05-12-2015, 12:40 PM | #1 |
Rep 2,907
Drives: 2011 E93 M3
Parting out S65 M3 engine & DCT transmission
From a 2008 M3 coupe. The engine had 47k miles on it and cracked a piston due to trying to start a waterlogged engine. Otherwise OK. Make fair offers if you need something or if my prices are out of line. -Injector rails w/injectors $100 -Complete bag of hardware from entire engine $35 -Engine block peripherals- compressor mount, engine mount arms, pulley tensioners, etc. Make offer -Crankshaft, great condition good journals no damage $1200 -Vibration damper & crank pulley $100 -Connecting rods w/ wrist pins $40 ea -Oil filter housing $140 -Oil Pan (Cracked and TIG welded) $500 -Water thermostat housing and pipes $80 -Front and rear water distribution pipes $60 -Cylinder heads complete with cams/vanos $900ea -EGR valve set w/pipes $80 -Engine ECU $300 -Camshaft position sensors $40 ea -VANOS solenoid intake, $60 ea -Complete wiring harness w/DCT sub harness $400 -DCT Transmission complete w/hoses SOLD -Exhaust mid section with cats/o2 SOLD -Engine block, complete (cylinder 2 damaged) SOLD -Flywheel/flexplate (DCT trans) SOLD -Oil Pump assembly complete SOLD -Exhaust headers with all heat shields SOLD -Timing chain set SOLD -Valve cover passenger side, SOLD -Valve cover driver side, SOLD -Ignition coils SOLD -VANOS solenoid Exhaust SOLD -Starter, SOLD -Throttle actuators, SOLD -Individual Throttle bodies SOLD -Intake Manifold, SOLD -Idle Control valve assembly SOLD I'll add pictures here as time allows. I also have other parts from this car... Thanks Last edited by deansbimmer; 07-01-2015 at 06:05 PM.. |
05-12-2015, 01:41 PM | #2 |
Rep 3,726
Drives: 2018 M2
Do you have the airbox(the enclosure for the air filer) how much?
05-12-2015, 01:43 PM | #3 |
Rep 2,907
Drives: 2011 E93 M3
05-13-2015, 10:26 AM | #5 |
Rep 2,907
Drives: 2011 E93 M3
No heat exchangers or really anything left from in front of the A-pillar.
05-13-2015, 03:19 PM | #7 |
Rep 2,907
Drives: 2011 E93 M3
05-13-2015, 03:20 PM | #9 |
Rep 2,907
Drives: 2011 E93 M3
05-18-2015, 09:30 AM | #10 |
Rep 2,907
Drives: 2011 E93 M3
Nobody needs engine parts?
06-03-2015, 04:00 PM | #13 |
Rep 2,907
Drives: 2011 E93 M3
Some items sold. Updated original post.
06-07-2015, 02:28 PM | #14 |
Rep 2,907
Drives: 2011 E93 M3
Bump. Still have DCT transmission and S65 engine parts. Make offers- want to get these parts out of here.
06-23-2015, 02:02 PM | #15 |
Rep 2,907
Drives: 2011 E93 M3
Still have some parts. Anyone need a crankshaft? Lowered the price.
07-01-2015, 06:06 PM | #16 |
Rep 2,907
Drives: 2011 E93 M3
Updated first post. Make offers on parts, I want to make space.
07-01-2015, 08:00 PM | #17 |
Rep 3,726
Drives: 2018 M2
Do you have a nav screen?
07-01-2015, 09:36 PM | #18 |
Rep 2,907
Drives: 2011 E93 M3
Yes, $100 shipped. Pm me.
07-31-2015, 11:41 AM | #20 |
Rep 2,907
Drives: 2011 E93 M3
Yes I do. $280 shipped.
08-02-2015, 04:31 PM | #21 |
Rep 3,726
Drives: 2018 M2
There's a long trim strip that the cup holders sit in. Do you have that? I really need it also I need one blue female clip that the dash trim clips into if you've got that too
