12-24-2008, 10:11 AM | #1 |
You don't know JACK!!!
43
Rep 796
Ipod - No Sound
Ok..this might be a stupid question. Just tried out my ipod adapter in my car and i can see all the playlist and songs, but as soon as I play it, no sound. I looked at the connection and it seems ok. A couple of questions:
1. are we suppose to connect both the ipod connector and the headphone connection (connecting the headphone to the aux)? i did both just in case. on my old e46, i just needed the ipod connector no headphone. 2. i choose aux on my idrive anything else that i'm missing? fyi..i have the first gen nano which I'm assuming is compatible?
Rated /// M
12-24-2008, 10:46 AM | #2 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
you should choose ipod
not aux aux is only if you are only using the mini headphone connector |
12-24-2008, 10:49 AM | #3 |
43
Rep 796
i'll check that in a bit. i could've sworn i didn't see the option ipod and assumed that aux would be the same. let me check again. thanks...
Rated /// M
12-24-2008, 11:01 AM | #4 | |
Rep 13,001
12-24-2008, 11:05 AM | #5 | |
Rep 13,001
That's not the problem here as the OP in fact can see the iPod Playlists and songs in the iDrive screen. Otherwise he won't see them... the issue is no sound. |
12-24-2008, 11:09 AM | #6 |
43
Rep 796
the one that came with the dealer. the cable has both an aux connection and a connection that connects to the ipod. the other end i connected to both the aux and usb. maybe i should only connect either usb OR aux.
Rated /// M
12-24-2008, 11:14 AM | #7 |
Rep 5,319
You are doing it correctly, you connect both AUX (line-in) + USB.
12-24-2008, 11:16 AM | #8 |
Rep 13,001
The OEM cable that you should be using has only an iPod connection at one end and both an AUX jack and an USB connector at the other end.
12-24-2008, 11:21 AM | #9 |
Rep 5,483
should be a no brainer...
did you figure it out?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
12-24-2008, 11:26 AM | #10 | |
43
Rep 796
Rated /// M
12-24-2008, 11:27 AM | #11 |
Rep 5,483
thats weird...try another ipod (friend or family members) and see if that works...
Current:
12-24-2008, 11:29 AM | #12 |
Rep 13,001
12-24-2008, 11:37 AM | #13 |
Rep 5,319
It should be a Y-cable.
iPod connector on one end and line-in + USB on the other end.
12-24-2008, 11:58 AM | #14 |
43
Rep 796
that's exactly how i have my connection. maybe it's not compatible with my 1st gen nano? i can see playlist so i figure it was compatible.
Rated /// M
12-24-2008, 02:10 PM | #15 |
Rep 6,845
i would reset the ipod
i had that recently happen to me i had the ipod plugged in only with a mini headphone plug my son was in the back watching Dora and he doesn't like headphones so i had the sound plugged into the stereo no sound was coming out i tried everything only thing that worked was a reset on the ipod and it worked perfectly press menu and the middle button till you see the apple logo |
12-28-2008, 01:26 PM | #16 | |
43
Rep 796
Rated /// M
