05-13-2019, 09:23 AM | #1 |
Rep 4,066
CIC Retrofit Coding Help - Screen worked, then Blank after coding.
Upgrading from CCC. All CIC parts from a 2010, non-m vert.
Install went smoothly, re-pinned the cid power cable. Removed ccc video cable, routed cic video cable. Ran usb to the glove box. On first power up, screen comes to life I am able to navigate thru menus check a few things. No sound at this point. Few options not there (as expected). Started the coding, using NCS Expert, Changed CAS VO, Removed #0308 & $S609 and added #0909 & $S6VA (no combox installed right now.). FA_Write CAS, NFRM. Went to FA_Write CIC which was listed as MCIC but FA_Write wasn't available. I decided to SG_Codieren a Blank .MAN file. Did that, I also did a Codierdaten_Lesen Read just to take a look at a TRC file for MCIC. Everything looked okay to me. Went to power on, I get sound now but screen backlight comes on and the screen is blank. I've tried the following troubleshooting the issue: - Changed to #0311 fa write to CAS and NFRM. Could no longer see CIC or MCIC in the module list. - Tried #0909, same issue as above. - Changed things back to #0909 where NCS can see MCIC and SG_RESET it. No change. - Checked connections at the back of the screen, removed and re-seat connections, removed HU and re-seated connections there also. - I have not done the script activation as yet, my plan was to get everything working without nav then do the script activation. Also note I had a slow 3.8A charger on the car for a few hours during install and coding. Stopped last night to watch the basketball game, figured i'd poke around today after work. Let me know if anyone has any suggestions.
05-13-2019, 10:35 AM | #2 |
Rep 4,434
Looks like your battery is low bro. I too upgraded to CIC a few years ago. Not a issue. Got my car wrapped a few months back. The car sat in the shop for 2 weeks without trickle charger. When I picked it up and started it, my screen was blank but I heard sound. I took it back to the shop and they were just as puzzled as me. So I drove back to my house and put my car on the trickle charger for the whole weekend. Once I noticed the battery was fully charged I started it up and PRESTO the screen was back to life!
05-13-2019, 11:10 AM | #3 | ||
Rep 4,066
I found this which conflicted with the DIY instructions I followed so i'll try this after work today. Quote:
05-13-2019, 05:05 PM | #4 | |||
Rep 4,434
