02-11-2018, 03:22 AM | #1 |
Rep 20
Misfire in cylinder #4 remains
Hi all fellow M3 owners.
I have a 2007 with 64000miles/107000km. Started getting a CEL some time ago and reading the code says misfire in cylinder #4 and #6. Tried to swap coils and failure went to #1 and #6 once. Next say back to misfire in #4, and now only #4. Car goes in limp mode when idle but stop/start a warm engine I managed to get above 2500-3000rpm and car is running perfectly fine up towards the limited (I stop at around 6000rpm as I know there is something wrong). I replaced all 8 plugs and bought brand new OEM coils from BMW and put that into #4. Car goes OK for a day, the back to limp mode next morning. Code is still misfore in #4. Yesterday I took all injectors in left bank (passenger #1-#4) out and swapped #4 with #1 and well as cleaned the seat as it was full of debris. Cleared the code, car stands idling for 20 minutes with no problem and I took a 20-minute drive to a friends house, stopped it for 45 minutes and when starting again it goes back in limp mode with misfire in #4 as usual. When having the plenum off, I got my wife to turn the ignition on and press the right pedal, all trottlevalves are cooperating as far as I can see and while doing this manually I see no slack from the TA`s or any deviations between #4 and the others. I am out of ideas and might send it off to someone that can inspect the electronics.. Any other suggestions for another try back home is highly appreciated. Budget had a rough 2017 with new crank, rod-bearings, clutch and flywheel |
02-11-2018, 10:59 AM | #2 |
Rep 1,535
If you had all that troubleshooting then the next probable cause would be a bent valve. it is not a common problem but I have seen few e90X M3 with this problem.
02-11-2018, 11:22 AM | #3 |
Rep 3,140
Drives: 2014 M5 6MT
Agree with the above, and or a weak/broken valve spring. You need to do a compression test on that cylinder, followed by a leak down test.
2014 M5 6MT
Honda288.50 |
02-12-2018, 05:23 AM | #4 |
Rep 20
Ok, thanks for replies and suggestions..
What is wierd is that, like this morning with a lot of snow during the night, I started the car and let it idle for 10ish minutes and I can hear some misfiring and suddently goes in limp mode while I was removing some snow outside of the car. The exhaust sounds much better in limp mode but car is shaking a little. I got into the car, stopped it and started it again to reset the limp mode. I kept it on 1500rpm and suddently it"relaxed" with smooth running and smooth idle again. Same thing happens when driving that I need to push it above a certain limit to run smooth but this time it was like a switch. I have a weak tought that it got something to do with the airpump for the cold start but this I can code to not start at all? When I drove away this morning it was all fine, no misfiring after the restart in the morning.. If it was a valve or valve-spring, this issue should be there 100% of the time right? |
02-12-2018, 06:33 AM | #5 |
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
If the issue is mechanical it should remain all the time, rather than coming and going. A bent valve isn't going to restraighten and rebend, and weak springs will remain weak and valves will continue to close more slowly than normal until the spring is replaced.
02-12-2018, 07:40 AM | #6 |
Rep 3,140
Drives: 2014 M5 6MT
This is starting to sound like a sticking vanos solenoid to me
2014 M5 6MT
02-12-2018, 09:16 AM | #7 |
Rep 1,148
Solo_M_Tech1687.50 |
02-12-2018, 01:58 PM | #8 |
Rep 65
what exactly is the CEL and are there any others that you have or had since you erased them? have you done a compression test of cylinder four? Is this all from the same tank of fuel? maybe you got some bad fuel? Do you have a multimeter. You can voltage check and resistance check the injector harness and the injector itself. If you can swap coils and plugs then injector is just as easy, swap cylinder 4 injector to cylinder 2 and see what happens? Anything else wrong, burning oil? leaks?
02-13-2018, 01:50 AM | #9 | |
Rep 20
I had several tanks with 95 since this problem occurred so bad fuel isn`t the thing I am pretty sure. I swapped injector #4 with #1 last weekend but problem remains in #4. I will do an oil flush asap using OMEGA 907, one bottle and idle for 1 hour as some other BMW tech advised me to do. One bottle goes to 3 litre, the engine have about 12-13 liters but service changes only 8,8 litres so to avoid having too much flush left in the hoses and cooler he suggested to use one bottle and extend the time for idling. I have no leaks, no heavy oil consumption out of normal. |
02-13-2018, 08:40 AM | #10 |
Rep 65
it must be a Troll then.. little guys get everywhere and cause havoc.. JK
Well. I'm afraid we don't seem to have enough information at this point for a conclusive answer.. To me it sounds like ignition related electrical but you would have to test power and resistance at the harness for the coil and the injector to be sure if one is not working as it should, since you already replaced the injector, coil and plug. Since you dont have a compression or leak down tester that fits and cannot test the mechanical as a result. I would hope you have a multimeter and can check those things at the harnesses. At least it would give you the direction to chase, if your coil harness is not getting signal for example to fire you know to check the wiring or the control module or any system that would tell the control module not to fire on cylinder four. I had a similar issue in a VW vr6 and it was the ignition control module, but similar does not mean identical problem. Have you tired a fuel system cleaner? Something like a product we have here called "Sea Foam" works very well. Great to add to your oil system flush just before you do that about two tanks of fuel a few weeks before to clean out the whole fuel system very well. |
02-15-2018, 08:35 AM | #11 |
Rep 20
I tried a injector cleaner from STP on 1/4 tank for higher consentration with no difference.
I will remove all 4 vanos solenoids for inspection this weekend and switch bank 1 with bank 2 and see what happend. I will also do an engine flush adding OMEGA 907 in the oil and flush it before adding fresh castrol 10w60 edge oil. Thanks so far |
02-17-2018, 11:45 AM | #12 |
the me
342
Rep 318
have you done a compression and leak down test?
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else 21 M2c Coupe ,DCT, SOM, not much else |
02-18-2018, 04:18 AM | #13 |
Rep 20
not, yet but will have it done shortly. I`ll keep you updated.
Same thing happened to another car here in Norway with fresh built lower part with new crank and rod bearings. Could we have missed out on something related to both engines being out, bottom part separated and assembled again with new crank, new bearings, new clutch, new flywheel++? |
02-18-2018, 06:16 AM | #14 |
the me
342
Rep 318
I had a broken valve spring that caused intermittant issues. Hard to believe. The leak down test finally proved the issue
02-18-2018, 07:04 AM | #15 |
Rep 1,535
03-03-2018, 02:51 AM | #16 |
Rep 20
Had it at BMW workshop yesterday and the did a compression test - OK.
System diagnostics - OK After 6 hours they did not manage to detect the fault. Next steop for me now is to pick up the car, take it home and swap places for the two AUS (exhaust) vanoses to see if the fault moves from #4 in bank#1 to somewhere in bank #2. That includes new seal rings and new bolts. I have the camshaft locking tools OEM |
IanB229.50 |
04-12-2018, 02:04 PM | #17 | |
Rep 832
Check my recent post it is exactly what’s happening to you. |
05-22-2018, 11:49 AM | #18 |
Rep 20
Hi guys
Finally got things back together. I was a little too querious about how the vanoses looks like internally as google haven`t done it before so I opened both exhausts but cracked the cover. Got a good deal on 4 "new" one from Mporium BMW "over there" in hope to get rid of the cold start rattle. Paid 1k for all 4 incl shipping to norway, they came off a 51k miles car with a collision damaged bottom part. Got photos from before they was removed and all looked fine. So, I started assemble the engine with new sealing rings on both exhaust cams, new o-ring inside vanoses, timed the engine with OEM cam-locks and new stretchbolts, swapped exhaust cam sensors from bank 1 to bank 2, swapped soleniod valves, all coild numbered and back in original position. Fired it up and -------------- nah, same hard start not idling nice and after a few seconds -> limp mode. This time in cylinder #2 WTF? If it only had moved over to bank 2 it could have been a soleniod or cam sensor. I am really starting to think this could be some remap or other electrical issue. Anyone have any suggestion as I am totally lost over here in Norway now. Not any good S65 mechanics in this country I`m afraid. Thanks in advance |
05-23-2018, 06:49 AM | #20 |
Rep 20
I numbered them so it was exactly the the same position as before when #4 had the issue.
I swapped yesterday coil in #2 with #1 with no luck. I`ll try today to swap both coils and plugs and see if that helps |
05-23-2018, 01:21 PM | #21 |
Rep 2,907
Drives: 2011 E93 M3
Do you have BMW ISTA-D to be able to help with diagnostics?
05-26-2018, 02:57 AM | #22 |
Rep 20
I`m trying to book an appointment with local BMW to get a software update but doesnt seem like they are keen on seeing my car again. They have too many hours under the hood and still cant figure out whats wrong. Just giving me advices of what I can/should try at home.
I paid for all their work but still... |
