11-18-2010, 09:54 AM | #1 |
Rep 318
re-11 285/35/19
I am looking to increase the width of my tires on the stock 19's
I wanted 275/35/19 rear but the re-11 don't come in that size they do come in 285/35/19. I will track the car maybe 5 times next summer. I will be going 255/35 on the fronts I wanted to know if there was any downside/upside of going 285 vs 265 in the rear. |
11-18-2010, 10:43 AM | #2 |
Rep 468
285 is too wide for the stock 19' wheel (9.5" wheel). You will need to go to 275/35. If you are stuck on the RE11, you could go 275/30 but that is a pretty significant drop in circumference.
There will be people on the forum that say you can do the 285, but it will be bulging on the sides and may not be safe for track use. I wouldn't advise it. |
11-18-2010, 10:51 AM | #3 |
chris
278
Rep 12,144
285/35/19 will have a tire side wall thats too thick, you cant use this set up even if you have aftermarket rims and 285 is too wide for the stock rims so i wont recommend it either.
use 285/30/19 if you have aftermarket rims. if you want a 35 profile tire then you will have to downsize to 275/35/19
11-18-2010, 04:13 PM | #5 |
Captain Obvious
90
Rep 977
Actually... I spent the summer (and 15 track days) on 285 RE-11s in the rear. Worked like a charm. Ben at TireRack confirmed this setup would work for me before I went with it as I had the same concerns.
Just a girl and her 863 ponies...
2013 Santorini M3, 2016 328i Alpine White Wagon (Lab hauler), 199x wrapped E36 M3 (because racecar) ///M-Flight |
11-18-2010, 04:16 PM | #6 |
Rep 1,562
i dont think 285 will fit on stock wheels
just read above post.. guess it does work. im running 275 width NT-05's look pretty nice and definitely "squared up" look. i guess another 5 mm on either side would be too bad . |
11-18-2010, 04:39 PM | #7 |
Rep 318
I just came from the tire shop and the guys says it would work for re-11's to put 285 on the rear wheels. Bridgestone specify they will work on rims from 9.5 to 11 inches. just might try it and if I don't I'll revert back to 265's
11-18-2010, 05:01 PM | #8 |
Captain Obvious
90
Rep 977
The only issue I've had with these tires (and I'm on my second set: 265 up front, 285 rear) has to do with the sidewall stiffness. Usually it takes at lease 2 guys to wrestle them on... I usually pre-warn them about it and ask they be careful not to scrape the wheels in the process.
11-18-2010, 05:11 PM | #9 | |
Rep 318
by the way I love your pic where the corvette gives you the go ahead PRICELESS |
11-18-2010, 05:37 PM | #10 | |
Captain Obvious
90
Rep 977
(And now I'm on snows... just looking wistfully at the 19's sitting in the corner.) Pressures are higly subjective to the conditions. Generally I tried to keep them below 43-44 (hot) though. More than that and you start to get that "greasy" feeling. I actually found I had to keep the rears a little higher than the fronts to keep the suspension from giving me grief under hard braking. Thanks! I highly recommend anyone who has the chance take your car to Laguna Seca - it's an awesome track. Tough, but NOTHING beats the corkscrew done right. Six months later and I still smile every time I think about it.
11-18-2010, 08:35 PM | #12 |
yodog
197
Rep 5,025
285/35/19 will work on 9.5 though that's the max a 9.5" rim can handle. If you aren't lowered and have not put on spacers or messed with the offsets then you will not rub and can run this setup just fine. I feel the 255/285 F/R combo is very balanced.
Now running 285/35/19 on wheels with a more aggressive offset, that I am not sure if it is safe as the sidewall is noticeably bigger and could hit your fender.
11-18-2010, 10:51 PM | #13 | |
Rep 318
11-18-2010, 10:56 PM | #14 | |
Rep 2,266
Cheers
Ben |
11-19-2010, 08:11 AM | #15 | |
Rep 318
do you have pics of what the wider tires look like on the rims? |
11-19-2010, 09:44 AM | #16 | |
Captain Obvious
90
Rep 977
Freshly mounted (when I posted this one I had questions about the directional versus asymetrical tread patterns) A side shot As for what MrHarris said - I'm not running any spacers, but I am lowered 1/2". Never had any issues with rubbing.
2013 Santorini M3, 2016 328i Alpine White Wagon (Lab hauler), 199x wrapped E36 M3 (because racecar) ///M-Flight Last edited by dnvrdrvr; 11-19-2010 at 10:18 AM.. |
11-19-2010, 10:21 AM | #17 | |
chris
278
Rep 12,144
i believe the m3 GTS is running 285/30/19 not 35. so my opinion is that 285/30 is a better size than 285/35.
11-19-2010, 10:54 AM | #18 |
272
Rep 2,946
The 285/35/19 on a stock sized rear wheel will have a little too much side wall movement IMO. It will bulge over the wheel some. The tire has some great grip levels regardless, but i would put in on a rim thats 10in wide or more on the M3
11-19-2010, 12:26 PM | #19 | |
Rep 318
what would be the impact on daily drive and the track in your opinion? |
11-19-2010, 12:58 PM | #20 |
272
Rep 2,946
You would maybe only notice it on track if you are intune to your car. Since the side wall is taller, and also buldging more on the narrow oem rear wheel, its not as stiff typically.
11-19-2010, 09:40 PM | #21 |
Rep 318
will the increase in grip from having a wider tire offset the fact that the sidewalls are not as stiff?
11-19-2010, 11:01 PM | #22 |
Captain Obvious
90
Rep 977
Ah, but. One of the great things about these tires..? They're really stiff.
I'm going to look through some archive pics from this summer to see if I can get any clear shots of the wheels/tires on the outside of a corner - taking load. I may be wrong (don't tell my husband I said that!!) but I feel pretty confident saying I didn't have any issues with this tire setup on the track (seriously, 15 days this summer! not pansy-footing around either!) I'm not a tire expert, but I do know that the tire width "size" (255, 275, etc) doesn't always mean they're the same width. The only thing I have figured out is that it helps to ask someone who knows (and is why I PMd Ben @ TireRack). I certainly respect anyone questioning this will work - I've gotten loads of help from from folks on this forum and is why I keep coming back...
2013 Santorini M3, 2016 328i Alpine White Wagon (Lab hauler), 199x wrapped E36 M3 (because racecar) ///M-Flight Last edited by dnvrdrvr; 11-19-2010 at 11:48 PM.. |
