12-19-2019, 10:32 PM | #1 |
Rep 14
WTB e92 manual in 2020
Hi everyone
A newbie here and looking to buy an e92 manual in early 2020. Looking at Carsales it seems most are 2007/08..... Hoping for a 2009+ manual so the rod bearing issue goes away. Any insight here why there's so little number for sale? |
12-19-2019, 11:48 PM | #2 |
Rep 254
all e9x m3 model years are affected by rod bearing issue. only way to minimise the risks is to get it done after purchase or buy one with rod bearings already done. I'd suggest you base your search on low kms instead.
M3e9x_Aust0.00 |
12-20-2019, 04:31 AM | #5 |
Rep 794
12-21-2019, 09:32 PM | #7 | |
Rep 1,464
Drives: BMW X5M Comp
Its here https://www.carsales.com.au/cars/det...yYdeJQqxsN6b5E |
M3e9x_Aust0.00 |
12-22-2019, 05:06 PM | #9 |
Rep 1,464
12-23-2019, 05:44 PM | #10 |
Rep 8
This 2013 model in manual looks like a good example of what you may be looking for:
https://www.carsales.com.au/cars/det...-6387335/?Cr=0 |
M3e9x_Aust0.00 |
12-23-2019, 10:04 PM | #11 |
Rep 14
Yeah this one definitely has the spec I am after.
Though it is interesting that it's almost priced at double the price with a similar mileage: https://www.carsales.com.au/cars/det...SSE-AD-4734961 If the rod bearings issue is across the board I wonder if it's better to get a cheaper one (perhaps 2007/08), replace the rod bearings and throttle actuators as opposed to get a overpriced newer version. |
12-24-2019, 12:24 AM | #12 |
Rep 183
The 07 Grey is very good value. Good colour combo in my opinion.
I would suggest get the cheaper one and do all the preventative maintenance. It will always play in your mind whether it is 07 or 13. And besides the comp pack and idrive, they are pretty much the exact same car. Good luck mate.
2008 BMW M3 | 6MT | OEM Exhaust Mod | Black Grilles | |
12-24-2019, 05:35 AM | #13 |
Rep 72
I know there's a big price difference between the two, but I would tend to stretch the budget to the 2013 model. There are a number of subtle improvements in the LCI from 2010/11 onwards such as improved iDrive with higher res screen, LED tail lights etc.
Also manufacturers tend to fix and improve little things along the way. I think the rod bearings have an improved tab to help prevent them spinning when worn. Another factor is how long you intend to keep it. The purchase of a recent build tends to future-proof the purchase somewhat for a long period of ownership. |
12-25-2019, 08:05 PM | #14 | |
Rep 104
But I do agree with you, in terms of buying closer to 2013 than 2007. A PRE LCI ain't no lci and worth the premium. But buy on condition and do a ppi Happy hunting. PS If I was buying today with an eye on the future and the other on the budget, I would be after a 2013 pure with low km's in white and carbon fibre factory as much as you could get and negotiate hard( need about 5k to sort out those tweaks above. I would do those mods all day every day before any preventative work such as rod bearings ( how many low km's 2013 m3s had the rod bearings grenade a s65 motor as a percentage of all 2013's manufactured) just service regularly and don't flog the motor shortly after a cold start. Throttle bodies are a non event. Just replace / fix if they ever go at the time. Also seems you won't be going there, but beyond those subtle tweaks mentioned above,if you think 450hp ain't going to cut it, just buy a supercharged example already done from the get go if you value your hard earnt. Last edited by BMWM3TS; 12-25-2019 at 08:11 PM.. |
