04-10-2011, 04:12 AM | #1 |
Rep 107
both of my remote stop working along with the trunk
I can't open the trunk without using the key or hit the release button inside the car under driver side dash. my remote stop doing lock unlock. what can it be ?
04-10-2011, 07:01 AM | #2 |
Rep 6,860
Drives: 2014 BMW 435i X-drive
Did you check the switch in the glove compartment?
04-10-2011, 08:38 AM | #3 |
Rep 107
04-10-2011, 09:50 AM | #4 |
Rep 107
Ok never mind, I still can use open the trunk from the back without the key as long as both door unlock, however, the remote still not working for lock and unlock doors, which fuse number I need to check if any?
04-10-2011, 11:26 AM | #5 |
Rep 1,603
Drives: my feet
I would say it's in valet mode but you said you already checked the glove box
2008 Alpine White e93 335i- Sold
2009 Black Sap. Met. e93 335i- Sold 2010 Melbourne Red e92 M3- Sold |
04-10-2011, 05:16 PM | #6 |
Rep 107
04-10-2011, 11:23 PM | #8 |
Rep 1,599
Do you drive your car regularly and for several miles at a time? Does it sit for days undriven? If your use is low, it's possible that the car's battery charge is low.
04-10-2011, 11:39 PM | #9 | |
Rep 107
back to back 18 hours drive count ? |
04-11-2011, 12:44 AM | #10 |
Rep 1,599
Yes - Should be as charged as it's going to be. It is possible that the battery has reduced capacity (from the way the previous owner used it). Sounds like you need to go to a dealer to find out what the problem is.
04-11-2011, 07:53 AM | #11 | |
Rep 525
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
If you open up the owners manual, there's also a section in there about the remote and how to replace the battery.
Drives: '11.5 Interlagos Blue E92 M3 Comp, '21 F95 X5 M Comp DIYs: Enable Rear Fog | Easy Side Gill Replacement | Front Grill Replacement |
04-11-2011, 03:42 PM | #12 | ||
Rep 107
04-14-2011, 08:23 PM | #13 |
Rep 107
went to the dealer, test both remote still work, they reprogram didn't work, they trace it down to the mirror and state that new mirror need and the antenna in the mirror could be faulty
