06-28-2018, 10:35 PM | #1 |
Rep 747
Help with code 5A53
Does anyone know what code 5A53 stored in ECU refer to other than meaning "DCT overheat" ?
I have searched online with not much result other than DCT overheat and whoever had these codes needed DCT gearbox replacement. Any help would be appreciated! |
07-03-2018, 08:32 AM | #3 |
Stop the hate, get a V8
3850
Rep 8,625
You may want to provide some additional context on the code. What were you doing at the time? Was the transmission exhibiting any other odd behaviors? Did the code return once you cleared it? What's the car's maintenance history?
Without the right context, this is akin to going to your doctor and saying your foot hurts but nothing else. That being said, the M-DCT is fickle at times. If you clear the code and it doesn't return, and the transmission is behaving normally, you can probably ignore it.
Past: 2011.5 M3 sedan ZCP |
07-03-2018, 09:12 AM | #4 |
Rep 1,534
07-03-2018, 09:14 AM | #5 |
Rep 4,014
Change your fluid. At the least top it off. Definitely a diy.
https://www.m3post.com/forums/showthread.php?t=746269 Thank you SYT_Shadow for the link. |
07-03-2018, 03:37 PM | #6 | |
Rep 747
07-03-2018, 06:40 PM | #8 |
3850
Rep 8,625
That doesn't mean the fluid level isn't low.
Also, see my earlier post -- you need to provide more info for us to try and help. It's not our job to play 20 questions with you.
BOOF-M34451.50 |
07-03-2018, 08:01 PM | #9 | |
Rep 747
If there was a leak, I would have noticed it and made sense to add fluid however, if there is no leaks. Where did the missing fluid go? I don't believe transmission drinks oil as engine does |
07-03-2018, 08:04 PM | #10 | |
3850
Rep 8,625
Per my original post: What were you doing at the time? Was the transmission exhibiting any other odd behaviors? Did the code return once you cleared it? What's the car's maintenance history? These are the basics for anyone to provide meaningful help. Shouldn't take more than a minute or two to provide this. Otherwise it's just a lot of random guesses being thrown out, which drives me nuts. Diagnosing problems is NOT guesswork.
07-03-2018, 09:46 PM | #11 | |
Rep 747
What were you doing at the time? Driving like any other day. Closer to redline Was the transmission exhibiting any other odd behaviors? Not really Did the code return once you cleared it? It returned once What's the car's maintenance history? I don't have maintenance history of the car. I am 3rd owner. |
07-03-2018, 11:17 PM | #12 |
3850
Rep 8,625
If the code is returning then there is likely an issue.
Hopefully someone proficient BMW TIS can look up the diagnostic procedure for that exact code.
08-20-2018, 12:16 PM | #13 |
Rep 398
I had that happen the dct overheating error , drove the other day to gas station at night and got the error after getting gas , annoying . I got that error on 90 degree day in traffic with ac on .so I just replace the dct oil thermostat http://www.bimmerworld.com/Cooling/O...9X-M3-DCT.html drove it the other day to work no issues yet .
09 Jerez black coupe . 275/35/19 mss rear,Alex alpine gts dct software with some coding(euro mdm,DVD in ,mirrors fold on lock ) , rogue engineering pulleys ,TTFS TUNE . Eibach springs . New brake front rotors with new hawk pads no rear pads. Rd front sway bar.ACTIVE AUTOWERKE TEST PIPES .csf dct cooler ,BE BEARINGS/BE ARP BOLTS,vibra road e/mounts
08-21-2018, 09:21 AM | #14 | |
Rep 747
08-21-2018, 06:42 PM | #15 | ||
Rep 398
08-21-2018, 06:56 PM | #16 |
Rep 747
I would definitely do this if this if it fixes the problem. Please report back once you get to drive it more. How often was your car throwing the code?
08-21-2018, 06:58 PM | #17 | |
Rep 398
