07-01-2016, 06:56 AM | #1 |
Rep 73
Widest tires on OEM 19" 220, stock suspension?
Dear list gurus, I have a new-to-me E92 M3 that requires new tires. I do like the stock 19" OEM 220s but would like a little more aggressive stance without compromsing the handling on my non-EDC car.
I have stock suspension, no spacers. Can I go a little wider than 245/265 w/o rubbing issues? Should I just get the 18/15mm spacers? Is lowering worth the effort and expense? Thanks in advance!
E92 M3
958 Cayenne Turbo 911 C2 LS3 |
07-03-2016, 09:56 PM | #3 | |
Rep 4,053
07-05-2016, 08:23 PM | #4 | |
Rep 1,107
Lowering, say on Eibach Pro Kit, gives a modest drop that improves looks and does have some handling benefits. |
07-08-2016, 09:49 AM | #5 | |
Rep 928
On my old e93 I hated the stock 245/265. 285 would have been a must have if I bought new tires. I ended up buying some used tires and trading it. The setup was 245/35/19 275/30/19 and it worked ok but the MDM didn't work as well.
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT |
08-03-2016, 06:11 AM | #6 | |
Rep 73
Thanks again
E92 M3
08-03-2016, 06:24 AM | #7 | |
Rep 1,107
Unfortunately, any drop - even as slight as the Pro Kit - does come at a price. A small price in this case as it is just marginally stiffer in my experience. I cannot say how much it will effect the ride in yours without EDC as I have EDC and it's fine for me. If your Mrs. already complains, it's not going to get better. Perhaps it won't get any worse either — and you can get a little better handling and the stance you are after!
08-17-2016, 08:19 AM | #8 | ||
Rep 2,672
EDIT: Nevermind, I see the star spec 285's you are referring to now and they are actually PS2's. Still, curious what the tire rack star BMW 255/275 19" PSS were originally intended for. Perhaps the F80/82?
08-17-2016, 11:00 AM | #9 |
Rep 668
Drives: 2011 AW E90 M3
I have 255 front and 275 rear on 8.5 and 9.5 wheels. Wheels are Rays TE37TTA, but same size as stock. Tires are Continental DW Extreme, which have a thick sidewall so overall I got this sort of meaty look that I like. Suits the car well imo...
I did a bit of searching before buying these tires and people recommend not going above 255 on 8.5 and 275 on 9.5, so I followed the advice. |
///Mobbin1478.00 |
08-20-2016, 03:51 PM | #10 | |
Rep 2,672
08-20-2016, 04:06 PM | #11 |
Grand Am Timing Official
11
Rep 162
I'm not seeing a lot of references to tire brands and models in these responses. That makes a HUGE difference.
I know 255/275 RE-71R's fit "tight" on the stock 19's at stock height on my EDC car. No combination of spacers or sport springs can be used either with these tires. They are insanely wide and highly recommended.
18 Ford Raptor SuperCrew 802A black on black
08 E92 M3 AW 6MT with Macht Schnell 75mm stud kit, RE-71R's 255/275, M3 Edition black grills, ZCP rear spoiler, exhaust mod |
08-22-2016, 10:55 AM | #12 | |
Rep 633
RE71R has firm sidewalls. Anything north of 255/275 on stock 220s or the 18 inch wheel option (8.5/9.5) is a 'stretch'. OP Costco has 45K mile warranty on the AS3+ BTW. As long as you don't have crazy camber and rotate, its not a bad deal. (22.5K for rears re: warranty). Heck they have mileage warranty for RE71R too Lutfy |
Tags |
oem, spacers, wide tires |
