      06-03-2018, 02:41 PM   #1
Dlpfcb
Drives: AW E92 M3
Gap Filler For Front Lip
Just installed a front lip and not thrilled with the fitment. We live and learn and can’t undo it now. I want to fill the gap slightly across the front. Can anyone point me to a proper black caulking of some sort that would work. I’m worried about getting the wrong one and have it effect the paint or have it dry out, fade and crack. Any help would be appreciated.
      06-03-2018, 06:18 PM   #2
jdamore
jdamore's Avatar
433
Drives: 2008 e92 M3
Caulk and paint make a man what he ain't. Haha that what my father always said.
Do you have pictures? Is it possible its not positioned just right? Maybe there is a small area that needs to be taken down so the lip will sit closer? Personally, I would rather see a gap then caulk on a car
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
      06-04-2018, 12:45 AM   #3
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
Any black silicone will work. You could also use black gasket sealer if you want something stronger.
      06-04-2018, 12:44 PM   #4
dparm
Stop the hate, get a V8
dparm's Avatar
Why not just use some black rubber trim/edging? Isn't silicone going to basically make the lip non-removable?
Past: 2011.5 M3 sedan ZCP
      06-04-2018, 12:53 PM   #5
Banana Hammock
Beefcake
Banana Hammock's Avatar
3769
Drives: NA
Nah, silicon comes off pretty easily. I use the stuff (clear obviously) to seal where the glass meets my bathtub. I scrape that crap off and apply a new bead twice a year to keep it clean.
      06-07-2018, 02:48 PM   #6
Aktavate
Aktavate's Avatar
246
Drives: Red
2011 E90 M3  [0.00]
2002 911 Turbo  [0.00]
I grabbed a tube of this but havent installed my lip yet. I tested it on a couple random things and it seems to have the right properties, should seal the edge nicely and isnt super permanent.
      06-08-2018, 06:29 AM   #7
Majdi
Drives: 2010 BMW M3
Which front lip did you buy?
      06-08-2018, 06:36 AM   #8
FMLYSDN
FMLYSDN's Avatar
Drives: 2011 Frozen Grey E90 M3
For what it's worth I used some clear silicone that I purchased from Home Depot. I used the kitchen and bath stuff. Painters tape is used to create a nice edge. I wasn't a fan of black myself. To each their own though! Best of luck.
      06-12-2018, 01:52 PM   #9
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
Windshield adhesive
      06-12-2018, 07:09 PM   #10
Aktavate
Aktavate's Avatar
246
Drives: Red
2011 E90 M3  [0.00]
Ended up using what I linked above when I installed my lip the other day. Its pretty forgiving to work with and even if you totally screw it up its not permanent.
      06-12-2018, 11:09 PM   #11
Dlpfcb
Drives: AW E92 M3
Awesome thanks man, I will give it a try. Got some pics of your lip.
      06-13-2018, 05:46 PM   #12
Aktavate
Aktavate's Avatar
246
Drives: Red
2011 E90 M3  [0.00]
Sure, I didnt use a ton so its not like RWB style. Visually filling the small gap and making sure at high speeds air wasn't trying to separate the lip from the bumper were my main concerns.
TTony271.00
