View Poll Results: What direction to go for suspension? | |||
Ohlins R&T- upgrade springs/sway bars | 17 | 54.84% | |
Go with new 3-way COs | 14 | 45.16% | |
Voters: 31. You may not vote on this poll |
03-08-2016, 12:50 PM | #1 |
Assistant to the Regional Manager
27
Rep 149
Ohlins R&T-- upgrade springs or go to new set up?
Been tracking with the Ohlins for 2 seasons now with factory rates (342/684), I never really noticed a huge difference over stock, was on EDC dampers with Eibach springs previously. Car did handle rebound a bit better but did not feel all that much stiffer on track. As I've progressed as a driver I am starting to feel where individual rebound/compression adjustment might help- on inclines where the car gets light, tight series of turns, over FIA curbs, etc.
Car still sees normal roads on sunny days + 10-12 track days a year, but my 4runner has turned into my dd these days. Ideally the car still needs to be compliant on roads for occasional drives down the coast but also needs to be stiffer/more aggressive on track. So I see it this way- Option 1- Upgrade to Swift Springs (448/784) and maybe upgrade sway bars (E93 or RD sport). Option 2- Bite the bullet and purchase new 3 way set up (KW CS 3-way, Ohlins TTX, JRZ RS-Pro). Possibly add sway bars but I'd like to see how these feel without first, especially for the price. I believe labor costs will be roughly the same with either option so I'd like to do this once. Any insights would be great, especially from those who upgraded their Ohlins R&T and from those who have swapped out COs to a more aggressive set up!
'08 E92 M3 DCT, AW on Fox Red
03-08-2016, 06:31 PM | #2 |
281
Rep 7,518
We would recommend a JRZ/Swift spring setup. We've actually have had a few customers switch from Ohlins to JRZ and preferred the JRZ's. We personally as well like to use JRZ/Swift setups on everything we can.
03-09-2016, 09:27 AM | #4 |
Rep 3,742
I never tracked on my Ohlins but I can say that my KW Clubsports only feel ever so slightly less compliant on the street than the Ohlins but you can tell body roll has been drastically reduced and overall the car feels much lighter and sharper on its feet.
I imagine JRZs feel awesome but I can't justify those for my level of track use at this point. Sounds like you can, though. |
03-09-2016, 10:18 AM | #5 | |
Rep 1,679
03-09-2016, 02:30 PM | #7 | ||
27
Rep 149
03-09-2016, 03:18 PM | #8 | |
27
Rep 149
03-09-2016, 03:22 PM | #9 |
Rep 1,679
Mine came 550/750 from JRZ. When my car saw dual duty it was AMAZING on the street (and track). I've since upped the rear rate since I now have aero.
03-10-2016, 03:48 PM | #10 |
Rep 3,742
2-way. Street compliance will only get better with the 3-way, of course, since you add low-speed compression control.
I will say that, IMO, the single biggest factor in the performance of a coilover system is proper setup. I would take a properly set up lower-cost coilover system over an incorrectly set up expensive system all day long. I had my Clubsports installed and dialed in by MRF Engineering and everyone I know who has had their suspensions setup by MRF have been very pleased with them. Not sure that is a realistic option for you given that you appear to be in WA, but just throwing that out there in case you are planning a trip to SoCal. |
03-10-2016, 08:01 PM | #12 |
Rep 2,672
Option 2! You can sell your Ohlins to offset the cost. I might also consider MCS, fan of JRZ also.
03-11-2016, 03:03 PM | #13 |
Rep 1,711
I have Ohlins R&T on my E92M3 and don't understand bad rep of these coilovers on this forum
I have been tracking my car with Ohlins for two seasons now and I love it. Is it as good as other more so called track oriented systems? Maybe, but I have been going against similarly prepped e9x m3 cars with MCS, JRZ, KW clubsports in the advanced groups and never had to give them a point by yet. |
03-11-2016, 10:05 PM | #14 |
Rep 2,492
Hey there, I actually was in the same boat, actually upgraded the springs to a 448/784 swift setup (i ordered direct from swift, and vorshlag and saved quite a bit of money over some of the quotes i got on here) wound up like 350 out of pocket for the upgrade. I had the stock ohlins on when I was dailying the car, and they served that purpose great for double duty.
Even then, that setup left me wanting a little more (specifically on the track, street it was a friggen awesome setup), especially on the front end of the car. I immediately noticed more oversteer as it firmed up the rear end of the car a bit, which I was ok with. I noticed the front of the vehicle started pushing quite a bit on fast sweepers at Roebling Road (look up track map for details). I sold the ohlins, and switched to a 2 Way clubsport setup, and, while still livable on the street, they are better on the track. Can you get good performance out of the ohlins on the track? You bet. But for an equal trade off (I wound up breaking even), I would look towards the clubsports. My .02 from a guy who went through the same thing you are! Let me know if you have any other questions.
2010 E92 M3 DCT
03-12-2016, 03:46 PM | #15 | |||
27
Rep 149
03-12-2016, 03:47 PM | #16 |
27
Rep 149
But it specifically states, "& Track" in it's name!
03-12-2016, 03:51 PM | #17 | |
27
Rep 149
06-05-2016, 11:13 AM | #18 |
Rep 254
I have ohlins with upgraded springs on my s2000. I upgraded to custom built penskes and it was night and day, this also with full monoballs, cage, r7's...
Just got a set of ohlins for m3 (DD), I may use it to sneak out to the track for a DE day sometime without wife knowing (a lot easier to sneak out to track without tow car, trailer, and missing race car from garage lol). I'm curious to compare how it does with the ohlins now... |
06-07-2016, 01:04 PM | #19 | |
27
Rep 149
My car had EDC and I had Eibach springs on there with the OE dampers. I can feel a little difference with my Ohlins R&T but quite honestly it's not night and day like you described with the S2000 (are you one their race line/ttx line?), but I was sure hoping it would be. I'm also getting about -3.0 front camber with the new camber plates so that alone probably accounts for half of the increase in handling. That being said they are still great on the rough streets around Seattle. But I also don't see many who went with the Swift springs on the Ohlins saying that made a huge difference either. I miss the ease of adjustability with the EDC button, it's almost worth the slight increase in handling to just have that back, for aggressive street driving at least. I'm not really that keen to pull over several times and twist knobs for a few hours drive. Not an issue at the track since I'm swapping tires anyways
03-08-2019, 02:39 PM | #20 |
Rep 553
are the swift springs linear rate and straight? I'm looking for a set of springs that will make my Ohlins compatible with this air cup front end lift kit (https://www.outcastgarage.com/produc...nt-air-cup-kit). I'm tired of going through front end splitters.
03-18-2019, 02:40 AM | #22 | |
Rep 1,617
