08-20-2018, 11:54 AM | #1 |
Rep 304
Akra Evo lambda error code
Hello guys
Finally, I installed a new engine. Fuel injectors, spark plugs, fuel pumps and map sensor and etc are all new. After installing, I finished engine break-in. <My engine mode> K&N drop in filter Akra Evo SAP removal oil catch tanks airconditioner compressor removal under drive pulley ECU tune (SAP and engine error code are suppressed for akra evo and SAP removal) All mode are all the same before engine failure. During break-in, I checked engine with diagnosis tool(Carly and ISTA) several times. These codes always came back. ( L & R lambda sensors before CAT are new) Is it normal on Akra evo? I didn't remember the diagnosis result before engine failure.
2011 LCI W/DCT / K&N drop in filter / CSF radiator / do88 oil cooler / do88 DCT cooler / Akra Evo / Moton CS 2 way coilover / Wiechers strut bar(F) / ARC strut bar(R) / Alcon Superkit BBK / Tarox rotor / Geoff steel EHPS / Sard carbon-Kevlar GT wing / GT4 carnard / Aim Evo4+G-dash+GT Steering+S/C GP HD / Bride Zeta3 / etc.
08-21-2018, 01:15 AM | #4 |
Rep 304
Akra evo doesn't have primary cats
08-21-2018, 09:57 AM | #5 |
Rep 966
That is why I asked. I'm not sure which version offered that since they no longer offer the catless version.
I read that you have the specific software already. Is it possible it was overwritten ? I had issues with software with 2 companies and ESS Tuning resolved it for me. Never had codes since. Do you have any of these codes : 272B 272A 2728 2729 274A |
08-22-2018, 03:57 AM | #6 | |
Rep 304
Always 27C6 277D 273A 273B What's the meaning of " Is it possible it was overwritten ?" I'm using the same Akra Evo for more than 5 years. There were not any codes before new engine(third engine), except O2 sensor(post cats). If you're using akra evo, what is the idle rpm at operating oil temp?
