      11-22-2017, 03:18 PM   #1
Exclusivs
Exclusivs's Avatar
Question Low profile floor jacks?
In search of low profile jack able to fit under front bumper of lowered car to center jack point. If impossible.
Thanks in advance
      11-22-2017, 08:35 PM   #2
VictorH
Drives: '09 M3
AC Hydraulic makes some really nice low profile floor jacks. They are a bit spendy as I think they are imported (not from China) and of course they've gone up in price over time. I've had mine at least 10 years and they are super reliable even with lots of use.
http://www.pelicanparts.com/cgi-bin/...n=ac+hydraulic
      11-22-2017, 10:10 PM   #3
pbonsalb
Drives: 08 E90 M3, 99 E36 M3 Turbo
AC is good but expensive. Arcan makes a low profile long reach but I dont know if it is long enough to go to the center. It is about 1/3 the price and gets good reviews. I have a lift but if I need to jack, I just jack one front side point and that lifts the car enough to fit any jack under the front or sometimes I just jack the two front side points. I have 2 of the $59 1.5 ton HF aluminum jacks and one $79 steel 3 ton Michelin jack. Had them for years.
      11-22-2017, 10:24 PM   #4
Exclusivs
Exclusivs's Avatar
Originally Posted by pbonsalb View Post
AC is good but expensive. Arcan makes a low profile long reach but I don’t know if it is long enough to go to the center. It is about 1/3 the price and gets good reviews. I have a lift but if I need to jack, I just jack one front side point and that lifts the car enough to fit any jack under the front or sometimes I just jack the two front side points. I have 2 of the $59 1.5 ton HF aluminum jacks and one $79 steel 3 ton Michelin jack. Had them for years.
Might be referring to this one that I was just looking at
https://www.northerntool.com/shop/to...SABEgIKZvD_BwE
I'm unsure myself distance from front bumper to center jack point. Anyone want to volunteer and get the measuring tape?
      11-22-2017, 11:42 PM   #5
pbonsalb
Just get down on the floor and measure. If I had the guess, that arcan is 36 long and the lift arm part maybe 23. Its tapered at the handle end so maybe it can reach under 24-26. Just guesstimating.
      11-23-2017, 01:27 PM   #6
roastbeef
roastbeef's Avatar
i have yet to see someone talk about a jack that reaches our center jacking point on this forum. i have also fantasised about this. lol.
if you have two jacks, you can use one to jack up one side, then slide the other jack under the center point....
      11-23-2017, 10:56 PM   #7
White 13
Drives: A 2013 Alpine White E92
I bought a 2x10 and cut it up to make a pair of ramps.
      11-23-2017, 11:28 PM   #8
pbonsalb
I have a lift and still need ramps for my lowered cars. I use a 2x12 cut into 4 pieces to raise the car about 1.75 inches. Might help with jacks also.
      11-24-2017, 09:57 AM   #9
Exclusivs
Exclusivs's Avatar
Suppose Race Ramps then get to center jack point will work.
Raise rear front there
      12-28-2017, 02:47 PM   #10
piesauce
Drives: 2018 | BMW M2 | 6MT [Pending]
https://www.floorjackshop.com/the-be...jack-reviewed/
Here's some reviewed. I doubt any of them will reach the distance to the center jack point.
piesauce
      12-28-2017, 04:19 PM   #11
spazzyfry123
spazzyfry123's Avatar
Drives: JTR
2011 BMW E90 M3  [5.00]
I drove up on boards and used a generic floor jack to reach mine while helping out a fellow M3 Post member a month or so ago in the parking lot. Reached the center point pretty easily and dropped it on a couple jack stands.
      12-29-2017, 08:52 AM   #12
ebisu8
ebisu8's Avatar
Drives: ///M
I haven't found a jack that would fit under there especially if you have a front lip. I just jack it up from the rear one side at a time to get the front stands on then I jack from that center point.
The other way is to get a few boards cut up that you can drive on to give you enough height to reach that center point.
      12-29-2017, 11:40 AM   #13
pbonsalb
I would either drive up onto a couple of 2x12 buy a 6 footer and cut at a 45 degree angle to make a ramp onto the plank. Or buy a 12 footer and cut into 4 for all wheels I have this for my lift. Or use 2 jacks - one to lift a front side to make space to get the other under the middle. Or just jack both front sides.
      12-30-2017, 12:55 PM   #14
M43S7RO
Drives: Jerez Black E92 M3
Ditto, I drive onto 2x12 planks which allows me to get a pittsburg low profile jack to the center point.
      01-09-2018, 09:19 PM   #15
Exclusivs
Exclusivs's Avatar
I'm still searching for the right floor jack to buy...
Guess the Pittsburg low pro works, im hesitant to go anything HF though?
Suntex has a pretty low pro 2 ton - will have to find some work around....
AC Hydraulic ... amazingly nice. Hefty price tag
      01-10-2018, 10:21 PM   #16
aussiem3
aussiem3's Avatar
Australia
235
Drives: Goggomobil
2007 E92 M3  [0.00]
I will post a pic on the weekend. I bought a low profile jack from NA and had it shipped to Australia. It will easily slip under the front of the car to reach the jack pad. The only issue is when the rear of the car is on ramps. Then the jack doesn't slip under the nose. Then I slip it behind the front wheel to reach the jack pad. It has served me well over the last 12 years. It's white in colour. I will check the brand and update this post.
E92 M3 2007 - ///PE with Test Pipes and BPM Stage II; CF Interior & Splitters; CIC with Connected Drive
      01-10-2018, 10:26 PM   #17
Exclusivs
Exclusivs's Avatar
White jack...hm doesn't ring any references in my mind I can think of.
12 years old? Hope you've serviced it well
      01-10-2018, 11:17 PM   #18
slicer
slicer's Avatar
Drives: '13 E92 M3 - '17 F31 330i
I use the 3"" trak-jax from race ramps which fit under the lip of my lowered car. I have a Compac jack which I got from Reverse Logic. The Compac is more than long enough to reach the center jack point. It's heavy and not cheap but very high quality. Really solid and trust worthy jack.
https://www.reverselogic.us/jacks---lifts.html
'13 AW E92 M3 - Ohlins TTX, SPL Susp Arms, AP Racing BBK (Essex), Akrapovic GT4, CSF Cooling, VPhreaks Bat, OE M3 GTS - Lip/RSD/Cage, M235ir Wing, Varis Diffuser, Karbonius Airbox, MFactory DS, M24 Door Cards, KMP Wheel, Cobra Seats w/BK Mounts, BBS E88
'17 MR 330i F31 M-Sport Touring - For Lease Assumption - Forged BBS RE - For Sale
INSTAGRAM - @Slicer_M
      01-10-2018, 11:27 PM   #19
Exclusivs
Exclusivs's Avatar
Any reason you chose over AC Hydraulic?
I specify AC because roughly same price category and almost "gold standard" of floor jacks. Thanks for posting this will have to read more on them.
      01-11-2018, 07:39 AM   #20
pbonsalb
5 inch frame height on that reverse logic is huge. You have to go on boards or ramps to use it. But if you go on boards, you can use a $59 Harbor Freight 1.5 tin aluminum jack or pretty much whatever jack you want.
      01-11-2018, 10:26 AM   #21
slicer
slicer's Avatar
Look more closely. The jack has a 3" saddle height which is the point that needs to get under the car to lift it. I actually remove the rubber pad shown in the picture below to get under my jack point without ramps. I'm not aware of a jack with a lower saddle height. Further, no matter what jack I use (I have had others), I need the race ramps if I want to get to the center jack point. My car has about 3.5" of ground clearance. Please let me know if there is a floor jack in existence that is 3" tall across its whole length. Further - check out the pic below comparing the Compac to a Craftsman jack. I think a frame height of 5" is lower than the Craftsman and most other floor jacks. Lastly, I agree that with ramps you can use almost any jack to lift at the center jack point. In fact, I think I was able to use the craftsman jack in the pic below to lift my car. However, the Compac's extra length allows me to get under the car and still use the entire lever range. Plus it's a lot more sturdy and higher quality. Some might not care about that.
      01-11-2018, 10:28 AM   #22
slicer
slicer's Avatar
No reason other than Reverse Logic was a board sponsor at the time. They make jack stands that slide into the OE jack points. No regrets on the Compac jack. The quality is top notch.
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
