09-26-2021, 01:47 AM | #1 |
Rep 163
Looking to trade a 2010 E90 M3 Jerez Black for E90 DCT. I'm looking for a car in similar spec. 6MT is fun as hell but looking to get into something a bit more friendly for commutes.
Extensive maintenance history under my ownership- I'll provide documentation upon request. Current mileage: 82xxx No accidents, title in hand. Oil change every 3,000 miles - running Redline 5W50 High-level overview including the big ticket items: - Purchased @ 72xxx (I am the fourth owner) - Swapped to Novillo Black interior, installed rear fold downs @ 73xxx - Thermostats & water pump @ 73xxx - Diff fluid service @ 74xxx - New front wheel bearings @ 74xxx - Multi-stage paint correction & ceramic coating @ 77xxx - New front rotors, trans fluid service (Redline MTL), clutch slave cylinder bled @ 78xxx - BE RBs w/ ARP bolts, 034 engine mounts, oil filter housing gasket @ 79xxx - Replaced oil air separators on both banks @ 80xxx - Brake fluid flush and bleed @ 82xxx Mods: - Macht Schnell Stage 2 Intake - Bimmerworld X-pipe w/ quad resonators + Akrapovic Rear - OEM EDC w/ ZCP coding + Swift Springs + Vorshlag Camber Plates - ECS Caliper Guide Pin Bushings + Pins (Fronts) - Hel SS Lines (fronts, rear outer lines) - Euro MDM Cosmetics: - GTS-R 1 piece lip by 360Carbon - F10 knob w/ alcantara boot - Coby alcantara steering wheel w/o center strip + alcantara center cover - Mjunkee GTS style Arm Rest Delete - eBay V-style rear diffuser Last edited by waterpanda; 09-27-2021 at 07:18 PM.. |
