09-24-2020, 08:50 PM | #1 |
OG
217
Rep 696
Excessive rasp from Bimmerworld X Pipe or is this normal?
After reading a bunch of reviews and watching all the videos I could find I pulled the trigger on a BW x pipe. Sadly I'm extremely disappointed with the low rpm metallic rasp that my car has now. I read that there was a bit of rasp associated with the BW x but I didn't imagine it would be this bad. It sounds metallic, like something is loose, but I've had two shops look at it and same results. Is this normal or is there something else going on here? Rear end is a Dinan which never made this noise before the new x pipe install.
The rasp only happens between 2000 and 2700 rpm, sounds great before and after that. Don't hear it on very light throttle/load or revving it in neutral, but the moment I get on it a little more at that rpm it's pretty bad. Anyone else experience this or have seen this with the exhaust combination? |
09-24-2020, 08:58 PM | #2 | |
Rep 3,408
09-25-2020, 09:20 AM | #4 |
Rep 4,155
Completely normal for catless unresonated x-pipe. That said, your rasp sounds a bit more tinny than my exhaust (non-BW). If you wanna get rid of it just put in some resonators. Or drive above 3k like I do. Lol
09-25-2020, 09:22 AM | #5 |
///M Powered for Life
11469
Rep 10,328
Did you get the completely unresonated one?
Even the resonated one has relatively small resonators. If you dislike rasp you may need to add a couple. |
09-25-2020, 02:22 PM | #6 | |
OG
217
Rep 696
I want to keep it because it clearly makes power, but that may mean having to change the rear portion. Adding another set of resonators is a good option too, may be the easiest way to go, but I'm worried it won't really fix the issue. |
09-25-2020, 02:35 PM | #7 | |
11469
Rep 10,328
I hear the resonated one quite often as two friends have it and it sounds fine to me, but different rear sections and different tastes make the final experience different to different people |
09-25-2020, 02:39 PM | #8 | ||
OG
217
Rep 696
What rear sections do they have? |
09-25-2020, 02:49 PM | #9 | |
11469
Rep 10,328
You could also just add the extra resonators to the primary cat area. This is what ESS sold with their 4 resonator xpipe back in the day |
09-25-2020, 04:24 PM | #10 |
Rep 14
I have the BW resonated X-pipe with a Gintani Race rear and I also have that loud metallic rasp at about 2000-2500 rpm. There's a noticeable difference above 3K but it really feels down on power below that. My car previously had AA test pipes with the secondary cats removed and it didn't feel bogged down below 3K like it does now. I am now switching to a MS X-pipe to see the difference.
09-25-2020, 07:24 PM | #11 | |
OG
217
Rep 696
I'm going to get dynoed later this week to see how much power this setup makes. Active Autowerke is close to me so I was just going to pick up their resonated xpipe and sell the BW. If I do go that route, I'll also dyno that setup and report back some numbers/comparison graphs and videos. There could be a chance to also dyno with a different 200 cell, normal x position x pipe, it would be really cool to get dyno numbers on all three and put a few questions to rest. |
09-25-2020, 08:01 PM | #12 |
Rep 3,980
The power loss / hesitation might be a tuning issue with a more free flowing exhuast.
Here is another thread about it, we got some logs to definitely confirm something is up. My tuner has also confirmed he makes no changes below 3k. So that could explain things. We need to get a tuner to look into it. https://www.m3post.com/forums/showthread.php?t=1716181 |
09-27-2020, 12:32 PM | #13 | |
OG
217
Rep 696
I'm really hoping it isn't something else like the car pulling timing due to knock. Only a dyno run log will confirm that. Will hopefully know soon. |
10-02-2020, 06:37 PM | #14 |
Rep 186
Drives: E90 M3, U11 X1
It's normal, unfortunately. I thought something loose was rattling at first. I bought new clamps for the rear because they're old and stretched out, so I figured they may help. Now I'm about certain they won't. I'm using the OEM exhaust still, so I'll see if anything changes with my Eisenmann sport when I throw it on.
10-04-2020, 08:15 AM | #16 | |
OG
217
Rep 696
I bought dual 12" resonators, should have them installed this week. I will report back with results. |
Gossypiboma542.00 |
10-04-2020, 10:19 AM | #17 |
Rep 1,195
Yes, very interested in your results.
10-04-2020, 01:49 PM | #19 |
I got lei'd
844
Rep 7,593
I have rogue engineering test pipes and straight piped the rest ending with an iPE muffler. I know exactly what you're hearing OP but I don't get that at low RPM's I have to be about 4.5 and up and really on it. I thought it was normal, now I know it is, I like it.
10-04-2020, 05:15 PM | #20 |
Rep 143
I had that same concern with my BW X-Pipe. Added the same Vibrant 1792 resonators just down from the X and it cleared up most (but not all) of it. I might add HFC or another set of resonators in the spring summer, but I'm not convinced I need it yet.
2013 Fire Orange II E92 M3 ZCP
Bimmerworld (Quad) Resonated X-Pipe, AFe Stage 2 CF Intake, Carbon Project CF Plenum, Epic Motorsports Race Tune, Rogue Engineering Power Pulleys, Continental Extreme Contact Sport |
10-04-2020, 05:28 PM | #21 |
Rep 143
I also have a power dip at the same point in the power band where the engine feels like it's bogging
10-04-2020, 05:29 PM | #22 |
Rep 2,359
These cars are known for "resonance" around 2000 rpm, it is even stated in the factory manual (as normal phenomenon).
I think the "issue" amplifies if you go straight pipe. My setup makes a similar sound around that rpm range.
Pass me if you can.
SYT_Shadow11468.50 |
