02-28-2014, 11:40 PM | #1 |
Rep 471
Lower control arm bushings
Hi guys,
My lower left front control arm is starting to move almost freely and it's time for a new control arm or new bushings. I was initially thinking of replace with the OEM control arm but would enjoy a tighter feel. What have you guys upgraded your controls arms or bushings with and what would you guys recommend? Thank you |
03-02-2014, 10:31 AM | #3 |
Bad Lieutenant
232
Rep 3,517
I don't think powerflex is making these for us. I was under the impression that the FCABs were delrin or are you talking about the thrust arm bushings?
03-02-2014, 11:01 AM | #4 | |
Rep 471
03-02-2014, 03:21 PM | #5 |
Rep 1,286
How many miles do you have? I just replaced mine only because I got a set of the mono ball bearings for a very good price. I had 65,000 miles of which several thousand were on the track and my bushings were like new.
The OEM bushing is a really high quality part so it's a bit surprising that yours is worn out, but I guess crummy roads, lots of track use (too much lowering?) and other causes might make it wear out quicker. In regard to the mono ball replacement, they don't really add any harshness or vibration, conversely I can't really tell any difference on the track either. Maybe it's a bit more precise but in my hands the difference is really minimal. Replacement tension arms are not that expensive, something like $90 or so per side and the monoball is much more expensive and the installation is going to take a couple hours(did it myself as my shop didn't want to risk cracking the arm when they pressed out the old bushing, which is not the way to do it anyway). |
03-02-2014, 04:02 PM | #6 |
Rep 12,307
Seems a bit premature for a 2011? You definitely don't hear that very often.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
03-13-2014, 11:12 AM | #7 |
Rep 5,517
I swapped my FCAB with BimmerWorld's FCAB that uses a fully-sealed bearing - great improvement over the stock rubber bushing. I actually installed them to address the "skip-slip" issue when turning into a corner:
http://store.bimmerworld.com/bimmerw...kit-p1860.aspx |
03-13-2014, 01:54 PM | #8 | |
Rep 381
11-25-2014, 09:01 AM | #9 |
Rep 633
Bringing up an old thread. Is this a maint item (car is tracked regularly with 63K on clock)? Reason I ask is that upon stationary and quick left right movements, I hear a little bit of a clunk. Presuming it could be the GC camber plate... Need to inspect it in detail but asking if others had failures/wear issue or just upgraded because of compliannce (or lack of).
TIA Lutfy |
11-27-2014, 02:26 PM | #10 |
Rep 1,286
Lutfy, the other thing to check are you sway bar drop links. That's the only item on my front end to wear out. Both sides on my car have play and make clunking noises when driving. I have BW adjustable ones now sitting on the shelf.
11-28-2014, 01:14 PM | #11 |
Rep 1,470
I have the bimmerworld unit on my lower control arms. One of the easier bushings to press out and 5 minutes to bolt in as it is not a press in unit.
11-28-2014, 02:59 PM | #12 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Was thinking of getting the bimmerworld front lower control arm bearing kit myself, any DIY guide on it or is it fairly straight forward?
Also Bimmerworld told me I would not need an alignment after install, true or no?
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc Last edited by squartus; 11-28-2014 at 03:51 PM.. |
11-28-2014, 07:08 PM | #13 |
Rep 1,470
You'll have to press out the old one. I did it using a ball joint press kit and the ford water pump tool as my cup. Pretty easy with an impact. New one just bolts right in. That part is a breeze. I used blue lock tight on bolts mounting the halves together. They give you new control arm bolts. No alignment should be needed unless you had really bad original bushings and had it aligned based on them.
11-28-2014, 08:13 PM | #14 |
Rep 1,017
Ah thank you sir, been meaning to buy a press kit anyway!
11-28-2014, 08:16 PM | #15 | |
just another M3
514
Rep 1,150
I installed those as well and love them. with coilover the car feels so precise
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
11-29-2014, 06:37 AM | #17 | |
Rep 1,470
11-29-2014, 07:28 AM | #18 | |
Rep 8,075
Drives: 11 E90 M3 Individual
Which is why I'm a fan of the Vorshlag plates...no clunks, no maintenance.
2018 F30 320iX Melbourne Red
11-30-2014, 08:47 AM | #19 | |
Rep 1,286
11-30-2014, 09:57 AM | #20 | |
Rep 8,075
That's why Vorshlag is better for camber plates. Vorshlag uses a sealed bearing. Mine are 5 years old and not a sound from them. GC uses a roller bearing which some flimsy plastic races which dirt gets into. You probably won't b able to rotate the spring perch by hand (at least it will drag pretty badly)...which is why it is probably clunking.
01-14-2015, 06:54 AM | #21 |
Rep 1,017
I put these in yesterday and it is a noticeable difference, sharper steering you also feel more in touch with the road with the little bit extra feel coming through the steering.
Pressing out the first bushing went quick, 2nd... grr was a huge pain. Rubber just stretched out and bottomed out inside my cup. Had to fab something up to make it work. Other than that was a quick job with noticeable results, would recommend.
07-27-2017, 06:03 PM | #22 | |
Rep 1,263
The quoted link doesn't work anymore. Is this the same part: http://www.bimmerworld.com/BimmerWor...93-M3-E82.html I don't see "Lower" bushing available on their site, just the "Upper", did they change the name? |
