07-16-2019, 10:49 AM | #1 |
Rep 3,982
Combox For Sale - Bluetooth Streaming, A2DP
$115 shipped. Used, tested working. Bought two because I thought the first one I bought was DOA but it was a MOST connection/wiring issue. To retrofit, all you need is a few connectors from BMW, some re-pinning (easy), then coding and you are good to go. I can provide some support/guidance if needed since i just did this and coded it myself with NCS.
07-16-2019, 09:30 PM | #2 | |
Rep 336
07-16-2019, 09:54 PM | #3 |
Rep 3,982
Sorry if it isn't clear.
Combox is only came as an option for CIC based cars after around 2011(afaik). No idea if you can get this working on a car without nav or with ccc nav. My experience is adding this to a car with cic. Do your research on what is needed for the retrofit before buying please. |
07-18-2019, 06:25 AM | #5 |
Rep 4,429
If your car is equipped with CIC instead of CCC then it can be retrofitted into your car. It will require a wiring harness and coding to work.
07-18-2019, 08:08 AM | #6 | |
Rep 3,982
Did mine on my 2008 with CIC retrofitted, so it can be done in any car (you'll just need more parts) if CIC was retrofitted. Instead of buying a harness (usually $100-150), you can repin the connector in about 15mins. You'll need the following to repin: 1 x 61136913644, BMW, connector, 26 pin $15 from FCP 1 x 61136913626, BMW, socket housing, 26 pin $1 from FCP If you have TCU and MULF, you'll need to terminate one of the MOST connectors. 1 x 61136931507, BMW Diagnosis Interface Most, $24 from FCP or you can use a generic one from amazon for $12 shipped: https://amzn.to/2LqIUvx This is the guide I used to do the install: https://www.bimmerfest.com/forums/sh...d.php?t=772784
Atomicteal_M3747.50 |
