05-15-2020, 12:33 AM | #1 |
Rep 17
Engine refresh
I thought I would share my M3 experience so far:
I bought this 08 M3 with 150k miles on it about 6 months ago. Immediately I wanted to do a bit of preventive maintenance. List of things that I replaced: rod bearings, clutch, flywheel, mounts, about every seal, and fluid. The cost for all this was surprisingly low. Probably well under $2k, but it did require a few late nights. See the pictures, they will explain the process better. I already have over 1,000 since the service, and so far there are no leaks, and most importantly the car was restored to a "new" driving condition (mainly because of the clutch and mounts). I went with the blue, purple, red paint in the engine bay because I wanted to match the ///M logo, but I need to fix the purple on the spark plug covers. |
Damado9335.50 rcracin1242.50 bimmergixxer48.00 Space Fox1042.00 akkando5864.50 jvictormp881.00 javarithms193.50 SAMM3Y3085.00 |
05-15-2020, 12:52 AM | #2 |
Rep 17
A few comments to add: While working on the car I was able to see that a lot of engineering went into this engine, and I really appreciate it because of that. Well I guess the engineers decided on the rod bearing specs on a Friday afternoon 5 minutes before the design had to be locked for production.
What is even worse than that is the crappy manual transmission they decided to add to this special engine. It has super long gears. 70mph on second gear, pisses me off every time. The shifter sucks for a RWD car or any car actually, and its super noisy and clunky. I guess they made it up with the M differential (my favorite part of the car). The EDC is amazing, but the steering rack sucks. It needs to be tighter. And it needs a little more noise. Why do I have to modify an M car to sound better? It's a very good car. You should buy one just so you can drift it safely everyday (MDM). |
05-15-2020, 05:43 AM | #3 |
Rep 488
Drives: 2011 E90 M3 6MT
Nicely done. Well the gearbox is no Honda, but it does have to absorb a bit of horsepower. Contact Ronald at Autosolutions, hand him $400, and you will think he built you a new gearbox.
SYT_Shadow11479.50 |
05-15-2020, 06:57 AM | #4 |
mTekMods
2142
Rep 2,901
rtd shifter 4.10 gearset problem solved.
Furthermore you may not like the stock gear ratio but it has to work for everyone who buys the car, not just you.
05-15-2020, 07:56 AM | #7 | |
///M Powered for Life
11480
Rep 10,328
It's has pretty short gearing. Go try a supposed race track ready GT4 and second gear there goes to 84mph... now that is a problem. For the shifter, get an AutoSolutions SSK and an Ultimate Clutch Pedal and it's pretty awesome. |
05-15-2020, 10:55 AM | #9 |
Rep 17
bvrider1 I thought there should be a tune for this but I didn't know what it was called. I will look into it right away. MDM does cut way too early, and traction off is a bit risky around town.
amrazM Good point. I might look into a higher FD ratio eventually. Just need to cut down the highway driving first. I guess I didn't mean to say it pisses me off every time, but rather it makes it really hard to enjoy the 8.4k rpm redline which is really the purpose of this car. serranot Can you give me a bit more details on this? |
05-15-2020, 04:59 PM | #10 | |
Rep 488
05-15-2020, 06:01 PM | #11 | |
Rep 486
05-15-2020, 06:03 PM | #12 | |
Rep 486
(Would be a tighter seal between gasket, and cover) And they won’t peel for another 150k |
05-15-2020, 07:50 PM | #13 |
Rep 10,614
I would not buy new valve covers unless mine are warped. He cleaned and painted his. No need to spend money on new ones if yours are good. Peeling is cosmetic. Magnesium BMW valve covers have been peeling for 25 years without doing anything other than looking bad.
SAMM3Y3085.00 |
05-16-2020, 12:07 AM | #14 |
Rep 17
I appreciate the info. Already contacted AutoSolutions to get a quote on a shifter.
I am very interested in the Euro MDM, but it's hard to find information on how to do it. I will keep searching. I am also looking into doing the OEM exhaust mod. My buddy has a welder in his garage. I guess a few minor touches can make this an even more exciting car. |
05-16-2020, 12:20 AM | #15 |
Rep 17
The OEM valve covers looked pretty bad. I couldn't believe how bad they were peeling on the inside. I had to fix that. I cleaned them as best as I can and pained them with Autozone paint. I like the way they turned out, and 3 months in they still look the same. I was worried about the gasket surface, but I stuffed enough RTV in there and nothing is leaking (I know I should not use RTV). I even reused the bolts and o-rings with RTV. Not a chance I would spend money on new valve covers.
05-16-2020, 06:30 AM | #16 | |
Rep 486
Also, if you don’t use the same exact paint process that bmw uses with the magnesium. You’ll run into the same problem much sooner than expected. Replacing the valve covers is what the BMW dealership would call for. So that is what I do. Some people cut corners. Some people don’t. |
05-16-2020, 07:12 AM | #17 | |
Rep 791
For my Euro MDM I went the easy route.
http://www.bpmsport.com/coding-features-service.html Quote:
05-16-2020, 07:39 AM | #18 | |
Rep 10,614
wfdeacon881105.00 Bartledoo2691.50 |
05-16-2020, 12:30 PM | #19 |
Rep 17
I didn't have to use the same paint process as BMW. I did not paint the inside, just cleaned it really well. A lot of paint came off. I would recommend doing this if you see any peeling near the oil cap.
Thanks for the BPM suggestion. I might go that route as well. |
wfdeacon881105.00 |
05-16-2020, 12:40 PM | #20 |
Rep 17
I'm surprised people follow the dealer's recommendations so closely, especially with old bmws. I wonder how much the dealer would have charged me to do this work? $10k? On top of that I don't trust the techs to perform the same quality of work that I did.
wfdeacon881105.00 |
05-16-2020, 04:17 PM | #22 | |
Rep 482
Ronald is really responsive to email, but you should go ahead and give him a call to discuss all the options. |
Tags |
diy, m3 engine removal, maintenance, oil leak, rod bearing |
