04-05-2017, 12:52 PM | #1 |
Rep 137
BW Powersteering fluid reservoir
Has anybody been using, or used the Bimmerworld PS fluid reservoir? It looks nice, but I noticed it doesn't come with a filter, or anyway to check the fluid level.
Just looking to see if it helps, or works. I have a CSF cooler, but the stock reservoir obviously still doesn't work. Looking for feedback on this, not much during the search.
'18 GT3 - 6MT
'13 E92 M3 - street/track '07 Cayman S - track car '15 FRS - Sprint racecar '00 Miata - Enduro racecar |
04-05-2017, 01:02 PM | #2 |
///M Powered for Life
11480
Rep 10,328
I have it on the E92 M3 which has seen two 'double tracked' seasons and has all stock radiators.
It works great. It's vented like the OEM one but has never sprayed any crap all over the engine bay There is no filter which is a downside, but I replace the fluid every year anyway because it gets black (with or without filter) As far as level, you should leave it right above the metal mesh it has inside. |
DrFerry6728.50 |
04-05-2017, 04:44 PM | #3 |
Rep 137
Sweet, exactly what I was looking for. I already have it in hand, just wanted to see if anybody else used it.
I too was initially concerned about no filter, but I would replace the fluid yearly anyway, so no big deal.
'18 GT3 - 6MT
04-05-2017, 05:23 PM | #4 |
Rep 1,286
I have one too, no issues and works great. My experience however as it relates to the optimal fluid level is a bit different. When I ran it just above the grate I would have a noisy PS pump when coming off the track, filled it up to about 3/4 full and no issues at all and noise is gone. It does hold a lot of fluid so I'd suggest buying two cans of PS fluid. You won't use all of both but you'll get a ways into the second can.
SYT_Shadow11479.50 |
04-05-2017, 09:53 PM | #6 |
11480
Rep 10,328
This and the BW precision front control arm bearings have been on the car for two years and have worked perfectly. I'm impressed with both pieces!
04-06-2017, 09:40 AM | #7 |
Rep 137
I have those FCAB's too, and they are great. No difference on street, but great on track.
'18 GT3 - 6MT
04-06-2017, 09:48 AM | #8 |
11480
Rep 10,328
ha awesome
04-06-2017, 12:54 PM | #9 |
IG: @dj_dub
1803
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
Thanks to the feedback in this thread, I think I may pick one of these up very soon. How is the install on these...pretty straightforward? Anything to be aware of? TIA
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
04-06-2017, 12:56 PM | #10 | |
11480
Rep 10,328
Then you move the rubber bushings from the old one to the BW one. Make sure you tighten the hoses on the BW one, then refill the fluid. That's it! |
dj_dub1802.50 |
04-06-2017, 12:57 PM | #11 | |
11480
Rep 10,328
The fluid degrades quite quickly on the track, it's disappointing |
04-07-2017, 01:25 PM | #12 |
Rep 137
Install was a breeze. I like how they switch the routing so the bigger hose, which is the feed to the pump, is now on bottom, and the return is now the top.
That makes more sense.....so that in high g-load corners, you can't more easily starve the pump. No wonder these cars go through PS pumps all the time. The stock orientation is kinda silly. They obviously knew it too, as the subsequent stock units on the 1M and beyond all use the same bottom mount feed location as well.
'18 GT3 - 6MT
04-08-2017, 11:05 AM | #13 | |
11480
Rep 10,328
04-11-2017, 05:34 PM | #14 |
Rep 6,218
is it that much better than a sock? lol
04-11-2017, 09:35 PM | #15 |
Retired Curmudgeon
2985
Rep 4,047
All the cool guys zip tie a blue shop paper towel around the top of the reservoir. Chicks dig it.
M3 Number 863221.00 |
04-12-2017, 07:45 AM | #17 |
Rep 137
I don't know how much "better" it is than a sock, but what I do know is that for the 1M, and every other 3-series, the new OEM design puts the pump feed line on the bottom to avoid any potential pump starvation and better flow.
This is the same line arrangement on the BW piece. It just makes more sense. I just wanted to avoid running a "low" level on the stock reservoir to avoid overflow, like many do. Based on the ridiculous amounts we spend on everything else, $165 for a reservoir that works just makes sense to me. The sock does not adequately address the issue IMO.
'18 GT3 - 6MT
04-12-2017, 11:13 AM | #19 |
Rep 5,483
I have had my PS pump growling at me after a long on-ramp before even with proper level, never understood the stock arrangement other than "that's how we've always done it"-itis
04-13-2017, 02:32 PM | #20 |
Rep 280
Drives: M2 F87, M3 E92 & E46, C63, 911
Garage List 2018 BMW M2 F87 [0.00]
2008 BMW M3 E92 [0.00] 2003 BMW M3 E46 [0.00] 2012 BMW M3 E92 [0.00] 2011 Merc C63 AMG [9.00] |
i just copied the gt4 solution
http://www.m3racing.de/e92umbau.html#5 |
04-13-2017, 04:24 PM | #21 |
IG: @dj_dub
1803
Rep 1,452
I also use a sock/sweatband to catch the overflow, works just fine. However, I just ordered one of these...the selling point to me was the correct arrangement of the feed line at the bottom. Makes complete sense. The price is also makes this a no brainer.
05-11-2017, 09:05 PM | #22 | |
Rep 405
Are there part numbers for this? Thanks in advance.. |
