07-16-2019, 10:43 AM | #1 |
S1N1ST3R
143
Rep 1,174
Transmission Flash to Increase Line Pressure
Hey guys has anyone ever done any logs to monitor line pressure in the transmission ?
I need to increase the line pressure for my clutches, SSP has recommended doing a transmission flash, but I want to make sure will increase properly so I avoid issues with the clutches slipping. I need a transmission flash that will reach 18 bar of pressure. Anyone have any recommendations of any trans flashes out there.
2012 E92 M3 World's Fastest N/A E9X M3 & Stock Motor Supercharged E9X M3 11.49 @ 121.54 10.38 @ 136.04 |
07-16-2019, 03:26 PM | #2 |
Rep 1,385
In for this info
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
07-17-2019, 06:46 PM | #5 |
Rep 457
Can anyone chime in about the GTS flash? I know for the F82 GTS, the trans flash DOES increase pressure, but I can't comment on the E92.
Most of the aftermarket trans flashes are based on the GTS tune, are you considering asking tuners putting out DCT flashes if they can do a custom file? |
07-17-2019, 09:29 PM | #6 |
mTekMods
2142
Rep 2,901
Clutch pressure is regulated by the tcu. The dme calculates load/torque constantly then it’s sent to the tcu to determine how much pressure to apply to the clutches to match the calculated Torque. If this is value isn’t accurate from the dme the trans will slip.
07-18-2019, 09:40 AM | #7 |
S1N1ST3R
143
Rep 1,174
So This value needs to be adjusted through the DME side via tune and not by transmission flash ? Cause in my case with the supercharger im making way more power, and the clutches barely slip. I want to be able to increase the pressure cause the e9x trans dont run that much pressure from factory. I want to be able to fix this for good.
07-21-2019, 03:53 PM | #9 |
Rep 3,001
have you tried the GTS flash yet? I'm sure that might work well with your upgraded SSP clutches.
INSTAGRAM: GORDON.M3
05-13-2022, 01:25 PM | #10 |
Rep 3,988
Who offers this now?
05-14-2022, 06:33 PM | #12 |
Rep 3,001
if you ever in Toronto you welcome to swing by my place bro, I can flash it for you
05-14-2022, 06:49 PM | #13 |
Rep 3,988
Not Looking for the GTS tune, looking for someone who can do increased line pressure for a super charged car.
05-14-2022, 10:24 PM | #14 | |
Rep 3,001
They blogged about it too multiple times. https://www.xhpflashtool.com/blog/20...essure_on_dct/
05-15-2022, 12:31 PM | #15 | |
Rep 3,988
