05-05-2018, 07:35 AM | #1 |
Rep 6
No Error Messages, Temporary Limping
Please my car seems to temporarily limp when i drive slow at speeds of 20-30mph between 2nd and 3rd gears. Even when i kick down it doesn't accelerate. Its a bit dangerous and this scares me at times when the car isn't able to accelerate properly. How ever i have found some sort of solution which includes me turning off the ignition or pressing the M power button. Please what can i do?
05-07-2018, 05:06 PM | #2 | |
Rep 392
Drives: F13 M6
Find a scanner and read it out first. The above listed issue are all very common problems. |
06-08-2018, 05:29 AM | #3 |
Rep 6
New Error codes
please what do these codes mean.
10212 plausibility vacuum pump mastervac (HEX) 27E4 P2098 POST CATALYST FUEL TRIM SYSTEM TOO LEAN BANK 2 10134 AUX TRANS FLUID PMP CTRL CKT 10183 LAMBDA SENSOR AD DIAGNOSIS TRIM CONTROL BANK 2 HEX(27C7) INTERMITTENT 10134 ENG. EMERG. PROGRAM ACTIVATED (HEX)2796 11095 ENG. EMERG. ACTIVATED (HEX)2B57 AFTER CHANGING MY ACTUATORS MY CAR WENT INTO LIMP MODE AGAIN. ALTHOUGH THIS CLEARS WHEN I RESTART, I PUT A SCANNER ON I GOT THESE CODES AGAIN |
07-21-2019, 07:01 AM | #5 |
Rep 1,067
The 27e4 indicates an issue with the secondary vaccum pump for the brake booster. That can be a bad pump, bad vacuum sensor, or vacuum leak in one of the booster lines. The accompanying lean codes could result from that issue if indeed there is a vacuum leak which is introducing more air into the engine. 1st thing, do you hear the vacuum pump running a lot, especially after hitting the brake pedal? It will be a humming of an electric pump coming from the area of the master cylinder, driver fender well area.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
