06-28-2018, 08:41 AM | #1 |
Rep 769
Battery change. What happens to coding?
When I bought my M back in April, it was already coded (mirrors, DVD, euro hazards, etc). Being that its a 2011 and I am still on the original battery, I figured I would take advantage of my extended warranty (yes it covers the car battery. I was surprised too).
Im assuming all the coding will be erased from replacing the battery, because I think BMW reprograms the software. Can anyone confirm this? |
06-28-2018, 03:29 PM | #2 | |
Derbo Tuning
3604
Rep 3,020
There shouldn't a reason to reprogram the other modules. You can check with your service advisor to confirm.
IG:ruhrohz_m3
06-28-2018, 03:54 PM | #3 | ||
Rep 769
06-28-2018, 04:08 PM | #4 |
Rep 742
Coding will not be reset. If you unplug the battery on your car it resets your cluster meaning MPG, miles driven since reset, clock etc is all reset but your actual coding is not touched. They do not reprogram anything either, since they'll most likely replace it with the same spec battery already in your car, all they need to do is register it. If it was a different type of battery being installed then they'd need to register/reprogram it with different variables with different AH or AGM to non AGM. But even then, coding options are not touched or erased. At most, your adaptations will be reset.
06-28-2018, 06:55 PM | #5 | |
Rep 769
