Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Cars for sale/wanted/trade
      05-31-2018, 06:34 PM   #1
aznbo187
Drives: E46 M3, 128, E91 328, E70 X5d
2002 Dinan Steel Gray Coupe - 6MT/CSL/VANOS/RTD/TCK
USD 22,000.00
Well sorted E46 M3 in rare Steel Gray on black leather with all common issues addressed:
VANOS overhauled, Subframe overhauled, Rod Bearings, Transmission and Cooling system all within last half year.
Daily driven, never tracked.
Looking for E90/E92 M3 DCT + cash or mint 335is. MUST BE DCT.
This is my 3rd E46 M3, owned for a year and no expenses spared in maintenance and driver orientated quality mods. Went through multiple iterations of modifications (3 different coilover setups, multiple bushings variations, intakes) to find the perfect balance of reliability and comfort.
Previous Build References:
Carbon Black M3 Sale Thread
Alpine White M3 Sale Thread
History:
I believe 2 previous owners, both BMW enthusiasts.
Norcal/Socal car all its life, with one year spent in Spokane, Washington (garaged, never driven in snow).
Car itself is in great condition, both interior and exterior. Paint is in great condition, no accidents, frame damage or rust. All paint is original, front bumper could use a re-spray due to age. OEM CSL trunk color matched at BMW paint center.
All electronics are fully functional. A/C blows cold, stereo sounds superb, heated & powered seats function, auxiliary items such as defrost, wipers, lights, gauges all work as intended.
All upgrades & maintenance within last half year.
2002 BMW M3 Steel Gray
  • Black Nappa Interior
  • Powered & Heated Seats
  • Karman Kardo Audio
  • Sunroof
  • 6MT (SMG to 6MT Conversion by Garage 54 @140k)
  • 170k
  • Clean Title (Title in hand)
Exterior
OEM Headlight Lenses
OEM Clear Corners
OEM Tail Lights
OEM Side Markers
OEM CSL Trunk (Glasurit paint by Pacific BMW)
OEM Hood Vent
OEM Gloss Shadowline Window Trim
OEM Windshield Trim
Osram 66240 CBI (5500K)
LED Reverse Lights
Color Matched Kidney Grills
Color Matched Reflectors
Gloss Black Side Grills
Rear Fenders shaved by Tony
Mechanical
RTD Short Shifter
RTD DSSR
Rogue Engineering Transmission Mounts (Street)
Rogue Stainless Clutch Pivot Pin
Rogue Engineering Clutch Line
Dinan Big Bore Throttle Bodies
Dinan Strut Bar
K&N 57 Series Intake & AEM Dry-Flow Filter
Agency Power Headers
High Flow Metallic Catalyst
Beisan Vanos Complete Overhaul (Anti-Rattle, Hub, Sealing Plate, Viton Seals, Bolts)
OEM Exhaust Upper Chain Guide
OEM Machined Bell Housing & Detent Springs by Kaiv
Suspension
TC Kline S/A Coilovers
Ground Control Street Hybrid Adjustable Camber Plates
Ground Control RSM
Ground Control Weight Jacks
SPC Rear Adjustable Camber Arms
PowerFlex Hybrid FCAB
PowerFlex RTAB
Hotchicks Adjustable Endlinks Front
Apex 75mm Extended Studs/Nuts
OEM Wheel Bearings
Brakes
996 Brembo F/R BBK Conversion
Creation Motorsport F/R Braided Lines
Rally Road Brackets
OEM CSL F/R Rotors
Textar F/R Pads w/ new damping plates
Racing Brake Upgraded Seals
Motul 660 Brake Fluid
Wheels
TSW Geneva Rotary Forged 18x9.5/18x10.5
265/35/18 Federal SS 80% Thread
Interior
Piano Black Trim
CF Door Handle Trim (Front & Rear)
Rennline Full Pedal Set w/ Extensions
CF Lower Steering Wheel Trim
BMW Motorsport "Golf Ball" Knob
OEM A/C Pillars
OEM Center Console
OEM Cup Holders
OEM Center Storage
OEM Radio Faceplate
OEM Aux Adapter
ECS Clutch Stop
Maintenance
CMP Subframe Reinforcement - Plates, Topside front & rear brace
CMP Solid Subframe Bushings
OEM Rear Differential Bushings & Updated hardware
Rear Differential Seals
Valve Adjustment
Rod Bearing Recall via BMW
ICV Flush
OEM Intake Camshaft Position Sensor
OEM Exhaust Camshaft Position Sensor
OEM Throttle Position Sensor (Both Sensors)
OEM Clutch
OEM Shifter Bushings
OEM Valve Cover Gasket
OEM Clutch Fan
OEM Guibo
OEM Idle Control Valve
Essentially all transmission components (bearings, compression springs, pins, seals) were replaced during the 6MT swap
OEM Engine Mounts
OEM Fuel Filter
OEM Fuel Pump
OEM Cabin Filter
OEM Final Stage Unit
Hunter 4-Wheel Alignment
Accessory Belts
Motul Transmission Fluid
OEM SAF-XJ+FM Differential Fluid
Oil/Filter every 5K using Castrol 10W-60 TWS
Blackstone Oil Report show normal wear on internals/bearings
Included
ACS Roof Spoiler
OEM Trunk
Color Matched Hood Grill
      06-01-2018, 11:30 AM   #2
Teufel_Hunden
Drives: 2013 M3 6MT LMB ZCP
Beautiful e46! GLWS!!
      06-25-2018, 12:34 PM   #3
aznbo187
Thank you! Still available.
      08-21-2018, 11:16 AM   #4
aznbo187
Subframe and rear end just reinforced and bulletproofed.
      08-22-2018, 04:59 PM   #5
JD3
Drives: 09 e92 M3, DCT.
Pm sent
      08-23-2018, 11:32 AM   #6
aznbo187
Originally Posted by JD3 View Post
Pm sent
Thanks for the PM!
      08-24-2018, 10:59 PM   #7
maaicher
maaicher's Avatar
62
Drives: 2008 BMW M3
Any pics of the interior?
SOLD Current 2008 Space Grey E92 M3 * JRZ RS Pro * TE37SL * AP Racing * Sparco Evo * Akrapovic Slip On * Studio RSR Cage *
SOLD 2003.5 E46 M3 * Apex ARC8 * MCS 2-Way * Stop-Tech C43 * Recaro Profi XL *
SOLD 2008 Jet Black E92 M3 * HRE C20 19in Wheels * KW Clubsport * Huper Ceramic Tint * Stop-Tech Trophy BBK * Gintani SC & Gintani Custom Exhaust * Vertice Front Bumper * Arkym Diffuser *
      08-25-2018, 06:11 PM   #8
atschmale
Drives: 2011 335is DCT
Beautiful car. Can't believe it hasn't found a new home yet! GLWS.
      08-30-2018, 09:35 AM   #9
JD3
By the way, second pic from bottom is weirding me out, haha. Took me a few looks to realize it was a tree branch top and bottom.
      09-24-2018, 06:50 PM   #10
aznbo187
Still open to offers/trades.
      09-24-2018, 08:37 PM   #11
Duck360198
Drives: 2018 F30 340i Laguna Seca Blue
Damn this looks great!!!
      09-25-2018, 05:52 AM   #12
DUBitDOWN
Drives: VW Jetta/GTI
Looks great. How many miles?
      09-25-2018, 08:43 PM   #13
aznbo187
Thanks!
160k. Daily driver at the moment so it will go up.
      10-12-2018, 11:32 PM   #14
princelybug
princelybug's Avatar
South Korea
60
Drives: '11 LBM E90 335i M-Sport
Vouch for a solid seller.
'11 LBM E90 335i M-Sport (Current)
'12 AWP II MDX Tech (Hers)
'07 NBP TL Type-S 6MT (Sold)
      05-07-2019, 12:11 PM   #15
aznbo187
Bump!
