12-05-2017, 04:55 PM | #1 |
Rep 561
Performance Caliper Guide Bushing
Hello Everyone,
What are your thoughts about this? "Reduced caliper deflection, enhanced pedal feel, and improved pad wear. An excellent way to improve braking performance". https://www.ecstuning.com/b-ecs-part...003326ecs02~a/ Thank you. |
12-05-2017, 06:53 PM | #2 |
Rep 10,613
I like them. Been running bimmerworlds version on my front calipers for several years and ran them front and rear on my E36M3 for about ten years. You must grease them periodically but once a year is probably enough unless you really use the brakes a lot or track the car—I don’t track and drive about 8k miles a year mostly highway.
Add braided lines, good fluid, titanium shims if you track the car, and higher temp pads if you track the car. For ridiculous cold bite but lots of dust and maybe some squealing run Hawk HP Plus. I use Stoptech Street and they have a little less cold bite than stock but more fade resistance (which I don’t need for my street driving). |
12-05-2017, 08:46 PM | #3 | |
///M Powered for Life
11480
Rep 10,328
I ran them for years on my E46M for track use. Worked extremely well. |
01-16-2018, 10:19 AM | #5 |
Rep 561
I noticed that the spiro lock grooves on the short bushings don't seat flush to the calipers, having therefore an axial play. Have you guys encountered this as well? Just the short ones. Long ones are kind of ok.
Long Short Thank you. |
01-16-2018, 10:55 AM | #6 |
Rep 1,286
I noticed the same on the bushings I installed on the rear calipers but I think that's just a last resort safety issue anyway to make sure it doesn't come out (into the rotor side) for some reason. The interference fit for my bushings was really tight and it's hard to imagine them coming loose unless you get the caliper really, really hot.
01-16-2018, 12:32 PM | #7 | |
Rep 561
Thanks. |
01-16-2018, 06:34 PM | #8 |
Rep 1,286
That's really weird. I don't think they should be loose at all. The way the bushings come out of the package with the knurling (and given how tight they were for me) makes me think they are designed to be a tight interference fit.
I wouldn't feel comfortable with that weeny spiral lock to keep the bushing in place if the bushing fit is loose. That just seems like a bad idea. Sorry you've had a bad experience. |
01-16-2018, 08:34 PM | #9 | |
Rep 561
01-17-2018, 06:20 AM | #10 |
Rep 1,286
No, they were about an 1/8" to 1/16" away from the caliper, just like yours.
So, I guess in your case they are going to wobble back and forth in the caliper. I wouldn't go for that. |
01-17-2018, 07:26 AM | #11 |
Rep 10,613
The ECS ones look like the only press fit ones since they have the knurled end. The others don’t fit as tight and the instructions say not to press the in but rather to sand the hole until the guide fits the caliper. The pin should be a fairly tight fit to the guide but you still need room for a little grease in there and they have to be able to slide freely with the caliper bracket.
01-17-2018, 08:32 AM | #12 | |
Rep 561
Contacting ECS is pretty impossible other than an online chat, so I guess I am stuck with a product I don't want anymore and have no support for. Thanks again. |
01-17-2018, 08:47 AM | #13 | |
Rep 561
I do understand that as long as the pins move freely without much friction (properly lubricated), that wont be enough friction forcing the bushings out, but by default, bushings should be press fit and spiro lock in place as a safety precaution. |
01-17-2018, 09:17 AM | #14 |
Rep 10,613
Maybe it is ok since the other versions like Bimmerworld can move back and forth in the caliper up to the C-ring and flange limits.
01-17-2018, 09:25 AM | #16 | |
Rep 561
Thanks! |
01-17-2018, 09:26 AM | #17 |
Rep 561
01-17-2018, 09:40 AM | #19 |
Rep 561
I could only contact them thru an online chat. I was asked to email them pictures of what is going on, which I did, and they would get back to me. I am still waiting to hear from them (3 days now) and cant get a person on the phone.
01-17-2018, 01:20 PM | #21 |
Rep 561
01-18-2018, 10:30 PM | #22 |
Rep 81
i've returned a handful of things to ECS, while their customer service isn't American Express level, I've found it decent if you pick up the phone. For all my returns, I've called them and gotten an RMA number and sent them back, no issues after that.
good luck, Jeff PS... I have these bushings on my e39 M5 from a year or two ago and they fit VERY tight, broke one cheap c clamp installing. |
