04-26-2013, 05:53 PM | #1 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
Lost "P" for DCT
My car wont go into Park mode when i shut it off...
I keep getting " transmission position P is not engaged " when i turn the car off. even with the keyfob in my pocket. It will shift into P mode if i manualy mess around with the park selector under the shift boot. And seems to park itself after 30min, But it wont automatically come on anymore after i turn the car off.... Anyone else run into this problem?
04-26-2013, 06:28 PM | #2 |
Rep 1,159
I've had the same thing happen to me about 15% of the time. I'm wondering whether it has to do something with how far up I crank that handbrake?
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
04-26-2013, 06:35 PM | #3 |
O! So Sour!!
552
Rep 15,615
does it go away on its own?
I think i diagnosed the problem...the little level under the shift boot that you use to put into N (for towing) when the car is off does not return to the P position when i turn my car off. I have to manually use my screw driver to put it into the P and the car will go into P. When you put into Drive mode that little level will fall down to N position to release P. for a normal DCT it will go back to upright position to "park" the car when ignition is cut. My car will just stay in the N position...it wont revert back upright to P, i have to manually do it with my screw driver everytime if i want the "p" and not use handbrake.
04-26-2013, 07:28 PM | #4 |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
I always just put it into N with handbrake. Don't even worry about Park when handbrake is on, like a 6speed.
04-26-2013, 08:48 PM | #5 | |
O! So Sour!!
552
Rep 15,615
I lost the "P" setting when i turn off my car
