06-07-2020, 02:08 PM | #1 |
Rep 940
Spacer on 220M wheels stock height
I read 34 pages of the MS spacer thread and couldn't find any pics/info on the following set up:
220m wheels 255/35/19 18mm spacer - front 265/35/19 15mm spacer - rear I'm looking for a very aggressive/flush fit. I know how this set up looks on a lowered E92, but a stock height M. I'm also wondering if 255s are to wide to run 18mm spacers in the front. Maybe I should go 15/15.
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
06-07-2020, 03:23 PM | #2 |
Rep 305
I run 255/35r19 falken azenis fk510 for my front street tires on the 220 wheels with a 15mm spacer in front (non lowered edc). The bottom of the wheel is totally flush with the fender, the top inboard the car by the amount of the factory camber. Idk if I would safely go 18mm fronts unless the factory camber adjustment was maxed out, in which case I would certainly go 18mm *with this tire*. I run 275/35's in the back with a 12.5mm rear spacer. I would not go any wider than that as I already have light sidewall rubbing when I launch the car or hit bigger "than expansion joint" bumps. If you were going to change anything suspension related (concerning looks/stance only)on this kind of tire/wheel set up it's really only the front that needs to be lowered by about an inch +\- a tenth to not look too tucked like a ricer.
06-14-2020, 07:17 PM | #4 |
Rep 940
Thanks. Crazy it looks like the red M that's running 15mm rear spacers stick out a bit further than yours. Probably the angle.
I ended up going with 15/12.5 TMS spacers. With 255s up front I get a little rubbing on my fender liners while making a tight turn. Good news, my steering wheel doesn't shake at any speed.
2013 e92 M3
06-27-2020, 02:41 AM | #5 | |
Rep 305
06-27-2020, 10:42 AM | #6 | ||
Rep 940
I rub a bit upfront with my PS4s. Do your tires rub?
2013 e92 M3
06-27-2020, 10:48 AM | #7 |
Rep 305
Not at all. The outside of my rears rub a little when I launch the car which, has only happened twice. It's just a little plastic transfer, it doesn't actually cut into the side walls
06-28-2020, 09:57 AM | #9 |
Rep 10,616
Tires do vary slightly in measured width. You can look up the actual widths under specifications at Tire Rack. And as you go wider in wheel width than the test wheel, the tread width will widen. I forget the exact amount — maybe like 1/10 inch wider tread per half inch wider wheel, until you reach an extreme like a stretched tire.
