11-25-2020, 07:30 PM | #1 |
Rep 49
Car won't start.. Hear fast clicks, but wont start
My 2013 E92 M3all of a sudden threw a Check Engine light and went into limp mode. I restarted it but it would only click really fast but wouldn't start. I got it towed to a local shop and these are the codes it gave him.
He said it could possibly be the battery terminal because when he charges the battery, it drains really fast. I recently did a secondary cat delete also. Has anybody experienced this before? |
11-25-2020, 08:04 PM | #2 |
09 M3 e93 VF650, e30 e85, Remus, Federal’s 595rs
205
Rep 329
By some of the codes you have, it tells me a bad Battery. How old is the battery ? If the battery is kaput it wont hold a charge no more.
09 M3 E93 - VF650, AFD e30 e85, Remus Race, Federal’s 595 rs-pro’s.
11-25-2020, 10:00 PM | #3 |
Rep 49
The battery is 7 years old, never been replaced. According to the CARFAX, it's been recharged 3 times. I ordered a new battery and hopefully it solves the problem
11-25-2020, 10:31 PM | #4 |
Rep 7,541
Battery for sure.
///M Power-Belgium63083.00 |
11-25-2020, 11:08 PM | #5 |
Rep 860
7 years old? yeah man you got your $ worth out of it. Time for a new battery.
Strange the shop didn't catch a 7 year old battery right off.
11-26-2020, 03:31 PM | #6 |
Rep 49
11-26-2020, 05:03 PM | #7 |
Rep 412
So it fixed your issue?
I just replaced mines not long ago. Def lastly 5 plus years but decided do it before running to possible issues or worry about during a night die on me. |
11-26-2020, 05:46 PM | #8 |
Rep 49
Going to have it towed to my house from the shop so I can install the new battery. Hoping for the best
11-26-2020, 05:53 PM | #9 | |
Rep 412
12-01-2020, 10:29 AM | #13 |
Rep 801
It's clearly not the battery. There's a short somewhere. I'd seriously consider obtaining a replacement engine harness. There are plenty of them out there for cheap. And having your mechanic spend many hours tracing the existing one for a short could easily end up being more expensive than just telling them to swap a replacement in.
12-01-2020, 10:26 PM | #16 |
Rep 860
Burning coils? I’m going to take back my earlier advice. That’s not a battery problem. Although at 7 years you do need a new battery. Hope it works out for you.
12-01-2020, 11:47 PM | #17 |
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
well, it's coils, plugs or injectors. doubt it's going to be wiring harness... doesn't just get melted all of a sudden. How old are the plugs? Just do the cheap stuff first. Change plugs, then coils, re-check.
12-02-2020, 08:39 AM | #18 |
Rep 234
Have you replaced the starter? Looks like you had a code for that. When pressing ignition do you hear 1 click? I had similar problem, the click I heard was the gear on the starter kicking out to engage the flywheel but wasn’t able to turn it to start the car. Started out taking several tries before being able to start to finally having it completely fail.
Edit: just saw your other post on the coils and stuff so you likely don’t have the same problem I did. Good luck and keep us posted. Last edited by happydude; 12-02-2020 at 08:45 AM.. |
12-13-2020, 10:37 AM | #20 | |
Rep 801
It's pretty much either DME or wiring harness or both with those symptoms. Especially given how it runs normally on one bank and is melty on the other. Edit: And while grounds are important (I just had to dig through my truck's wiring harness to find a bad ground), I don't really see how a bad ground cable would cause one baank to get melty and one bank to run normally. I can't think of any grounds that are separated in that way that wouldn't just point to "replace engine harness."
12-13-2020, 02:02 PM | #21 |
Hey, where have you been all my life?
680
Rep 1,401
My guess it's the alternator. When they go bad, they can throw all kinds of wonky codes.
Have you tested the alternator? |
12-13-2020, 02:03 PM | #22 |
680
Rep 1,401
Also, I hope your mechanic registered that new battery with the ECU... Otherwise that new battery and/or the alternator might be getting fried (possibly causing the burning?)
Tags |
battery, battery terminal, check engine light, codes, wont start |
