10-23-2020, 11:49 AM | #1 |
Rep 1,041
disadvantages of removing cold start from a tune?
Are there any disadvantages to removing cold start from a tune?
The things that come to mind as possibilities are reduced cat life, and longer warmup times. I'm planning to go supercharged soon, and in the process will likely having cold start deleted. I'm not planning on running test pipes or removing the cats, so I want to ensure I am not going to negatively affect cat life by doing this, or increase engine wear by making it take longer to warm up. Thanks. |
10-23-2020, 12:32 PM | #2 |
Rep 5,484
I am not a doctor, but I don't think cold start cycle does anything at all to warm the car faster, that's more a high idle thing, and I would think reduced life of cats just from shoving 20-30% more exhaust flow through them at WOT, and possibly at a richer mixture/richer idle due to the bigger injectors, is a much bigger factor than whether or not they light off 20-30 seconds quicker thanks to the cold start still being there
10-23-2020, 01:11 PM | #3 |
Rep 552
Like Richbot said, it only is used to bring the cats to operating temperature faster. I've been running a cold start delete for several years with no issues. I am running Akra Evo exhaust so it has high flow cats anyways. My oldest appreciates it since before the cold start delete the exhaust note would vibrate her bedroom floor as she's right over the garage.
10-23-2020, 01:21 PM | #4 | |
Rep 1,041
Totally get that increase in fuel from the supercharger will affect cat life. Just wanted to make sure that the cats taking longer to come up to temp wouldn't cause any unintended side effects. |
10-23-2020, 01:51 PM | #5 |
Rep 3,331
Yup, the $500 for the Alpine tune to delete cold start was 100% worth my wife not complaining about it. When I first got the car cold start + the Eisenmann Race would shake the whole damn house inside the garage.
Back with the stock exhaust and no cold start I left the other day at 5AM and asked if I woke her up and she said nope, so I'm golden.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
10-23-2020, 02:20 PM | #6 |
Astronaut
514
Rep 732
Cold start delete is 100% worth every dime.
The cold start cycles are so damn annoying. Especially when you turn off an already hot car, just for it to cycle again when you start it up 30 seconds later. I've been running it for over a year now with zero issues. |
10-23-2020, 02:29 PM | #7 |
Rep 1,041
That has always perplexed me. Why in the world does cold start kick in if the car is already hot? It almost seems like cold start runs longer if its already hot too. Makes no sense.
10-23-2020, 02:55 PM | #8 |
Rep 2,159
I tried both maps with and without cold start, and I noticed that with HFCs the car smelled a lot less when I ran the cold start procedure. :
10-23-2020, 05:46 PM | #10 |
Rep 11,667
It's purely an emissions thing to warm up the primary CATs as mentioned.
Part of this cold start cycle is the air pump which also helps the CAT's performance. The question I haven't talked to a tuner abut yet is, does the cold start delete also remove the air pump error code if it is removed. |
chocstraw495.50 |
10-23-2020, 11:49 PM | #12 | |
Rep 279
Cyberdemon1537.50 drwankel1031.50 |
10-24-2020, 12:59 AM | #13 | |
Rep 1,457
Drives: 2023 G81 M3 Touring
10-24-2020, 01:16 PM | #14 |
Save the Manuals
1714
Rep 2,937
I consider the CSS as a huge bonus with the installed Corsa exhaust. Gets the adrenaline going when I start the car which is what it's all about.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
10-25-2020, 12:57 AM | #15 |
Rep 2,747
Hated cold start with already obnoxious exhaust system, so had deleted with no cats. this time opted to keep it with more civilized system with HFC.. I do like it, it's a bit dramatic but there's something very satisfying when you can hear the air valve closing and it gets all quiet and smooth and the idle seems to slow a bit and the oil pressure starts coming down.
9ers
10-25-2020, 12:05 PM | #16 |
Rep 65
I'm running a Dinan mid pipe(4resonators no cats) with an ACM modded OE muffler and the cold start sounds fANTASTIC!
BUT is loud enough it shakes out house AND the neighbors! And on the freeway it is loud enough you have to talk loudly with passengers and/or crank the stereo. I've got to make a change... Thinking I'm going to go CSD and then a muffler swap to balance things out. That said, I am apprehensive that it will take the excitement out of the wonderful S65 experience.
'12 E92 M3 ZCP Ruby Black Metallic, BBS E88, Ohlins R/T, Eventuri, Dinan exhaust, Tune +36whp, S752 + JL Audio XD1000/5 & 12w6v3, Dinmann |
10-26-2020, 07:48 PM | #17 | |
Astronaut
514
Rep 732
Cold start is annoying and I usually kept my valves closed before I deleted it. With the valves open, it's louder than a straight piped C7 corvette
Instagram | @undisclosedm3
"Never think that you are above taking out the trash." |
