's the price you pay!
As others side, big wheels/tires are heavy, which means higher rotational mass at the corners, which can spoil handling. I run 18" square now and it's a thing of beauty, even on the street.
cvstar9M3284.00
      06-01-2019, 02:40 AM   #12
cvstar9M3
cvstar9M3's Avatar
My fronts are +20 offsett
      06-01-2019, 07:09 PM   #13
slicer
slicer's Avatar
2738
The fronts aren't in question. You were asking about fitting 295's in the rear. The rear offset is what we need to know in order to let you know if it will fit.
'23 X7
      06-01-2019, 07:10 PM   #14
slicer
slicer's Avatar
2738
You shouldn't rub with a 295 if you have the right offset.
'23 X7
      06-01-2019, 07:22 PM   #15
cvstar9M3
cvstar9M3's Avatar
19x11 et 27
      06-01-2019, 07:30 PM   #16
slicer
slicer's Avatar
2738
19x11 et 27
295/30/19 will fit fine on that wheel spec.
'23 X7
      06-01-2019, 07:39 PM   #17
cvstar9M3
cvstar9M3's Avatar
what about 270/30 upfront (will do a conservative drop with Dinan springs). 19x10 (+20)?
      06-01-2019, 07:45 PM   #18
slicer
slicer's Avatar
2738
It will fit great but I would plan on camber plates. You will need approximately -2 to -2.2 camber with that front fitment.
'23 X7
cvstar9M3284.00
