02-15-2024, 12:43 PM | #1 |
Rep 193
DCT Service & ISTA
Hi Guys,
When DIYing the DCT service do you HAVE to have ISTA? When using ISTA's "oil balancing" procedure after warming up the trans it gives a message: The actuator system is now activated - -1st gear is engaged -System pressure is limited -Maximum cooling is activated Does going through ISTA open up more room for fluid or does that happen regardless when you reach correct temps? Also, has anyone tried below DCT oil pan? Seems like a carbon copy of the OEM one but made in aluminum and is a bit cheaper, $156 vs $183 for OE. https://www.fcpeuro.com/products/bmw...ts-28108070791 |
02-15-2024, 01:01 PM | #2 |
Rep 1,700
Using Ista software will not affect the opening or closing time of the thermostat.
You can monitor fluid temperature by using a pyrometer or using ProTools / an OBD2 device that can pull transmission temperature. It is one of those things where you may need to lift the car up once or twice during the process. start cart, lift it up, monitor the temperature, fill it, monitor temp, fill it, once it overflows, close it, drive it, lift it again, check it, fill if needed, drive it... fill it, check it again and fill if needed again.
02-15-2024, 01:49 PM | #3 | |
Rep 193
02-15-2024, 05:50 PM | #4 |
Rep 1,104
Wear long sleeves and at least thick nitrile gloves when checking the fluid level, you will be very close to the midpipe. I usually let the car cool down for several hours between level checks so I don’t miss my temperature window.
DrFerry6728.50 |
02-15-2024, 05:52 PM | #5 |
Rep 1,104
I should have prefaced with, while I have ISTA I’ve never bothered with using it for the transmission fill. I just basically did the work instructions with a timer and a cold car.
DrFerry6728.50 |
02-15-2024, 06:06 PM | #6 |
Rep 62
I'm not looking forward to doing all of this when I replace my DCT cooler
02-16-2024, 05:01 AM | #7 |
mTekMods
2143
Rep 2,902
you dont have to, just overfill the gearbox when its within the temp range.
spammysammich1583.50 |
02-16-2024, 09:44 AM | #8 |
Rep 7,110
02-16-2024, 11:13 AM | #10 | |
mTekMods
2143
Rep 2,902
never had any issues with the car it could shift midcorner if I pulled the paddle.
DrFerry6728.50 spammysammich1583.50 |
02-16-2024, 12:36 PM | #11 |
Rep 7,110
02-16-2024, 12:53 PM | #12 | |
Rep 1,700
You can do the banjo method like AmrazM stated, but I overfilled mine by just constantly filling, driving, filling, driving until it can't take anymore and check the fluid temp via pyrometer. Just an annoying process. Although the extra 1L does nothing for temp, it just makes sure the DCT goes into gear. LOL What I mean by that is if you're on track and experience frequent issues with shifts, then the extra 1L would help as it prevents fluid starvation witch in return helps with getting into gear.
DrFerry6728.50 |
02-16-2024, 01:57 PM | #13 | |
Rep 1,104
02-16-2024, 03:59 PM | #14 | |
Rep 7,110
02-17-2024, 05:07 AM | #15 |
mTekMods
2143
Rep 2,902
not really, I think i usually put 7.5 with a standard size pan. those aftermarket deeper dct pans are really only for greater heat capacity. you need to overfill it to not have high force shift issues.
02-17-2024, 06:04 AM | #16 |
Rep 7,110
7.5l when normal change? Believe the "service kits" include 6l only?
02-17-2024, 05:53 PM | #17 |
Rep 1,104
02-17-2024, 08:12 PM | #18 |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
Yes there is a procedure but let’s not over complicate things. Drain fluid, replace both filters and add fluid until no more will go in. Replace bolt and let car warm and then cool a bit. Remove bolt and try to add more. A useful trick is to jack up the car from passenger side only and add more. The GTS banjo bolt allows for more fluid because you can connect to it and force in more fluid past the drain bolt level. Hot fluid is what we are measuring here is all.
Tragiclil56.50 |
