05-15-2019, 09:30 PM | #1 |
Rep 26
diagnose a problem
Everytime i make a hard right turn, it sounds like something is rubbing or something in the back right tire, is this the diff or something else?
05-16-2019, 12:38 PM | #2 |
Rep 924
if it sounds like a rubbing nise more noticeable on tight turns, u may need to replace your differential fluid to the one with the additive. after u put in new fluid its best to do about 10 circles left and 10 circlesright (steering full lock) to fully eliminate the noise...
IM_DR3W0.00 |
05-16-2019, 03:22 PM | #3 | |
Rep 26
05-16-2019, 03:39 PM | #4 |
Rep 2,138
Drives: 2011 E92 M3
Not the BMW fluid. Unless you have money to burn Make sure it has the proper friction modifiers for LSD read ends.
Lots of options are available. I have run both Redline and Castrol and they work fine. This is a good kit as you "need" new plugs according to BMW anyway. Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... Last edited by Scharbag; 05-16-2019 at 03:46 PM.. |
IM_DR3W0.00 |
05-17-2019, 02:40 AM | #6 | |
mTekMods
2142
Rep 2,902
IM_DR3W0.00 |
05-17-2019, 09:25 AM | #7 | ||
Rep 2,138
Drives: 2011 E92 M3
IM_DR3W0.00 |
05-17-2019, 09:52 AM | #8 |
Stop the hate, get a V8
3850
Rep 8,625
Everyone sure is quick to jump on the idea of a differential fluid change. Diff problems are typically clunking sounds.
I would always start with a quick visual inspection; get the car up on a lift and take a look around (bent suspension component, road debris, wheel weight coming loose, loose lug nut, etc).
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 05-17-2019 at 10:08 AM.. |
IM_DR3W0.00 |
05-24-2019, 10:07 AM | #10 | |
Rep 26
