INDustry distribution
      07-20-2019, 02:27 PM   #1
Fooksdaddy
Fooksdaddy's Avatar
32
Drives: 2011 BMW M3 SSII
DCT overfilled?
Engine completely cold.
So I changed the dct filter (driver's side beside the oil lines) and a small bit of fluid came out...maybe 1/5 of a liter. Got that all put back together. I then backed out the fill hole and fluid started gushing out, I quickly ran the plug back in. Does that mean it was seriously overfilled?
will an overfill cause over temps since the fluid can't properly cool off???
I got everything patched up, did some runs and hard accelerations and pushed thru all the gears just fine. DCT transmission temp around 93°C...
E90 ///M3 Silverstone II '11
E90 ///M3 Silverstone II '08
E46 ///M3 Alpine White III
E36 ///M3 Arctic Silver
E46 ///M3 Carbon Schwartz
      07-20-2019, 03:15 PM   #2
exVtekGuy
Drives: none yet
you are supposed to fill with the engine running and trans fluid at certain temp. It was most likely at normal level when you opened it cold. Check in the diy section for trans fluid change diy for more details.
      07-20-2019, 04:33 PM   #3
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
was the car level when you opened the fill hole?
Anyways people try real hard to over fill the dct trans oil. Its seen as a positive.
Id worry you are now underfilled depending on how much came out when you open the fill hole.
      07-20-2019, 05:00 PM   #4
Fooksdaddy
Fooksdaddy's Avatar
32
Anyways people try real hard to over fill the dct trans oil. It’s seen as a positive.
I’d worry you are now underfilled depending on how much came out when you open the fill hole.
car was level
      07-21-2019, 12:43 AM   #5
M43S7RO
Drives: Jerez Black E92 M3
Was it running when you filled it initially?
If yes, then it is normal that oil drains when you open the fill plug when the car is off as the oil settles.
If no, then you cannot tell if it is filled to the correct level because of what others are pointing out. Fill should be done with engine running. Check the procedure for specific steps.
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
