  TireRack
      02-28-2015, 08:52 PM   #1
nickl630
nickl630's Avatar
Drives: 18 M3CS, 09 GTR
newbie with a hub centric ring question
Howdy everyone!
Just recently picked up an E92 M3 coupe, having owned several BMW M's in the past (most recently an E60 M5) and I absolutely love it... besides one problem that's been killing me.. the car vibrates at 60+ mph almost violently sometimes in the steering wheel.
The car has aftermarket wheels that look like competition reps that are the factory size and look decent with new tread on them, the dealer mentioned it had hideous aftermarket wheels on them with bald tires so they replaced them with these.
The car has been to the shop 4+ times being balanced, new tie rods, new alignment etc until FINALLY they found the problem.. it needed some hub rings due to some minor play in size.
Heres the issue... I took my wheels off last night to clean them.. and guess what.. after putting the wheels back on the vibration came back! The spacers were plastic also and looked either mashed/damaged and too small (they were all cut so they could fit around the hub, too small maybe?)
I dont want this issue every time I take my wheels off... however it gets more complicated as the stock size of the E92 hub is 72.56 if im reading correctly.. and my wheels are 72.60. Would .04 mm make a difference? And is it even possible to find spaces that measure that size? The smallest ive seen is 72.6 to 74.1
Am I stuck with this issue every time I take my wheels off? This has been so frustrating! Thanks for the help in advance!
      02-28-2015, 09:47 PM   #2
Chhr
Drives: 2018 F80 M3 ZCP
I'm not an expert but yes .04mm does matter. It might be so small but you have to think about your wheel spinning at 2k-8k ram. . That multiples the off fitment on the hub which causes vibration. . Get new wheels or get outlet fitting hub rings. Obviously the are safety issues too.
      02-28-2015, 10:08 PM   #3
HXS
Licensed Drug Dealer
HXS's Avatar
Drives: F10 M5
When you put your wheels back on, why don't you see if it rests perfectly on the hub? I mean rest it on the hub without any wheel bolts. It should fit snug.
      02-28-2015, 10:25 PM   #4
nickl630
nickl630's Avatar
They do, however there is a pretty strong vibration from 60 to 80mph. Even the manufacturer of the wheels has said it shouldn't need a hub ring since the difference is marginal but so far that's the only thing that's solved it.
      03-01-2015, 10:43 AM   #5
Helmsman
Helmsman's Avatar
Sweden
4465
Drives: 2011 AW E90 M3 ZCP
"Violent steering wheel vibration" - ouch, not good for any part of the front chassies bro. I'd search up a set of good used OEM rims and invest, right away.
Good luck
      03-01-2015, 11:49 AM   #6
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
I bet you a beer its your rotors
Performance
ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe
Looks
M colors grill - CF trunk - Sapphire Blue Forgestars F14
      03-01-2015, 12:43 PM   #7
nickl630
nickl630's Avatar
I'd agree with you but they resolved it when they put some rings on the wheels. My concern is when I removed my wheels to clean them they were damaged and undersized... however I cant seem to find the proper size or clearance of only .04mm and most people are saying .04 shouldn't make a difference but clearly it does.
      03-01-2015, 01:40 PM   #8
W Cole
Drives: 2009 M3
I've had some minor vibration since bmw replaced mine. Is there a company that balances rotors? What can be done?
      03-01-2015, 01:46 PM   #9
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
The reason I said rotors is because mine was having the same issues as OP described, I tried balancing, and new alignments and nothing. A friend recommended to get my rotors turned and they were warped beyond repair! New these suckers are too expensive so I bought some used ones with a claimed 5k miles on them, but the I installed those rotors the vibrations went away and haven't had them since, I plan on buying the two piece ECS rotors so just so I can have brand new rotors.
Performance
Looks
      03-01-2015, 04:42 PM   #10
alpina-527
.04mm of clearance is a perfect fit. Nothing at all wrong there.
My money would firmly be on the quality of the rep wheels. How many weights on the wheels?
Does the tyre run true when you spin the wheel by hand? No amount of balancing will cure a lumpy tyre.
      03-01-2015, 05:41 PM   #11
nickl630
nickl630's Avatar
This is my concern too, the fronts have a bunch of weights, once time 3 rows deep on one of the balances. Im trying to get the dealer I bought it from to replace the wheels with stocks... as I know it will solve my issues.
      03-01-2015, 05:58 PM   #12
alpina-527
That's your problem then.
      03-03-2015, 11:50 AM   #13
ben@tirerack
M3Post Supporting Vendor
87
Drives: 740i
The clearance definitely sounds too tight for a ring to be a viable solution. Nothing that thin is going to have any durability unless it's made of some exotic materials.
Here's another idea:
Maybe the wheels are designed to be hubcentric, but are just slightly imperfect in the machining of the centerbore. The M3 is very sensitive to that type of thing, so it wouldn't have to be much.
You might try treating them like wheels that are lug-centric. Torque them down in the star pattern with the weight of the vehicle supported by the jackstands or lift (and something wedged under the wheel to keep it from turning.) This will let the lugs pull the wheel centered. You may not get it perfect every time, but you may get it good-enough.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions.
      03-13-2015, 10:41 PM   #14
trbo94
Drives: E92 m3
NickL630.. Wheel/tires were my living from 2005-2012 (just some background so that my answer can have come weight to it)
Look inside your wheels lug holes. And feel inside as well. There are 2 different types of seating for the lugs/bolts for wheels. ball and conical.
Ball is just as it sounds it would be like a ball or circle so the degree of taper would change just like a circle. The other is conical so the taper of the seat for the lug/bolts would be a constant (most common is 60 degree)
Your wheels being 72.6 and not 72.56 is not the issue I promise that. In the USA to sell a aftermarket wheel the wheel has to be DOT approved. And DOT standards for the US require the wheel to be load rated off the lugs/bots and not the hub. So aftermarket wheels have to fit correctly off the lugs/bots and not need the hub at all in short.
So I think you might have ball seat wheels and be using conical seat bolts. Or the reverse. If that is the case hub rings could stop the vibration but then the bolts that hold all the weight would not be seated correctly. Or I have seen (to many times for my liking) over spray in the lug holes. You could have some degree or paint in the lug/bolt holes that is not letting your bolts center the wheels.
Just some thoughts but from my experience I think it is one of those. Hope it helps.
